Washing machine lid switch
How do you bypass the lid switch?
  • Anonymous Mar 13, 2014
    lid switch repair
Can you bypass the lid switch on a roper washing machine?
Posted on Oct 14, 2009
  • 67 Answers
Not sure what machine tou on about,but no switches should be bypassed
Posted on Oct 16, 2007
What would happen if you accidentally spliced the green ground wire with the other wires? Will this ruin the motor?
Posted on Jan 10, 2013
AlmostBob
  • 550 Answers
SOURCE: Lid Switch for Washing Machine
pop trims from ends of control panel
remove screws from bottom of control panel under trims
slide control panel forward and up from the bottom, and flip over backwards on its hinges
undo brass clips under control panel, NOTE* how the clips are installed
unplug lid switch cable
lift cabinet slide forward and remove cabinet
turn cabinet upside down
lid switch is accessible
assemble in reverse order
Posted on Aug 29, 2008
SOURCE: washing machine lid switch
used my noggin and saved $20-00
Posted on Dec 29, 2008
SOURCE: replacing lid switch on Kenmore 80 series washing machine
It's attached under the top panel but depending on the year of manufacture it could be on the right, below a hole where the strike comes down or on the left rear under the console.
Posted on Jan 07, 2008
  • 1937 Answers
SOURCE: How do I bypass the safety switch on the door of
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
Posted on Dec 13, 2009
  • 147 Answers
SOURCE: Just got my first washing machine with a locking
YOU COUD NOT BY PASS THAT IT IS A SAFTEY SWITCH
Posted on Dec 23, 2010
Bypass LG WF-T9250PP lid switch
Before bypassing the lid switch, check whether the magnet on the lid is OK. The reed switch is under the cover adjacent to the position of the magnet when the lid is closed.
Jun 09, 2015 | LG Washing Machines
Bypass lid switch
Never ever bypass lid switch. Legal liability forever. Any future owner of machine has 2 years from the day they discover bypass to sue the crud out of you for injuries. Not worth it for cheap lid switch. Do it right. If you discover bypassed lid switch on customers machine, fix it or leave machine inoperable.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/perry_14036f9bc71cde6a
Jan 12, 2015 | Whirlpool WTW6400SW Cabrio Washer
Can you bypass a lid switch
Yes. You need to determine if the switch is normally open contact or closed contact after which you bypass it. The hard bit is probably finding a spot where you can get at the wires to by-pass the switch. If you can find this spot, remove the wired, place an ohm meter across the switch and open and close the lid a few times. I suspect you will get a reading when the lid is closed, meaning you just join the wires together to bypass the lid.
Sep 22, 2014 | Washing Machines
The small metal piece on the lid rusted and broke away so now even when the lid of the washing machine is closed, the machine won't start because ti can't detect the lid as closed. What can I do?
You can bypass the switch by jambing something in there and this will allow it to spin with the lid open or closed but please keep the lid closed at all times while washing.
Oct 31, 2009 | Washing Machines
Won't Spin
Sounds like a bad lid switch. Test my solution test by bypassing the lid switch. If the machine spins after bypassing the lid switch, replace the switch. Remember, this is a safety switch and needs to be on the machine.
Please rate this solution
Sep 06, 2009 | Whirlpool LBR4121JQ Top Load Washer
Fault with draining washing machine
hi,
verify lid switch function first. you can bypass lid switch with jumper wire. unit will not spin out if lid is open. if switch goes bad it thinks lid is open when it is actually closed
Jul 05, 2009 | Washing Machines
Water in machine not advancing to spin? What is wrong and what can I as an end user fix?
My washing machine did this and I found that the lid switch had gone out. I bypassed it and keep out of it when it is spinning. You could do this yourself but it is a safety issue and if you have children around may not be a good idea. When you raise the lid look for a plastic piece on the lid that is inserted into the machine when you close the lid. As soon as you locate the actual switch (unplug machine from the power source) remove he two wires from the switch and tie them together. However, machine will run through all cycles even with the lid open. My Whirlpool washer has been running for 21 years. I bypassed the lid switch about 5 years ago.
Jul 02, 2009 | Washing Machines
Washing machine stops after washing does not rinse and spin
Jun 24, 2009 | Washing Machines
How to bypass Lid Switch Admiral Washer
The only way to bypass this switch is fist pill the plug, gain access to the switch from under the hood. put a jumper wire on the 2 wires on the switch. that will do it. I hope this helps you out.
Nov 28, 2008 | Admiral AAV7000A
Open Questions:
Washing Machines Logo
2,810 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
