Question about Whirlpool Refrigerators
I have a whirlpool refrigirator model #ER6AKXPQ02 and the door will not shut tight.The rubber gasket does not hold the door shut tight. ???
  • 159 Answers
Adjust the doors
Posted on May 15, 2009
Old whirlpool upright freezer. door left slightly ajar.light on inside. Rubber around door warm. won't seal.some things starting to thaw.shut door.should I do anything else
Seal needs to be replaced around door. Make sure magnetic strip is tight against sides of refrigerator, even if you have to cut the outside so it lays flat against the sides.
May 03, 2015 | Whirlpool Freezers
How to find out if there is a leak on the top of the freezer compartment of my whirlpool french door fridge there seems to be an icicle ?????
Most likely your freezer door or fridge door is not closing properly. Poor rubber seal (door gasket)???
Most likely moist room air gets inside through a door leak
Sep 17, 2014 | Whirlpool Refrigerators
After dishwasher fills an shuts off I get water coming out at the bottom of the door on both sides. I think it could be coming at the side ofthe door and at the top. I installed in Feb. of 2010. Could it...
The door seal could be the problem but if it leaks at the top also, I would check the latch and make sure that it is drawing the door tight against the rubber seal. Normally, if you run your finger over the seal you can find any defects in it.
Jul 27, 2011 | Whirlpool Dishwashers
Replacing door gaskets on model EF19MKXSN00
The gasket is held in place by metal strips on all 4 sides with a lot of screws. Loosen do not remove the screws and pull the gasket out from under it, Warm the new gasket in some hot water and tuck back under the retainers. Tighten the screws snug not overly tight. Use a heat gun or hair dryer to seat the new gasket and remove the wrinkles. Careful not to overheat and melt it.
Eric
Oct 21, 2009 | Whirlpool Refrigerators
Ice cube flap door
try this site...input your model # and look for the ice door parts. Maybe a bad spring. They are also very helpful with their chat and phone assist., video repair etc. Make sure to get the model # though.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Refrigerator/62-5-1414685-/Whirlpool-Refrigerator-ice-maker-overflowing-WRX735SDBM00?r=%2fShop-For-Parts%2fa4b5c21i2659d1414685%2fModel-WRX735SDBM00-Whirlpool-Refrigerator-Gasket-Seal-Door-Gasket-Parts
Best to you.
Oct 22, 2017 | GE Refrigerators
Refrigerator door gasket pulls down and brakes off on top corner
Look it over and see how it is held in place. A stripped screw or bent clamp depending on what holds it in place is the most likely suspect.
A stripped screw get a slightly bigger one or shrink the hole with tooth pics or match stick.
Bent metal strip remove and straighten possibly bending a little more in the opposite direction. And sometime 1 metal strip may be put on upside down or turned around backwards and not holding. look for similarity in the way these type of bracket/strips attach.
If this helps please rate me as high as possible.Thank you for using fixya.
Apr 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
The door leaks on my whirlpool front load model wfw8300sw03, looks like the door isnt sealing tightly, if I push on the door it stops lealing, any ideas?
you might have a bent door hinge, but most likely you have a worn door boot. its the grey rubber thing that the glass seals to.
try to lift up on the door to get the hinges back into place and if that doesnt work then you might need to replace the door boot.
look at the edge of the boot where the glass hits it. the glass must seal to the rubber and if the rubber is worn or torn then it wont seal.
not an easy piece to replace but it can be done. i wouldnt recommend trying it first as you will find it very tight to get your hands into and the clamps are hard to figure out as well.
Feb 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Black mold growing on rubber gasket and under rubber gasket in Whirlpool Duet front loading Washer
The solution? Plain old bleach.
Scrub rubber seal on door. Run the bleach through the machine once a month to keep clean.
Keep door open after each wash to ensure that it dries out properly.
d
Oct 12, 2008 | Whirlpool Washing Machines
Maytag dishwasher mdb5000awa leaking
Well did you check to see if the door seal is ripped or not on tight??? The door seal is the rubber strip that is used to seal the door shut tight, if this is wrecked in any way that might the the answer to your solution?
Dec 20, 2007 | Dishwashers
Refrigerators Logo
261 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
