Question about Dell (U0614) for Inspiron 5150 60 GB Hard Drive
Dell inspiron 5150 primary hard drive disk 0 not found
I started receiving the message "primary hard drive disk 0 not found" whenever i tried to boot my dell inspiron 5150.
i figured that my original hard drive had died sooo i purchased another. after installing the new hard drive, i'm still receiving the same message...i went into bios and it is not found there, either.
really need the help....starting online classes soon. thanks.......
  • debbydo May 15, 2009
    well.....i feel stupid. went to a cppl other techie sites and found that i had neglected to remove the blk plastic adaptor thingie that covers the points on the old hd and reapply it to the new one. i am now up and running...installing winos xp as we speak!
    i guess sometimes it's the simple things to ck first.......
    thanks for all your help; you ppl are terrific!
  • 909 Answers
You may find that either the cable is not connected properly or is faulty, or the worse case the mother board has problems (driver, chips, breakages)
May even be a power supply problem, as the power supply has many output points and different voltages that the HDD power out may have blown. If it has then the rest of the system will appear to be ok.
So first off, check the cables connections on the motherboard, and look for any breaks in the cables, and if you have a power meter of some sort check the power connection, or plug in another power connector, the ones with the same end are generally the same power outputs. The ribbon cable for the HDD should have 2 sockets for HDDs and you must connect your HDD to the end one.
Posted on May 14, 2009
My dell 5150 dimension will not boot up and says no boot device available. I have gone into system setup and tried a few things and at one point got a message that said drive 0 not found and now it is back...
Go back to setup and check your boot sequence. It may not be looking for your hard disk. Do you know what Hard disk you have? It may not be wired in there properly if it's in the boot sequence. Set DVD/CD to 1st boot device and put in your installation disk. Do you boot now? Do you have data on your hard disk you need? If not, Re-format the drive.
Nov 07, 2009 | Dell OptiPlex GX280 PC Desktop
Dell Inspiron 8500 started boot error message ?primary hard disk drive 0 failure, no boot device available?strike F1 to retry reboot, F2 for setup. Ran express diagnostics and it shows two errors: Error...
Call Dell if under warranty. Start shopping for a replacement hdd if outside of warranty. You'll need
your OS disks that came with computer (hopefully). If you don't have OS/recovery disks, you can get
them from Dell or even using somebody elses (match version with sticker on your laptop).
Check the hdd connection underneath laptop - make sure cable is not loose, etc.
Probably safe to say your data is gone unless you're willing to spend $$.
Jul 12, 2009 | Dell Inspiron 8500, Latitude D800...
Dell inspiron 5150 green light flashing on front won't boot up
I had the same problem, replaced the hard drive and problem went away. The hard drive developed bad boot sectors after downloading XP service pack 3. I found out later it isn't compatable with the dell I have. Hope this helps. Good luck!!
Apr 29, 2009 | Dell Inspiron 5150 Notebook
I have a dell inspiron 5150 and it won't start up it started with NTLDR is missing I tried to replace these files with new ones didn't work. I have 2 laptop another one is a compaq armada 1750 now the 2...
inset the extrnal dvd drive attch with usb cable and insert the orignal windows cd dell recover cd and boot timepress F12 and select the extrnal drive and start your system setup.............ok
Apr 02, 2009 | Dell Inspiron 5150 Notebook
Dell 8250 Hard drive 0 not found after move from US to UK
IT sounds like the hard drive went bad, especially with the clicking noise. If you want to keep the system, you will need to buy a new drive (relatively cheap) from tigerdirect or newegg and istall it. NOt sure if dell still send out recovery cds with their systems but if you have one just insert the cd after you install the new drive and follow the prompts. If you do not have one contact dell support and they should beable to send you one
Jan 21, 2009 | Computers & Internet
D6000 DELL LAPTOP
Do you have any flash drives or external drives connected? If so unplug them and try to reboot. If not check to see if the hard drive is firmly in place sometimes they can come un hooked and that error will appear.
Oct 03, 2008 | Dell Latitude D600 Notebook
Dell Latitude C600 Laptop
Did you try to boot into the BIOS and load the default settings?
Pls check if the hard drive is recognized in the BIOS first.
Sep 02, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Primary hard disk drive 0 not found
The first thing to try is removing and reseating the hard drive. Sometimes the drive just looses it's connection with the motherboard, reseating can resolve that.
If that doesn't work, you can get a 2.5 in USB hard drive enclosure, and see if you can read the drive in another system, and recover you files that way.
Most likely though is the hard drive has failed. If this has occurred, then your options are limited. You can contact a data recovery service, but that is expensive. Http://www.ontrack.com or http://www.drivesavers.com are a couple options. You can contact them and get an estimate of the cost if the other options do not work.
Jun 08, 2008 | Dell Inspiron 6400 Notebook
Laptop won't boot..
try new hard drive 1st ok
Jan 30, 2008 | Dell Inspiron 8500 Notebook
Dell (U0614) for Inspiron 5150 60 GB Hard Drive Logo
621 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
