Question about RCA R52WH73 Projection Television
Tv shots off 10 minutes - RCA R52WH73 Projection Television
  • 28 Answers
Unplug set, take off bottom (rear) panel and carefully blow out the dust with a can of compressed air. If that doesn't help you probably have some bad solder connections or a component failing when it gets hot.
Posted on May 15, 2009
Replacing crankshaft position sensor on 2005 kia sorento
Vehicle 2005 Kia Sorento
after 10 t0 20 minutes will shot down 10 minute to 15 will start again, I check all fuses any clue
Oct 09, 2012 | 2005 Kia Sorento
I have got a technika television which is stuck on DVD mode. The remote that i have for it does not work, so i bought a Gemini universal remote to try and solve the problem but the codes provided do not...
Have you tried unplugging the TV for 10 minutes? If not, give that a shot. This will allow the TV to reset itself to factory defaults (usually back into TV mode) so at least you can use your TV while you figure out the remote. There is also a possibility that the TV is stuck trying to read a remote that is lost (for some reason the firmware could be locked up) This would keep your Universal remote from working even with the correct codes. I hope this helps!
May 27, 2011 | Televison & Video
TV shots off by itself
is it a projector?Loose fitting wall plugs can loose connection momentarily and power will shut off to protect bulb
Feb 18, 2010 | Westinghouse Televison & Video
Sony syber shot w130 10 min limit for movie clip
You can not remove the 10 minute limit.
The manual says that 10 minutes is the maximum time you can shoot continuosly.
You can make a longer movie if you break the shots up to less than 10 minutes each.
Hope this helps.
Feb 10, 2010 | Sony Cyber-shot DSC-W130 Digital Camera
Extremely long warm up time 25 minutes. ok once it comes on.
Just a shot in the dark- I think your main projection lamp is going bad- If the set is more than a year or 2 old it can happen. Unfortunately they are a little expensive.
How is the brightness level after it warms up??
May 30, 2009 | Audiovox FPE2706 27 in. LCD Television
Blue screen
your screen may be shot. Do not take out the battery. Try these IN ORDER:
1: place in charger overnight WHILE THE PHONE IS OFF!
2:place closed phone (that is on) in the refrigerator for 5 hrs. Leave open for 10 minutes to defog. DO NOT HEAT IT IN ANY WAY!
3: Turn off phone. Remove battery and let sit for 10 minutes to 1 hour.
If none of these work, then your screen is shot.
4: Take to your carrier's dealer and get the screen replaced.
Jul 22, 2008 | LG VX5200 Cellular Phone
Sharp remote control not working
Ok, looks like this TV works on MS Windows. Anyone who has had a computer 5 years back knows that when Windows has a problem, there is only one sure-shot solution.
SHUT IT DOWN, START IT UP !
Try this with your TV. Completely unplug it and leave for one minute. Start again. Voila ! Remote works flawlessly.
Feb 13, 2008 | Sharp Televison & Video
TV screen went black, sound OK
check cold solder vertical circuit
Nov 21, 2006 | JVC AV-27530 27" TV
RCA R52WH73 Projection Television Logo
43 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
