Question about Kenmore Washing Machines
Washing machine sounds like it is spinning but isn't. 70 series model #82870120
  • 5,911 Answers
Your washer more than likely has a broken motor coupling. This is a common fail item with this model washer thorugh normal wear and tear. Newer versions of the coupler are more resilient and resists breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupling can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria. Let me know if you have any questions. I hope you find this information helpful. NOTE: There are other problems that can cause the washer symptoms as you describe. The motor coupling is the least expensive and easiest solution to try first. If the motor coupling is still intact, please let me know.
Posted on May 14, 2009
I have a Kenmore 70 series Washing machine top load model 110 serial number 82870120 . where is the lint trap located and how to take out to clean? clothes have a lot of lint after being washed.
It is likely that a tissue or paper product was included with the wash load. The series 70 does not have a lint trap. At the hose connection to the house drain lint has been known to build up restricting the emptying. This buildup would not introduce lint into the washer.
If the water temperature is very very cold and you use powder detergent it will not dissolve completely into the water and will leave a white residue on the fabrics.
Try running a short load in the washer allowing for ample water to rinse out the machine before the next wash load.
Dec 28, 2015 | Kenmore series 70 80 90 Washer timer...
How do i determine if my switch is working on my kenmore 70 series washing machine
i think there is some problem in wiring of spin and drain. thats y it works only for washing. current stops after washing. or otherwise click below link and check the manual may be its timer problem
http://www.askmehelpdesk.com/appliances/kenmore-washing-machine-70-series-repair-manual-479481.html
http://www.askmehelpdesk.com/appliances/kenmore-series-70-washer-manual-445690.html
Jan 04, 2012 | Kenmore Washing Machines
Kenmore 70 series washer model 22722 will not spin or agitate
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 14, 2011 | Washing Machines
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
Mar 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer not spinning ans washing
Does it sound like the motor is running at all ?( if motor is running u need a coupler) (with machine off turn cycle switch around 3x roughly, then try machine) With the machine off do you hear a clicking noise if you open and close the lid?
Mar 25, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
53 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
