Question about Foxconn K7S741GXMG-6L AMD Socket A Athlon/ Duron/ Sempron microATX Motherboard- Retail (0683562741415)
Bios and ddr
I put another ram in my com and i got a series of beeps and no boot up i was told by a tech guy that it is a memory beep and the part may be faulty but i was told by the manufacturer that it is something to do with the bios
  • 196 Answers
The new RAM is faulty or incompatible.
Take out the old RAM and see if the error goes away. If it does the two sticks are incompatible. If not the new RAM is the wrong type or faulty.
Get a stick that matches what you have, and you should be OK.
try  www.crucial.com and use their memory finder.
Posted on Oct 16, 2007
Why does my dell inspiron m5030 laptop give me a series of 5 beeps and wont boot when I try to turn it on?
Please read this:
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Jan 12, 2013 | Dell Inspiron M5030 Laptop
MB keeps beeping 1 long beep no boot.
Hello try to download the manual:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=4&m=CUSI-M&os=&hashedid=n/a
Select windows xp and open the manual folder
Click on global for download.
Unzip the file and you need adobe reader to read the content.
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
This mainboard uses SD ram and it sounds like a ram problem.
If there is room for a ddr ram block you can`t use SD ram and DDR ram simultaneously.
Try to insert the old cpu again and upgrade the bios to support a bigger cpu. Not all cpu is supported.
Good luck
Dec 22, 2012 | ASUS SiS Chipset CUSI-M Motherboard
The PC does not start.Only it beeps and a red light blinks,also fen is not working.
here are some of the basic codes, depending on which BIOS you have...
Also you do not indicate which fan? I would guess you mean the main Power Supply (PS)? In which case it could just be you need to replace the PS.
Here is a link to some other codes as well...
AMI BIOS ERROR BEEP CODES
  • 1 Beep - Memory Refresh Failure (check memory)
  • 2 Beeps - Memory Parity Error in first 64KB block (check memory)
  • 3 Beeps - Memory Read/Write Error in first 64KB block (check memory)
  • 4 Beeps - Motherboard timer not functioning (possible motherboard replacement)
  • 5 Beeps - Processor Error (may need replacement Processor)
  • 6 Beeps - Gate A20/keyboard controller failure (possible motherboard replacement)
  • 7 Beeps - Processor Exception Interrupt Error (may need replacement Processor)
  • 8 Beeps - Display Memory Read/Write Failure (reseat or replace video card)
  • 9 Beeps - ROM checksum Error (replace BIOS chip or motherboard)
  • 10 Beeps - CMOS shutdown Read/Write error (possible motherboard replacement)
  • 11 Beeps - Bad Cache Memory - test failed (replace cache memory)
Phoenix BIOS ERROR BEEP CODES
Phoenix BIOS beep codes are a series of beeps separated by a pause, for example:
beep --- beep beep --- beep --- beep beep would be 1-2-1-2
  • 1-1-4-1 - Cache Error (level 2)
  • 1-2-2-3 - BIOS ROM Checksum
  • 1-3-1-1 - DRAM Refresh Test
  • 1-3-1-3 - Keyboard controller test
  • 1-3-4-1 - RAM Failure on address line xxxx (check memory)
  • 1-3-4-3 - RAM Failure on data bits xxxx of low byte of memory bus
  • 1-4-1-1 - RAM Failure on data bits xxxx of high byte of memory bus
  • 2-1-2-3 - ROM copyright notice
  • 2-2-3-1 - Test for unexpected interrupts
I hope this helps.
Mar 29, 2011 | HP Computers & Internet
It beeps five times and no picture just five beeps
The beeps you hear is a BIOS Beep Code.
The computer's way of telling you something is wrong, and an area to look into for the problem.
The BIOS Beep Code is sort of like Morse Code.
Instead of a series of dots, and dashes, it's a series of short beeps, and long beeps.
One example:
One short beep, two long beeps.
Then a period of silence, and the beep code starts all over.
There are different BIOS manufacturers that make the BIOS program.
(Basic Input/Output System)
Two of the main BIOS manufacturers are AMI, (American Megatrends Inc.), and Award/Phoenix.
(Award and Phoenix used to be two separate manufacturers, but have combined)
5 short beeps sound like one of AMI's BIOS Beep Codes.
http://www.pchell.com/hardware/beepcodes.shtml#ami
Part of the information given states to remove the ram memory module/s, ('Sticks'), and reinstall them.
I would also like to add to clean the gold plated contact pins, on the bottom of the ram memory modules.
Computer off, unplugged from power, and computer case open, observe Anti-Static Precautions BEFORE reaching inside your computer, and handling the ram memory module/s.
Use a pencil eraser to clean the gold plated contact pins.
Example of a DDR Sdram ram memory module, and it's gold plated contact pins,
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
(You can click on the photo to enlarge. You can enlarge twice)
The top of the ram memory module is towards the DRAM chips. (Black rectangular objects)
The bottom of the ram memory module is where the contact pins are located.
Suggest use the eraser on the top of each contact pin, stroking down towards the bottom of the contact pin.
If you are using an eraser on the end of a pencil, refrain from letting the metal band touch the contact pin.
Now use air to remove the eraser dust.
You can use a can of compressed air for computers, if one is readily available, or air pressure from your mouth will be sufficient.
Reinstall the ram memory module/s.
Close the computer case, plug the computer back into power.
WAIT 1 minute, turn the computer on.
Sep 15, 2010 | Computers & Internet
Beep codes
1 Long Beep: Memory problem
Explanation: There is a failure of some sort related to the system memory.
Diagnosis: The first bank of memory probably has a failure of some sort; this is usually just a physical problem such as an incorrectly inserted module, but may also mean a bad memory chip in a module. It is possible that there is a failure related to the motherboard or a system device as well.
May 14, 2009 | AOpen AX34-U Motherboard
I put a 1gb expansion ram in my toshiba satellite M35X-S149.  Did it with the battery out.  Put the new ram in the empth slot - - 256 mb in the other slot from the factory.  When I turned on the power, the...
Remove the 1 gig chip. Pull you battery out and unplug the laptop. Hold the power button in for 10 seconds. Put the battery back in and plug the laptop back in again and try booting it up. This should reset the BIOS and allow it to boot. The beep codes you are talking about are a memory beep code and it is normally caused by adding memory or a loose memory stick. Also try pulling the existing memory and resetting it.
Dec 20, 2008 | Toshiba Satellite M35X-S149 Notebook
New RAM, computer stays on intel screen and occasionally continually beeps
Hi DeezKelb, The continous beeps you are hearing is the Award bios telling you the memory is not seated correctly. Please remove the memory & re-seat the two DIMMS.
See Award bios beep codes, click on this link.
http://www.bioscentral.com/beepcodes/awardbeep.htm
If the beeping continues. Either boot into the bios & reset from there or reset the bios by moving cmos/bios jumper page 1-16 in you're user manual to clear/reset the bios. (Remember to set the jumper back to default). Boot the PC & enter bios to setup you're prefered settings.
If you're board still continues to beep download a free program called Memest86 & run the software which will test you're memory. http://www.memtest.org/ Scroll down the page till you are under the three Screenshots. Listed there is ** Memtest86+ V2.01 (21/02/2008) ** typed in red.
You have a choice of downloading software to creat either a bootable floppy disk or a bootable CD disk.
Bootable floppy; Download - Pre-Compiled package for Floppy (DOS - Win)
Bootable CD; Download - Pre-Compiled Bootable ISO (.zip)
You're Asus board can only run up to 2GB Max memory.
Main download web site for ASUS P4V8X-X.
http://support.asus.com/download/download.aspx?modelname=P4V8X-X&SLanguage=en-us
Good Luck!
Have more questions, feel free to ask.
Mike
May 04, 2008 | Intel D101GGC Motherboard
No display
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
39
Apr 09, 2008 | Intel Motherboard
Memory upgrade
Chances are you just need to reseat memory. Make sure the slot in the memory lines up with the DIMM. Flashlight helps.
Below is a link about BIOS beep codes & what they mean
There are others on the far right, like AMI ect
Jan 03, 2008 | Dell Precision 360n PC Desktop
No boot on start up all fans start but no video
I had same problem!
I figured there was something wrong with my memory because that is what the manual says the constant beeps mean.
I bought a new PNY memory stick 1 gb DDR and got the same beeps when i put it in.
So being totally disappointed I tried putting the Stick in the #3 DIMM. I booted up and IT WORKED!
I have not called tech support or tried both 1 & 3 DIMM together but I will try after I set up the rest of my computer.
Sep 03, 2007 | Mach Speed (MSNV-939) Motherboard
Foxconn K7S741GXMG-6L AMD Socket A Athlon/ Duron/ Sempron microATX Motherboard- Retail (0683562741415) Logo
69 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
