Question about HP Photosmart C6280 Printer
Hp 6280 will not print 2 sided projects
I have been trying to print a two sided brochure but only prints one side and tells me I will have to feed it back for the other side.
  • lightyear25 May 14, 2009
    I understand that but I bought it to print duplex and it did before but not know that is my problem any one can print one side and then the other. If I wanted to do that I would have bought a less expensive printer,
  • 909 Answers
Thats correct, you need to flip the paper over and reload so that the printer will print the other side.
Just take the stack out of the tray and put it back in the loader and away you go.
You may have to press the continue key to carry on printing.
I hope this helps.
Posted on May 14, 2009
HOW DO I PRINT A BROCHURE
You can put special media on side bypass feed tray. Then select paper type/thickness. Choose the bypass tray and paper type when sending print job from your PC. Job status light will blink and you need to go to the copier to execute the print job for special paper.
Sep 26, 2014 | Toshiba estudio 255 Copier
What is on the screen- is not what is printed. My entire 2-sided brochure is not printed.
ok but did you set up the 2 sided printin on your printer. check the control panel of your printer click that icon that your printer puts in your tray and check printing or paper make sure it is set to 2 sided printing there
Sep 24, 2010 | Microsoft Office Publisher 2007 for PC
Using as a printer on 3-fold brochure
From your print menu properties change it from short 2 sided to long 2 sided or visa versa
Apr 30, 2010 | Canon imageRUNNER 5000 Copier
Print wedding announcements and the print is not straight
Card stock on an HP can be a nuisance, due to the paper feed path. The stock has to curl around the platen.
Some things to check: Make sure you are telling the print driver you are using card stock. It should be in the printing preferences as paper type. The printer will respond differently, knowing it has the heavier paper. Also make sure that your paper guides are adjusted to fit the smaller stock. Just putting in 5.5 x 8.5 paper into an 8.5 x 11 tray may cause it to skew.
I am assuming that you are already telling it to print high quality, as it is for a wedding announcement, but make sure that you are. Slowing down the paper feed speed by putting it into high quality mode can help.
Your printer is an older model, so it could be that the rollers are wearing down, and it just can't feed the last bit as well. You could try to print it in "landscape" mode. Turn the paper 90 degrees in the paper tray, so that the 8.5" is the feed side. This will allow the printer to have a better grip on the paper as it goes through. A word of caution with this method, though. HP's have a 1/2 inch margin at the bottom of the paper where it can't print. Turning the paper 90 degrees will force you to have a side margin of 1/2 inch. Currently, your bottom margin has to be 1/2 inch. I don't know what your layout looks like, so I don't know if you can turn the paper.
If you are the one getting married, the congratulations, good luck, and mazel tov! (Have to cover all the basis).
Jul 17, 2009 | HP DeskJet 5550 InkJet Printer
How do i make double sided copies for my HP 2840
When you call up your printer (usually [Ctl][P]) tell it to print even numbered pages only, but in reverse order, This means the last page to be printed will be page 2, and it will be face down on the top of the pile (blank side showing) Take the printed sheets and rotate them so the top (head) of the sheet is feeding back into the machine, with the blank sides up. Now call your print up again and tell it to print the odd pages only. The first sheet to be printed will be page 1 which will print on the blank side of page 2, and all the rest will follow in sequence, with the correct sides up. Works every time. The print control is part of the Windows system, so your application should provide the full functionality.
Dec 18, 2008 | HP LaserJet 2840 All-In-One Printer
Printing a two sided brochure on HP Color LaserJet 1600 and brochure is getting spotty. Do rollers need to be cleaned? If so how is this done? Printer is one year old. Thank you.
the hp1600 is a rubbish printer. The fuser is inefficient and the toner doesn't stick correctly to the page, for double sided jobs, print all of side 1 first, allow the pages t cool completely and then print side 2, alternately buy a HP3600d or HP3505d, its chalk and cheese
May 09, 2008 | Office Equipment & Supplies
Back to back printing
if you do not a duplexer, then the only way is to print one side then put the paper in the tray again and print the opposite side.
Usually the side you already printed will be face up in the tray
Feb 18, 2008 | Office Equipment & Supplies
Duplex printing on HP Laserjet 2840
This is the natural process for the you the user to make sure that you have the correct media in the manual feed. You can change this in the paper handling menu within the menu options set the tray 1 media type to plain and auto continue also correct paper size. You can also put the paper back into the main cassette and this will not cause the problem.
Thanks J
Jan 24, 2008 | HP LaserJet 2840 Printer
Margin printing problems
Check your application's print settings (for e.g. MS Word). Then check the printer's properties and print settings. If nothing works you also try re-installing the latest printer driver. If you use MS word should check the page setup option, for paper size errrors. If the color of your margin is red and the red ink is out then you won't se the margin line.
Oct 09, 2007 | HP Color LaserJet 2600n Printer
HP Photosmart C6280 Printer Logo
78 people viewed this question
Seeker5211
Seeker5211
