Question about Excalibur RS-310-EDP Remote Start Keyless Entry Dlx Map:58.50
Suburban battery keeps dying
I had my truck jumped since then battery keeps dying- i think it may have something to do with my aftermarket remote start - how do i un-install an excalibur remote start/alarm system
    Problem Solver:
  • 13 Answers
Locate the brain under the drivers side under-dash area. this may require you to undo a couple of bolts. you will need a 7MM and a 10MM depending on the year of the truck. from there you can unplug the the 6 pin main ignition harness from the brain. it may just be that the battery is no good. a trip to one of the major chain auto part stores can have them check your battery for free. Good luck.
Posted on Oct 21, 2009
    Filmmaker:
    Uploaded 5 video answers.
  • 126 Answers
Trickle charge the battery before taking it to the auto parts store for testing making sure it is fully charged. if the battery is good, check for loose ground wires at the brain box for the alarm as well as the battery to engine block ground strap. if the battery is bad get a new battery obviously. make sure your alternator wires are bolted tight, maybe even take that in for testing as well. you may also have an open relay somewhere.
Posted on Jul 20, 2014
I keep have to jump my suburban off i have changed alternator and starter still have to jump it off whats te problem
did you test the battery to make sure it can hold a charge. If the alternator goes sometimes it takes the battery with it ( orthe battery can cause the alternator to go)
Apr 02, 2014 | 1999 Chevrolet S-10 Pickup
We have an aftermarket car alarm installed, but have lost the remote. Our battery died and when we jumped it, the alarm reactivated itself and now we can't turn it off! We cannot start the vehicle unless...
I don't think that the alarm can be bypassed once installed. So you'll have to contact the aftermarket car alarm installer that put it in to try to get a new fob that will work with it, or else have it uninstalled by an alarm dealer.
I think the wires need to be traced to deactivate the alarm system, one way or another, because most alarms cut into the ignition or start wiring to prevent the vehicle from running.
Aug 09, 2010 | Chevrolet TrailBlazer Cars & Trucks
89 toyota camry battery issues
Sounds like something is drawing power from the battery when you are not driving your car. Check interior lights, head lights, brake lights, aftermarket stereo or trailer wiring.
Apr 11, 2010 | 1995 Toyota Camry
Battery cables
Do you have sealed battery cables? If you have the ones that are stripped with a clamp (shown below), then you should change the cables out to sealed.
You don't want corrosion on your cables or battery. Follow these instructions to clean and prevent corrosion on your battery. The corrosion may be hindering the connection of the battery post/screw and cable.
Feb 26, 2010 | 1997 Chevrolet Suburban
1997 Suburban. Turned on headlights and truck completely died
under the hood there is a fuse box with a 50 amp fuse in it this may need to be replaced
Nov 14, 2009 | 1997 Chevrolet Suburban
1994 suburban will not keep charge from battery,
Sounds like a bad altnator. if the alt. is working propperly it will run the burb. with out the battery installed. With that though, it possiably could of damaged the batt. enough to the point of replacement as well.
Jul 17, 2009 | 1994 Chevrolet Suburban
2004 suburban 1500 battery keeps going dead
CHECK FOR BATTERY DRAW,GROUND WIRE ON FRAME OF TRUCK,STARTER CAN ALSO BE DRAWING VOLTS WHY TRUCK IS STILL.HAVE THE BATTERY TESTED BY A LOAD TESTER ALSO ANY PART STORE WILL BE GLAD TO TEST IT FREE FOR HOPES OF A SALE.
May 10, 2009 | 2004 Chevrolet Suburban
PASS 2 SECURITY PROBLEMS
try this it might work, turn key to on and let set for 15 mins or so, shut key off and try to start, had this happen with passlock systems.
May 08, 2009 | 2003 Chevrolet Suburban 1500
Excalibur RS-310-EDP Remote Start Keyless Entry Dlx Map:58.50 Logo
419 people viewed this question
Top Buck Vehicle Parts & Accessories Experts
xxxxxx xxx
andy148814
Level 1 Expert
Rocguy
Are you a Buck Vehicle Part and Accessory Expert? Answer questions, earn points and help others
