Question about Samsung TXN2798HF 27" TV
I have a samsung tantus 27* hd ready tv with a dyna flat screen =
It is a little over a year old - recently during the showing of commercials the picture is wavy - this is not true when a prime program is on - but usually only during the commercials - i thought maybe it was the type of film being used - but the problem is bizarre - the picture becomes markedly wavy to the point where you cannot watch it - i have tested the cable signal but it seems to be in the tv - any suggestions - OR what do i tell a repair man if i take it in
  • Paul Bade Jun 12, 2017
    Hi dburgess005, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Is this on all channels? Have you had the opportunity to check using a different TV? The fact that only commercials are affected suggests an intentional change somewhere; perhaps the commercials are broadcast in a different format not supported by the mode to which your TV is set. It is possible that the routine for processing the commercial format is not working properly, but it's not likely. Try going into the menu and experimenting with different video formats or modes to see what they do, and take notes if one duplicates or bypasses the problem. (Usually the worst that happens is an incorrect mode crops the picture or distorts it horizontally.)
  • 35 Answers
SOURCE: Samsung DynaFlat TX-P2775H 27
Do you get any indication of power to the unit? Mine didn't.. the light next to the power button didn't come on. Turned out it was just a fuse inside the unit. So, take it in for repair and hopefully its a simple fix.
Posted on Dec 13, 2007
  • 2326 Answers
SOURCE: Samsung 52" tantus pch521r convergence panel
I found a this SITE that carries that convergence assembly for your TV.
Good Luck.
Posted on Mar 10, 2008
relectronics
  • 38 Answers
SOURCE: SAMSUNG LCD TV horizontal lines
causing of horizontal lines is leaky or defective capacitors. check big value capacitors around the board at Horizontal area. check the filter capacitor as well. good luck
Posted on Apr 20, 2008
  • 39 Answers
SOURCE: Samsung 46 DLP picture freezes and then....
common problem on samsung. bad DMD BOARD. these are modules located on light-engine. there very proud of this little jewel. usually parts cost 400-500.00 dollars for the shop. after mark-up & labor don't be shocked at 600.00-700.00 repair bill. this is of coarse for dmd replacement. 85-90%. if logic board, est. 400-500.00 repair. mch
Posted on Mar 09, 2009
  • 1779 Answers
SOURCE: Faint Vertical lines on Samsung LCD TV
Your correct, LCD's don't burn. This sounds like a defective main control module. I would take it in as soon as possible to have it looked at.
Posted on May 03, 2009
My Hyundai tv 74 cm The color it not show good
Nice big screen but CRTs are getting old So, if you can't set correct colors with your Hyundai it might have some serious issue with tube. Probably replacement might cost you more then a new new 27" Flat Panel. See some tutorial and info about bad color of CRT
Fix your own CRT Television Color Problem
How To Diagnose Bad CRT or LCD Monitor
http://www.electronicrepairguide.com/monitor-color-problem.html
LG M2762D 27 Inch Widescreen 1080p LCD TV Monitor Black
LG Electronics LG M2762D 27 FLATRON LCD TV widescreen 1080p FullHD HDTV...
RCA F27440 27 CRT TV
Samsung TXN 2798HF 27 Tantus CRT TV 1080i
Aug 02, 2015 | Televison & Video
Hitachi rear projection LCD with yellow blobs on screen
I have the same tv and the same problem, but my yellow is a cloud around the outside of the screen. My tv was recently moved, and a repair shop told me that sometimes in a move these tvs light engine takes a shock and causes a yellow "band" on the screen. I am hearing that these light engines are not cheap either. Hope this helps you.
Dec 01, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
My tv no longer shows the color red. No idea what
I have sound but my tv screen is black. Sometimes when I turn on the tv I get a picture but after 15 minutes or so the screen goes black again.
It's a 4 year old LCD.
Nov 23, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
My 32 inch samsung lcd tv has got faint black lines running down the screen ,its nearly 4 years old but i expected it to last longer than that,and ive had sky hd box recently would that have anything todo...
Are these lines on both side of the screen or what location are they in? They can be caused by watching 4:3 television with the black bars on both sides. Watching 16:9 full screen HD wont cause issues with that. If only on the sides there is not much you can do except put a pure white screen on the TV and leave that on for at least 6 hours. This will age the panel a little but in theroy wil even the pixel burn you have to make the lines less noticable. Please take a few moments to rate my answer. Thank you
Nov 18, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Screen is flashing different colors and no matter what I do, I can't get rid ot it. remote won't work, nor will menu button on top of tv. Now what?
You will need to have the Screen Control PCB replaced, however as a 27" TV it is most likely 3 or 4 years old.
It is unlikely to be cost effective to repair.
Sorry.
Sep 06, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
A horizontal line on sony 32'' LCD
This is a known defect with the lcd panel.With a little persistence to the customer support with sony they will fix the problem for free.
Apr 24, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Samsung HD tv help
Is it a Plasma Television? I recently had a customer have the same issue with a 2 year old model Samsung 50" plasma TV. In his case one Of the computer panels failed. He didn't have a service plan and the warrenty was out, so i directed him to Samsungs help line. They inturn directed him to a authorized repair center. Repairs were roughly $800. Thats a possibility but it may not be the same as your issue. Try leaving your TV running for a little while when it has the issue, and see if it eventually goes away. Some older plasma models have started to require a warm up time for the pixel cells. This has been a down fall of plasma that for the most part no longer exists on newer models.
I hope eveything works out.
Have a great day
Mar 22, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Red line fault
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Aug 07, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung TXN2798HF 27" TV Logo
107 people viewed this question
Henry  Thomas
Henry Thomas
