Uniden 5.8GHz Dual Cordless Phone Logo
Posted on May 14, 2009
Fuzzy phone My Uniden phone is SO fuzzy. I can't even hear the person I'm talking to sometimes. How can I fix this?
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on May 15, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1225
Points
8
It sounds like the speaker has blown in the phone. you may be able to buy replacement speakers off ebay cheap. good luck
1helpful
I have a Uniden cordless phone #D2CT 6.0--I love the phone but the party on the other end of the line can barely hear me -how can I fix this or this a bad phone???
At 20 ft line of sight, you should have perfect reception with most any cordless phone.
The fuzzy signal can indicate:
1.
A weak signal between base and handset.
20 ft line of sight should have a good strong signal.
Your handset may be defective.
Or, your handset battery may be weak.
Your base unit may be defective.
2.
You may be experiencing RFI Interference.
Is the base unit next to any other electronic devices?
If it is next to a wireless router or some other wireless device, it may be overloaded by the nearby signal (even if on a different frequency)
I've got a 5 year old Panasonic 5.8 Ghz cordless phone connected to my VoIP box. I just tested it from about 25 ft away from the base unit in another room with a wall in between and my reception is perfect.
I did the same test with my Panasonic DECT 6.0 phones (1.9 GHz). The first handset is slightly fuzzy, but otherwise good signal. The 2nd handset was perfectly quiet with good strong signal. So, there is a difference between two identical handsets connected to the same base unit. This indicates to me that one handset is better tuned than the other. Nothing I can do about that but get a new 2nd extension cordless handset. Sometimes, it's just luck of the draw
2helpful
Can't hear the other side of the line. Uniden Elite
check the speaker of the phone it may damaged .welcome.
Very fuzzy phone
Sounds like the board is going bad. You may want to consider replacing it.
I hear them, but they have problems hearing me
try to get a bluetooth nd synchronize it to the phone, or a earpiece that works with the phone so the people you are calling would be able to hear you.
6helpful
2answers
I can hear but the person I am talking to cannot hear.
try cleaning the mic' without openning the phone -
from the outside by an old touth brush...
that will do the trick
if you can open the screws without any damage
than pull out the mic's cover
it is probebly full of moist
9helpful
3answers
Xbox 360 Blurry/Fuzzy Screen
The machine is overheating and the graphics chip on the main board is acting up cause of it. Make sure there is no dust or dirt blocking the air vents that would cause the system to heat up more then normal.
If that doesn't do it then maybe think about getting a cooler for the system, here is a website that talks about a few of them. Click here.
If that doesn't help then your mainboard is going bad and would need to be replaced.
I cannot hear the person or persons that I'm talking to.
first they are not a phone, they are a 2 way radio walkie talkie and will not work for telephone communication.
1helpful
2answers
Repair on problem blue dot
Good Day, flavrlen;
This is your fix it is not costly and if you handle a screwdriver you can do this in 30 minutes:
PANASONIC:
MODELS: PT-44LCX65, PT52LCX15, PT-52LCX65, PT-52LCX35, PT-61LCX65,
PT-61LCX35.
SYMPTOMS: 1. FUZZY SPOTS
2. FUZZY SPOTS
3. FUZZY SPOTS WITH STAINS
4. FUZZY SPOTS & UPSIDE DOWN
5. FUZZY SPOTS WITH LINES
CORRECTION: SYMPTOMS CAN BE CORRECTED BY EEPROM
CORRECTION TOOL; (LSUQ0100).
Good Luck, big IRISH.
2answers
Phone Freeze, Fuzzy Screen
faulty flat cable or display itself
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
