Question about Philips Magnavox 24MC4306 24" TV/VCR/DVD
A thin line appears on the screen,when turned on
Sound is there but no picture, judt a thin line
We bought a new set, the tube on the old one was burnt out
Posted on May 15, 2009
Have thin line of picture on right side of screen, rest is blank. Sound is fine
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 05, 2015 | LG 32LG30 32 in. LCD HDTV
White fuzzy thin vertical lines appear on screen. The picture is fine, but the lines are in front of it. Is this something than can be repaired?
Hello can you post a picture of your tv set with the fuzzy white lines thank you so I can give you the best sound advice.
Aug 19, 2014 | Sylvania Televison & Video
Thin horizontal lines on screen
It sounds that the TV is displaying vertical retrace lines along with the picture. There are many reasons for this fault. It will be better to contact any service technician in this case. Gopakumar Gopalan Google
Feb 11, 2014 | Samsung BN96-08752A Y-Main LJ41-05683A,...
Tv had thin black line when turned on today whole screen scrambled
need to access the ez menu to reset the parameters u will need a tech to fo this
Jul 19, 2013 | Vizio VF550M 55 in. LCD HDTV
I have a LG model 47LH55 LCD tv. it is 3 months shy of me having it for 2 years. the problem i have is that there is a thin black line (actually two very skinny lines close to each other) that is running...
It sounds like you have a bad capacitor on the power supply or other boards. These will heat up over time and eventually swell and probably vent which will cause you this issue. The bad news is you need to get into the set and be able to solder to change them. The good news is they are easy to spot because they will be swelled up and not look like a cylinder or have a goo leaking from them.
If you happen to know enough to change these you can find kits online to replace all the easy components. NOTE: You have to use low ESR High temp capacitors on these because they get hot and won't run the delicate digital processes without producing very clean filtering(which is what usually causes lines like this... Dirty filtering of power)
Hope that helps!
Jun 25, 2011 | LG 47 in. HDTV LCD TV
32" sylvania TV thin line
There are bad solder connections on the vertical IC. This is a small flat IC attached to a heat sink. It should have about 9-11 pins and may be marked LA7837 or something similar. Resolder the pins on this IC and that should resolve the problem.
Dan
May 07, 2008 | Sylvania SRT2232S 32" TV
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
No picture
Power supply problems that must be addressed by a shop. Sorry...accordianman
Feb 03, 2008 | Hitachi 50UX57B 50" Rear Projection...
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Philips Magnavox 24MC4306 24" TV/VCR/DVD Logo
67 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
