Lid switch How do you bypass the lid switch?
There's usually a 3 (large) pins switch at the lid. unscrew it and take it off and look for the highest amperage on the switch(e.g.:220V/16A-30A rather than 220V/6A), then look for the pins combination; mine has 2-3 for the highest amperage and 1-2 for stand-by. you have to take off the switch's plug and connect the highest amperage pins (2-3). screw back the switch(without the plug).
Posted on Jun 08, 2009
Bypass LG WF-T9250PP lid switch
Before bypassing the lid switch, check whether the magnet on the lid is OK. The reed switch is under the cover adjacent to the position of the magnet when the lid is closed.
Jun 09, 2015 | LG Washing Machines
Bypass lid switch
Never ever bypass lid switch. Legal liability forever. Any future owner of machine has 2 years from the day they discover bypass to sue the crud out of you for injuries. Not worth it for cheap lid switch. Do it right. If you discover bypassed lid switch on customers machine, fix it or leave machine inoperable.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/perry_14036f9bc71cde6a
Jan 12, 2015 | Whirlpool WTW6400SW Cabrio Washer
Can you bypass a lid switch
Yes. You need to determine if the switch is normally open contact or closed contact after which you bypass it. The hard bit is probably finding a spot where you can get at the wires to by-pass the switch. If you can find this spot, remove the wired, place an ohm meter across the switch and open and close the lid a few times. I suspect you will get a reading when the lid is closed, meaning you just join the wires together to bypass the lid.
Sep 22, 2014 | Washing Machines
How do i bypass the lid lock switch on my amana top load washer
I had that problem with a top loader and wedged half of a wooden clothespin between the lid and the switch to close it. Problem solved!
Feb 18, 2013 | Amana Washing Machines
How to bypass lid lock control on kenmore elite oasis type 581 washer model 110.28032701
there isn't any way to bypass this type of lid switch as in the old 2 wire type lid switches,as the 5 wire type lid switch you have has to be connected to the control board located behind the control panel,it has to see the lid is closed and sends a magnetic signal to the control board to start the wash cycle
Oct 29, 2012 | Washing Machines
Whirlpool washer doesn't spin or empty. Could the lid switch cause both issues
Yes , you have a bad lid switch . You can bypass the lid switch , which will cause the washer to spin and drain with the lid open ( after you raise the console ) , but if you have kids in the house , it would not be adviseable to bypass .
Apr 18, 2010 | Whirlpool Washing Machines
Won't Spin
Sounds like a bad lid switch. Test my solution test by bypassing the lid switch. If the machine spins after bypassing the lid switch, replace the switch. Remember, this is a safety switch and needs to be on the machine.
Please rate this solution
Sep 06, 2009 | Whirlpool LBR4121JQ Top Load Washer
How to bypass Lid Switch Admiral Washer
The only way to bypass this switch is fist pill the plug, gain access to the switch from under the hood. put a jumper wire on the 2 wires on the switch. that will do it. I hope this helps you out.
Nov 28, 2008 | Admiral AAV7000A
Washing machine lid switch
Can you bypass the lid switch on a roper washing machine?
Oct 15, 2007 | Washing Machines
Washing Machines Logo
178 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
