Question about Huffy Cycling
The brakes on my bike are sticking what are the phillip head scre
S on the calipers for? the bike is a mainstreet model#26214b 04 c it says old pair o jeans comfort tech system on the neck
    President:
  • 1,138 Answers
If you're talking about the screws where the brake arms mount on the posts and not the bolts that hold the arms to the post; they are for adjusting the springs that adjust side to side movement. With your wheel running perfectly centered in the forks and the cable adjusted so that the brake pads have enough clearance, you can use these screws to make either pad come closer to the rim . If your brake is rubbing only in one or two spots there is a chance that your wheel is not trued. In other words the screws are for side to side adjustment. Hope this helps.
Posted on May 14, 2009
2003 Suzuki VL 1500 Intruder LC REAR DISC RATTLE,HOW DO I REPLACE IT?
Hello Dale, this is an easy job on your bike. Use a flat head screw driver and remove the brake pad cover...it will pop off.
Remove the hairpin type clips off of the ends of the brake pad pins.... Use pliers & pull the brake pad pins out from the front of the rear brake caliper....Clean the rear brake caliper's piston with brake cleaner. Use a rag and wipe it clean...Reinsert the old brake pads into the caliper. Place a pry bar between the brake pads, then push the inner piston into the caliper body, this will allow room to install new pads.... Remove the old brake pads...Coat the brake pad pins and the new brake pads metal back plates with high-temperature grease.
Slip the new brake pads into the rear brake caliper, then push the brake pad pins halfway into the caliper. Slip the spring clips into place between the brake pads and the brake pad pins. Push the brake pad pins completely through the rear brake caliper. Push the hairpin clips back into the brake pad pin tips. Snap the brake pad cover onto the top of the rear brake caliper....
Pump the rear brake pedal until the pedal feels firm, indicating that the brake pads have closed around the brake rotor...No bleeding will be needed because the system was never opened - That's all there is to it...i hope this information is helpful & good luck with your bike.
Nov 22, 2011 | 2003 Suzuki VL 1500 Intruder LC
Gday, I have a 04 FXSTB Night Train, could sum1 please tell me how to change the rear brake pads. Do I have to take the wheel off to get to the pads ?? as the caliper & bracket is only 1 peice &...
Remove any saddlebags or anything that hampers your access to the rear brake caliper. Remove the two bolts that hold the caliper onto the brake caliper bracket and lift the caliper off the bracket.
The pads and all anti-rattle parts should stay on the caliper bracket. Pay particular attention to the way these parts are installed in the bracket. Replace all the old parts with new parts paying attention to how the new parts are put in the bracket. Make sure the rear pad is installed with the fiber side to the rotor, not the metal side. Don't laugh, I've seen it done more times that I care to remember.
Now, you have to get the piston compressed back into the caliper. I used either a large C-clamp or a large pair of slip joint pliers. Protect your paint and finish on your caliper by using rags or a couple pieces of wood or something. Once the piston is fully compressed into the caliper, carefully replace it back on the bracket being careful not to disturb the pads or parts. Install the two bolts and torque them to 25 foot pounds.
Now, slowly press the rear brake pedal repeatedly until you get a full firm pedal. Check the level of the brake fluid in your master cylinder. Add only the proper type of fluid called for on the top of the master cylinder cap. DO NOT MIX THE TYPE OF BRAKE FLUIDS. Check the brakes before riding the bike. Failure to insure proper brake operation prior to riding the bike can cause lose of control of the machine resulting in serious injury or death. Make sure you do this job correctly.
Jun 29, 2011 | 2002 Harley Davidson FXSTB Night Train
Neenchanging front and rear brakes on my 06 dyna custom
To change the brake pads on your bike, either front or rear, you must take the calipers off. They are held on by two bolts. Take the bolts out and take the caliper off. Replace the brake pads like the old ones came out. Then you must compress the pistons back into the caliper. I use either a large C-clamp or a large pair of slip joint pliers. Protect the paint on the calipers with rags or wood. Press the pistons all the way back into their bores on the calipers. Replace the calipers and work the brakes until you get a good firm brake. Make sure you do this job correctly as failure of the brakes can result in serious injury or death.
Good Luck
steve
Apr 24, 2011 | 2006 Harley Davidson FXDCI Dyna Super...
What is involved in changing front brake pads on an 08 Streetglide
I haven't done a brake job on a bike this new but it shouldn't be any different than any other bike. Simply take the two bolts that hold the caliper on out. Remove the old shoes. Use either a large C-clamp or a large pair of slip joint pliers and squeeze the piston back into the caliper all the way. Install the new pads and put the caliper back in place. Replace the two bolts and torque them to 25 Foot pounds. Squeeze the brake lever until you have a good firm brake.
Good Luck
Steve
Apr 02, 2011 | 2008 Harley Davidson FLHX Street Glide
JUST LOOKING FOR ANY TRICKS OR TIPS ON CHANGING FRONT BRAKES ON MY '04 FLHRSI
No trick. Simply take the two bolts out of the caliper and take it off the slider. Replace the pads and squeeze the piston back into the caliper. Use a large C-clamp or a large pair of slip joint pliers to do this. Protect the finish of the caliper with rags or pieces of wood. If your bike has dual brakes, do one side at the time.
Good Luck
Steve
Feb 18, 2011 | 2004 Harley Davidson FLHRS - FLHRSI Road...
Need harley davidson sportster 1200 1996 model free download to install rear brake pads
You must take the two bolts out that holds the caliper to the caliper bracket. Lift the caliper off the bracket and set it aside. Carefully examine the pads and the anti-rattle spring that is in the caliper bracket. Take the old parts out and install the new parts exactly like the old ones were in there. Make sure you put the fiber side of the brake pads towards the rotor.
Now, you must press the piston back into the caliper in order to get it over the new pads. I use either a large C-clamp or a pair of slip joint pliers to force the piston back into it's bore completely. Once you have this done, carefully place the caliper back over the pads and onto the bracket without disturbing the pads.
Now, slowly depress the rear brake pedal repeatedly until you get a full firm brake pedal. Do not ride the bike until you get a good brake pedal and test the brakes.
Good Luck
Steve
Jan 27, 2011 | 2006 Harley Davidson XL 1200 C Sportster...
Have 99 fxst- rear caliper will not lift off when bolts removed. I was told to remove rear wheel. can you help. thanks, CD
If you're trying to replace the pads, you shouldn't have to remove the rear wheel. Now. Sometimes Harley plays tricks on the owners and the mechanics. If it's approaching a "year change" and they run out of parts for the current year, they'll go ahead and switch to the later year model parts. In other words, your '99 model may have 2000 year model brakes on it.
Now, since I can't see the bike, all I have to go by is a few books. If this is the case, I won't know it so I'll have try something else. Look at the rear caliper. If look "inside" of the caliper you'll see the two pads. Are the two pads held in by two pins that run horizonally though the caliper halves and the pads? If so, you have the newer four piston calipers. If you've taken any bolts out of this caliper, the caliper is probably trying to split into two pieces. If this is the case, replace the bolts and tighten the well. Then, using a punch, drive the two pins out the backside of the caliper. There should be a metal piece that is an anti-rattle spring that will come out. Use a large screwdriver inserted between the rotor and the pad to gently pry the pad and the two pistons on the that side back into the caliper. Leave that screwdriver in there and use another to pry the pad and pistons on the other side back. Don't get too aggressive when doing this. The pistons move slowly just put enough pressure on the old pad so that the piston move into the caliper. If you don't do this, you will not be able to get the new pads in. Once you have the piston fully compressed into the caliper, lift the old pads out and drop the new pads in with the fiber side towards the rotor. Install the anti-rattle spring and the two pins. I would be a good idea to bleed the brakes and make sure you have a full firm pedal before you ride the bike.
If you don't see the pads or pins, you have the earlier dual piston caliper. Once you have the two bolts out, you may have to "rock" the caliper inward and outward a bit to compress the pistons back into the caliper a bit and break them loose from the pads. Once you get the caliper off, use a large C-clamp or a large pair of slip joint pliers to compress the pistons all the way into the caliper. Use some rags or thin wooden pieces to protect the paint and finish on your caliper. Remove the old pads and replace them with the fiber side towards the rotor. Put the caliper back on and tighten the bolts. Depress the rear brake pedal a few times until you get a full pedal. You may wish to bleed the brakes a bit to ensure there is no air in the system. Make sure you have a full firm pedal before you ride the bike and that the brakes work properly.
If you still cannot get the caliper off, I would suggest that you take the bike to a qualified mechanic since something else may be wrong. Brakes is THE ONE THING YOU DON'T WANT TO TAKE A CHANCE ON. If your bike quits, you pull off the road and get mad. If your brakes don't work when you need them, you get hurt or worse. If you experience anymore problems, let a qualified mechanic have a look at them.
Good Luck
Steve
Nov 21, 2010 | 2000 Harley Davidson FXST Softail Standard
How do i replace the rear brakes in my 2005 harley springer softail
Remove any saddlebags or whatever in order to get to the rear caliper. Remove the two Torx head bolts that hold the caliper into the bracket. Lift the caliper out of the bracket and lay it aside so as not to put a stress or sharp bend in the hose.
Stop and look closely at the pads and the anti-rattle hardware in the bracket. When you're sure of how it goes in, take the old stuff out and install the new.
You must get the piston depressed all the way back down into it's bore in the caliper. Use either a large C-clamp or a large pair of slip joint pliers to push the piston into it's bore. Use rags or pieces of wood to protect the finish and paint on your caliper. Once you have the piston fully seated in it's bore, carefully reposition it in the brake caliper bracket without disturbing the pads and hardware. Insert the two bolts and tighten to a torque of 18-20 foot pounds.
Slowly pump the rear brake pedal until you get a good firm pedal. Test the brakes before you ride the bike. Failure to do this job correctly can cause serious injury or death. Make sure the brakes work correctly before riding the bike.
Good Luck
Steve
Aug 08, 2010 | 2005 Harley Davidson FXSTS - FXSTSI...
How to change rear brakes on 2003 ultra classic
Take everything off the rear of the bike so you can gain access to the rear brake caliper. There are two screws that hold the brake caliper into the caliper bracket. Remove the screws. Most newer bikes have Torx head screws. Once you get the screws out, rock the caliper a bit and gently lift it up. Notice the position of the pads and the anti-rattle hardware that is in there. Some bikes have a "spirng" in there as well. Notice how it's all in there and then take it out. Replace the pads and hardware. Make sure you put the rear pad in with the fiber towards the rotor. Don't laugh, I've seen professionals put them in backwards, metal to metal.
Now, you've got to get the piston back into the bore of the caliper. I use either a large C-clamp or a large pair of slip joint pliers. Protect the paint on your caliper by wrapping it with rags or something. Compress the piston until it is all the way down into it's bore. Then, carefully put the caliper back on the bracket, insert bolts and torque them to 18-20 foot pounds.
Slowly pump the rear brake pedal until you get a full pedal. Make sure you test the brakes before you ride the bike. An improperly preformed brake job can cause serious injury or death.
Good Luck
Steve
Jul 13, 2010 | 2003 Harley Davidson FLSTC Heritage...
04 dodge ram 1500 HEMI's new brake pads won't fit
what you need to do is line clamp brake hose so you dont push dirty brake fluid back into your system..(you can use a pair of needle nose visegrips if you dont own an actual line clamp) loosen bleeder at this point, remove caliper from attatching bracket, with old pad still installed next to piston use a big C-clamp to compress piston, just make sure clamp is centered and compress slowly allowing brake fluid to escape through loosened bleeder... once compressed tighten bleeder and install caliper and pads remove lineclamp....******NOTE******* no need to bleed the system cause of lineclamp procedure... Make sure upon reassembly you use plenty of brake lube on all sliding caliper parts...Good Luck
Dec 31, 2008 | 2004 Dodge Ram 1500
Cycling Logo
364 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
