Usualy that is happened when you try to print another format , to solve that put some paper in the manualy tray.
When you receive a mail from another contry in another format : ex A4 , and your printer is set to letter , brother says no paper because the machine want to print in that format of paper.
Pay attention to the setings in printer driver in computer.
SOURCE: brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
SOURCE: I have an error message, Brother MFC-8640D Printer
NO PAPER MP
Load paper into the Multipurpose (MP) Tray There is no paper on the Multi-purpose tray. Load paper onto the Multi-purpose tray.
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/002100/000073/faq002173_005.html?reg=eu&c=eu_ot&lang=en&prod=hl3260n_all
Thanks
SOURCE: Print Brother Mfc-290c Error Print unable 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: problem paper jam printer brother no mfc-490cw
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
SOURCE: my brother mfc 465cn keeps saying paper jam. I do
The paper sensor is either stuck or dirty.
Just open it and follow the paper path and you should see where it is.
Otherwise, the sensor may be bad.
