Question about John Deere Garden
Parking Brake Lever (Orange Plastic Lever on left side) is stuck
Usually this parking brake lever slides up or down depending on the actual position of the brake pedal meaning ... you can lock the brake pedal in position whenever you stop (park) for whatever reason so the lawn mower will not roll.  When you want to continue to mow or simply ride, you make sure the brake pedal is depressed and move this orang parking brake level to an off position and off you go on your merry way.  Currently this lever does not move up or down.  I've looked in the compartment to see a single metal rod that goes down into an enclosed area where I can't see the full details.  I can use the lawn mower, but can't "park" it in a safe condition ... menaing, it can still roll if not on level surface.  I have the operator's manual, but no exploded parts catalog or view to determine how this orange parking brake lever interacts/interfaces with the actual brake mechanism.  Any ideas what I should do next?  Is there some sort of cable involved here that has ound up?  I couldn't see anything, as I said.  I guess I need to build some sort of a ramp mechanism so I can get it up high enough to see fully from beneath it.
I hope I make sense here.
Thanks in advance for any suggestions.
Bo Dirigo
The parking break is associated with your foot break. Depress the foot break ALL THE WAY down, then you will find that your parking break can be pulled all the way up.
Posted on Apr 26, 2010
Chevy Aveo5 2008 automatic trans - how do I remove the parking brake lever?
Chevrolet Aveo Would not Shift out of Park - Sensor Glitch
sensorglitch.livejournal.com/91859.html
Nov 17, 2009 - Tags, ', aveo, brake light, chevrolet, chevy, gear, park, parking, shift, ]... believe it or not all I had to do was replace the brake switch (a cheap $5 part). ... Theautomatic transaxle shift lever may not shift out of the park position ...
Service Manual2007 Aveo PARKING BRAKEwww.autocats.ws/manual/chevrolet/tis0911/.../Aveo/.../9T2_4G0.EN.htm...Remove the complete parking brake lever assembly and the cable from the assemblyby unfastening the parking brake lever-to-vehicle underbody bolts and ...Missing: 2008How to disconnect the parking brake cable on a Chevy ...? 2:05https://www.youtube.com/watch?v=FxAQMbcHAnQApr 22, 2013 - Uploaded by Josh BruniVehicle Tips: How to disconnect the parking brake cable on aChevy .... How to replace rear brakes and rotors on a 2008 Buick Lucerne ...
Jan 05, 2016 | Cars & Trucks
Hummer H3 airbag light wont go off
Airbag light on in a Hummer H3 Dashboard???Here is the fix...
Start the engine of your car, set the parking brake, hold the regular brake pedal down with your right foot. Push down the parking brakepedal to its fully-applied position with your left foot. Now while you are still holding the regular brake pedal down. Quickly release the parking brake, Pull the bottom edge of the lever, located above the parking brake pedal, with the parking brake
symbol, directly rearward to release the parking brake. Make sure pedal snaps hard all the way back releasing the parking brake... If this doesn't work the first try, try it 3-5 times and it shall work... The airbag light will go off...
NOTE: The parking brake pedal is located to the left of the regular brake pedal, near the driver's door.
The parking brake lever is located above the parking brake pedal, with the parking brake symbol.
May 28, 2012 | 2006 Hummer H3
Parking brake wont stay engaged on 2000 s10
Do you mean that the parking brake works when you press the pedal down but the pedal does not STAY down? If this is the case, you should look at the parking brake mechanism to make sure that the lever that releases the brake is not stuck (the release cable attaches to it - SEE PICTURE BELOW). You will have to remove the lower dash cover to do this. Sometimes the lever gets stuck in the "relaese" position when you pull the cable. Some spray lithium grease usually works well in getting it working again.
If the lever is not sticking, then the ratchet mechanism is dammaged and the pedal assembly will have to be replaced. The assembly is only attached to the vehicle with 3 bolts. It can be a little tricky getting the main cable disconnected fronm the old pedal assembly and connected to the new pedal assembly, but other than that it is not hard to change.
Oct 14, 2011 | 2000 Chevrolet S-10
Instructions and diagram,to remove and replace rear drum brakes
1984 Ford Tempo - Rear Drum brake drum/shoes
REMOVAL & INSTALLATION
See Figures below instructions
1. Raise and safely support the vehicle with jackstands.
2. Remove the wheel, tire, hub and finally, the drum assembly.
3. Using a spring removal tool, remove the horizontal securing spring at the top first of the assembly.
4. Pull the adjuster locking plate away from the shoes.
5. Remove the lower horizontal securing spring.
6. Unfasten one of the 2 shoe hold-down springs and remove the pin.
7. Remove the brake adjuster.
8. Remove the remaining hold down spring and clip.
9. Lift the brake shoes assembly off the backing plate and wheel cylinder assembly. Be careful not to bend adjusting lever during the removal process.
10. Remove the parking brake cable from the parking brake lever.
11. Remove the horseshoe retaining clip and spring washer and slide the lever off the parking brake lever pin on the trailing shoe.
To install:
12. Apply a light coating of high temperature grease at the points where the brake shoes contact the backing plate.
13. Apply a light coating of lubricant to the adjuster screw threads and the socket end of the adjusting screw. Turn the adjusting screw into the adjusting pivot nut to the limit of the threads and then back-off 1 / 2 turn.
14. Assemble the parking brake lever to the trailing shoe by installing the spring washer and a new horseshoe retaining clip. Crimp the clip until it retains the lever to the shoe securely.
15. Attach the parking brake cable to the parking brake lever.
16. Attach the lower retracting spring to the leading and trailing shoe assemblies and install to backing plate. It will be necessary to stretch the retracting spring as the shoes are installed downward over the anchor plate to inside of shoe retaining plate.
17. Install the adjuster screw assembly between the leading shoe slot and the slot in the trailing shoe and parking brake lever. The adjuster socket end slot must fit into the trailing shoe and parking brake lever.
The adjuster socket blade is marked R or L for the right or left brake assemblies. The R or L adjuster blade must be installed with the letter R or L in the upright position, facing the wheel cylinder, on the correct side to ensure that the deeper of the 2 slots in the adjuster sockets fits into the parking brake lever.
18. Assemble the adjuster lever in the groove located in the parking brake lever pin and into the slot of the adjuster socket that fits into the trailing shoe web.
19. Attach the upper retracting spring to the leading shoe slot. Using a suitable spring tool, stretch the other end of the spring into the notch on the adjuster lever. If the adjuster lever does not contact the star wheel after installing the spring, it is possible that the adjuster socket is installed incorrectly.
20. Inspect your work to make sure it is correct.
21. Install the hub/drum and wheel/tire assemblies and adjust the wheel bearings.
22. Lower the vehicle and check brake operation.
Fig.1 Exploded View of Rear Brakes - 1984 Ford Tempo
Fig 2. Remove the brake shoe upper retaining spring with a suitable removal tool.
Fig.3 Removed retaining spring - note spring direction.
Fig.4 Remove the adjuster lock plate. Note the direction of the tab.
Fig.5 Remove the lower retaining spring.
Fig.6 Remove the Hold Down Spring - note brake spring tool used.
Fig.7 remove the shoe adjuster. Note direction of the adjuster spline.
Fig.8 Remove the hand brake cable.
Fig.9 Remove the final brake shoe.
Fig.10 All removed parts in order and properly oriented for re-assembly.
Apr 17, 2011 | 1984 Ford Tempo
Remove replace rear brakes on ford t bird 1996
1989-97 Vehicles Drum Brakes (Let me know if you need the Disc Brake Instructions)
  1. Raise and safely support the vehicle.
  2. Remove the rear wheel and tire assemblies, then remove the brake drum.
    Fig. 4: View of the drum brake assembly with the drum removed
    Fig. 5: Use a commercially available brake spray to clean the
    components before removal
  3. Install Brake Cylinder Clamp D81L-1103-B or equivalent, over the ends of the
    rear wheel cylinder.
  4. Disconnect the parking brake cable from the parking brake lever.
    Fig. 6: Detach the parking brake cable and conduit from the
    parking brake lever
  5. Remove the 2 brake shoe hold-down retainers, springs and pins.
  6. Spread the brake shoes over the piston shoe guide slots. Lift the brake
    shoes, springs and adjuster off the backing plate as an assembly. Be careful not
    to bend the adjusting lever.
    Fig. 7: Lift the brake shoes, springs and adjuster off the
  7. Remove the adjuster spring. To separate the shoes, remove the retracting
    springs.
  8. Remove the parking brake lever retaining clip and spring washer. Remove the
    lever from the pin.
    Fig. 8: Drum brake components - 1995 vehicle shown
    Fig. 9: Exploded view of the drum brake components, removed
    from the vehicle
    To install:
  9. Apply a light coating of caliper slide grease to the backing plate brake
    shoe contact areas.
  10. Apply a light coat of lubricant to the threaded areas of the adjuster screw
    and socket. Assemble the brake adjuster with the stainless steel washer. Turn
    the socket all the way down on the screw, then back off 1?2 turn.
  11. Install the parking brake lever to the trailing shoe with the spring washer
    and a new retaining clip. Crimp the clip to securely retain the lever.
  12. Position the trailing shoe on the backing plate and attach the parking brake
    cable. Position the leading shoe on the backing plate and attach the lower
    retracting spring to the brake shoes.
  13. Install the adjuster assembly to the slots in the brake shoes. The socket
    end must fit into the wider slot in the leading shoe. The slot in the adjuster
    nut must fit into the slots in the trailing shoe and parking brake lever.
    Fig. 10: Install the adjuster assembly in the slots in the
    brake shoes
  14. Install the adjuster lever on the pin on the leading shoe and to the slot in
    the adjuster socket.
  15. Install the upper retracting spring in the slot on the trailing shoe and the
    slot in the adjuster lever. The adjuster lever should contact the star and
    adjuster assembly.
  16. Install the brake shoe anchor pins, springs and retainers. Remove the brake
    cylinder clamp tool
  17. Install the brake drum, wheel and tire assemblies and lower the vehicle.
  18. Apply the brakes several times while backing up the vehicle. After each
    stop, the vehicle must be moved forward.
Oct 07, 2010 | 1996 Ford Thunderbird LX
How to installing brake shoes on back ?
First you have to compress the parking brake cable spring and attach the parking brake lever.
Clean and lubricate the brake backing plate.
Use silicon Brake Caliper Grease and Dielectric Compound.
Then,
install the rear brake shoes and linings:
1) position the rear brake shoes and linings
2) position the parking brake lever
3) install the brake shoe hold-down spring pins and the brake shoe hold-down springs.
Install the parking brake strut
1. install the parkig brake link spring on the parking brake strut
2. install the parking brake strut
3. Install the brake shoe anchor ping guide plate.
Install the short brake shoe retracting spring
1. Place the brake shoe adjusting lever cable over the anchor pin, with crimped side in
2. Install the short brake shoe retracting spring
Note: Make sure the brake shoe adjusting lever cable is positioned in the cable guide groove
Install the long brake shoe retracting
1. install the cable guide
2. position the brake shoe adjusting lever cable in the cable guide groove
3. install the long brake shoe retracting spring
Note: to prevent incorrect installation, teh socket of each brake adjuster screw is stamped R or L
Assemble the brake adjuster screw assembly.
1. apply silicone brake caliper grease and dielectric compound
2. install the brake adjuster screw into the brake show adjusting screw nut to the end of the threads and then loosen one half turn
3. install the brake shoe adjusting screw socket on the brake shoe adjusting screw nut.
Install the brake adjuster screw assembly
1. Position the brake adjuster screw assembly
2. Install the brake shoe adjusting screw spring
3. Position the brake shoe adjusting lever cable
4. Position the adjusting lever return spring and the brake shoe adjusting lever
5. Hook the brake shoe adjusting lever cable to the brake shoe adjusting lever.
Test the operation of the automatic self-adjuster
1. Pull the brake shoe adjusting lever cable and check that the brake shoe adjusting lever rotates the brake shoe adjuster assembly
2. Release the brake shoe adjusting lever cable and check that the brake shoe adjusting lever advances to the next notch on the brake shoe adjusting screw nut.
Adjust the brakes.
Install the brake drum.
Thats it
Sep 10, 2010 | 1998 Ford Ranger SuperCab
Picture or directions for repairing rear drum brake
Brake Shoes Removal & Installation Duo-Servo Type To Remove:
  1. Raise the vehicle and support it safely.
  2. Remove the tire and wheel assembly.
  3. Remove the brake drums.
  4. Using a brake tool, remove the shoe return springs.
  5. Remove the shoe guide.
  6. Remove the hold-down springs and pins.
  7. Remove the actuator lever and pivot.
  8. Remove the lever return spring.
  9. Remove the actuator link, parking brake strut, spring retaining ring.
  10. Remove the parking brake lever and washer.
  11. Remove the shoe assemblies.
  12. Remove the adjuster screw and spring from the shoe assembly.
To Install:
  1. Use brake cleaning fluid to remove dirt from the brake drum. Check the drums for scoring, cracks and for out-of-round; service the drums as necessary.
  2. Check the wheel cylinders by carefully pulling the lower edges of the wheel cylinder boots away from the cylinders. If there is excessive leakage, the inside of the cylinder will drip fluid; repair or replace as necessary.
  3. Check the flange plate, which is located around the axle, for leakage of differential lubricant.
  4. Lightly lubricate the parking brake cable, parking brake lever where it enters the shoe and the backing plate-to-shoe contact points. Use high temperature, waterproof, grease or special brake lube.
  5. Install the parking brake lever into the secondary shoe with the attaching bolt, spring washer, lockwasher, and nut. It is important that the lever move freely before the shoe is attached. Move the assembly and check for proper action.
  6. Lubricate the adjusting screw and make sure it works freely.
  7. Connect the adjuster screw and spring to the bottom portion of both shoes. Ensure the spring does not interfere with the adjuster rotation when installed. The primary (smaller shoe pad area) to the front and secondary shoe (larger shoe pad area) to the rear of the vehicle.
  8. Install the shoe assembly. Ensuring the shoe webs are positioned correctly against the wheel cylinder.
  9. Install the parking brake cable.
  10. Secure the primary shoes with the hold-down pin and spring.
  11. Install the parking brake strut and the strut spring.
  12. Install the actuator lever and pivot, securing the assembly with the hold-down pin and spring. Install the actuator link and spring.
  13. Install the return springs.
  14. Check the operation of the self-adjusting mechanism by moving the actuating lever by hand.
  15. Adjust the brakes and install the drum.
  16. Adjust the parking brake.
  17. Install the tire and wheel assembly.
  18. Lower the vehicle.
Leading-Trailing Type To Remove:
  4. Raise the lever arm of the actuator until the upper end is clear of the slot in the adjuster screw.
  5. Slide the actuator off the adjuster pin. Disconnect the actuator spring from the shoe.
  6. Remove the hold-down spring assemblies and pins.
  7. Pull the bottom ends of the shoes apart and lift the lower return spring over the anchor plate. Allow the shoe ends to come together and remove the spring.
  8. Remove the shoe assembly, along with the upper return spring and the adjusting screw assembly.
  9. Remove the upper return spring and the adjusting screw assembly from the shoes.
  10. Remove the retaining ring, pin, spring washer, and parking brake lever.
Typical rear drum brake assembly (Leading/Trailing type) 93026g52.gif
To Install:
  1. Clean adjuster wheel and the backing plates with a suitable cleaner. Lubricate the backing plate contact points, levers and adjuster with a suitable lubricant.
  2. Assemble the parking lever, spring washer (concave side facing the brake lever), pin, and retaining ring onto the rearward shoe.
  3. Install the adjuster pin in the forward shoe with the pin projecting 0.276 in. (7mm) from the side of the shoe web where the adjuster actuator is installed.
  4. With the brake shoes resting on a flat surface (the shoe with the parking lever to the rear of the vehicle), install the upper return spring.
  5. Install the adjuster screw assembly with the spring clip facing the backing plate.
  6. Place the shoes in position on the backing plate. Do not place the lower shoe webs under the anchor plate.
  7. Install the lower return spring, spread the bottom of the shoes and position the shoe against the backing plate.
  8. Install the hold-down pins and spring assemblies.
  9. Install the adjuster actuator over the end of the adjuster pin so the top leg engages the notch in the adjuster screw.
  10. Install the actuator spring, being careful not to over-stretch it more than 3.27 in. (83mm).
  11. Install the parking brake cable to the lever.
  12. Adjust the parking brake if the shoes will not totally retract.
  13. Install the drum, tire and wheel assembly. Adjust the rear brakes and lower the vehicle.
Aug 17, 2010 | 1999 Chevrolet Suburban
1997 Ford contour rear brake shoe replacment help.
Brake shoe removel:
Depress and turn the retainers for the hold-down springs and pins to remove them from each shoe. Slide the brake shoe assembly--including the shoes and springs--down so you can disengage the top ends of the shoes from the cylinder and tilt them to lift them past the retaining plate.
Unhook the lower retracting spring from the front brake shoe to disconnect it. Spread the shoes apart at the bottom to remove the adjusting screw, the screw's retracting spring and the adjuster lever. Remove the front brake shoe.
Pull the parking brake cable spring back with diagonal cutting pliers, grip the cable with the pliers without cutting it, unhook the cable from the parking brake lever and remove the rear brake shoe with the lever.
Disconnect the parking brake lever from the rear shoe by spreading the retaining clip with a screwdriver and removing the clip and its spring washer.
  • Step 4 Pull the parking brake cable spring back with diagonal cutting pliers, grip the cable with the pliers without cutting it, unhook the cable from the parking brake lever and remove the rear brake shoe with the lever.
  • Step 5 Disconnect the parking brake lever from the rear shoe by spreading the retaining clip with a screwdriver and removing the clip and its spring washer.
  • Read more: How to Change Rear Brakes on a 1997 Ford Taurus | eHow.com http://www.ehow.com/how_6123373_change-brakes-1997-ford-taurus.html#ixzz0u2xgUqun
  • Step 3 Unhook the lower retracting spring from the front brake shoe to disconnect it. Spread the shoes apart at the bottom to remove the adjusting screw, the screw's retracting spring and the adjuster lever. Remove the front brake shoe.
  • Read more: How to Change Rear Brakes on a 1997 Ford Taurus | eHow.com http://www.ehow.com/how_6123373_change-brakes-1997-ford-taurus.html#ixzz0u2xdByQ8
  • Step 2 Slide the brake shoe assembly--including the shoes and springs--down so you can disengage the top ends of the shoes from the cylinder and tilt them to lift them past the retaining plate.
  • Read more: How to Change Rear Brakes on a 1997 Ford Taurus | eHow.com http://www.ehow.com/how_6123373_change-brakes-1997-ford-taurus.html#ixzz0u2xVyUAt
    Jul 17, 2010 | 1995 Ford Contour
    I need a schematic for the rear brakes on an F150 super cab with 4.6L automatic trans 4wheel drive
    Drum, Rear Brake System Standard Rear Brake
    Item Part Number Description 1 2069 Brake Shoe Hold-Down Spring Pin 2 — Rear Wheel Cylinder Retaining Bolt (2 Req'd) 3 — Washer (2 Req'd) 4 — Anchor Pin (Part of 2211) 5 — Wheel Cylinder 6 2028 Brake Shoe Anchor Pin Guide Plate 7 2A637 Parking Brake Lever 8 2296 Brake Shoe Retracting Spring (Short) 9 2296 Brake Shoe Retracting Spring (Long) 10 2200 Rear Brake Shoe and Lining (Secondary) 11 — Washer 12 2106 Parking Brake Lever Pin Retainer 13 — Brake Shoe Adjusting Lever Cable Guide 14 2A642 Primary Brake Shoe Parking Brake Lever Link 15 2A601 Parking Brake Link Spring 16 2068 Brake Shoe Hold-Down Spring 17 2A176 Brake Shoe Adjusting Lever 18 2048 Brake Shoe Adjusting Screw Socket 19 2047 Brake Shoe Adjusting Screw Nut 20 2041 Brake Adjusting Screw 21 2049 Brake Shoe Adjusting Screw Spring 22 2200 Rear Brake Shoe and Lining (Primary) 23 2A178 Brake Shoe Adjusting Lever Cable 24 2211 Brake Backing Plate
    Heavy Duty Rear Brake
    Item Part Number Description 1 — Rear Wheel Cylinder Retaining Bolt 2 00538 Lock Nut 3 2212 Rear Brake Backing Plate 4 2262 Rear Wheel Cylinder 5 2A642 Primary Brake Shoe Parking Brake Lever Link 6 2A601 Parking Brake Link Spring 7 2A637 Parking Brake Lever 8 2106 Parking Brake Lever Pin Retainer 9 — Parking Brake Lever Bolt 10 — Secondary Shoe Assembly 11 2A179 Brake Shoe Adjusting Lever Cable Guide 12 2068 Brake Shoe Hold-Down Spring 13 — Adjusting Lever Pin 14 — Adjusting Lever Return Spring 15 2A176 Brake Shoe Adjusting Lever 16 2047 Brake Shoe Adjusting Screw Nut 17 2049 Brake Shoe Adjusting Screw Spring 18 2041 Brake Adjuster Screw 19 — Primary Shoe Assembly 20 2068 Brake Shoe Hold-Down Spring 21 2200 Rear Brake Shoe and Lining 22 2035 Brake Shoe Retracting Spring 23 2A178 Brake Shoe Adjusting Lever Cable 24 2092 Brake Adjusting Hole Cover 25 2069 Brake Shoe Hold-Down Spring Pin
    The rear drum brakes:
    • Have internal shoes that expand against the brake drum (1126).
    • Are a single-anchor type.
    • Are actuated by one rear wheel cylinder (2262).
    • Have two pistons in the rear wheel cylinder (2261). One exerts force against the upper end of the primary shoe; the other exerts force against the upper end of the secondary shoe.
    • Adjust rear brake shoes and linings (2200) automatically.
    • Need manual brake adjustment if the adjusters are not operating properly or after the rear brake shoes and linings have been replaced.
    When the brake pedal is applied, hydraulic fluid pressure forces the pistons in the rear wheel cylinder outward, moving the rear brake shoes and linings against the brake drum.
    The rear drum brake system includes the parking brake mechanism. Refer to Section 206-05 .
    Apr 04, 2009 | 1997 Ford F150 Regular Cab
    How to install rear brakeshoes
    If you are not thoroughly familiar with the procedures involved in brake replacement, only disassemble and assemble one side at a time, leaving the other wheel intact as a reference.
    1983-88 Vehicles
    See Figures 1, 2 and 3
    1. Raise and safely support the rear of the vehicle with jackstands.
    3. Remove the brake drum, as outlined earlier in this section.
    4. Place Brake Cylinder Clamp D81L-1103-B or equivalent, over the ends of the brake cylinder.
    CAUTIONBe careful that the springs do not slip off the tool during removal, as they could cause personal injury.
    1. Remove the shoe-to-anchor springs, using Brake Shoe R and R Spring BT-11, or equivalent, then unhook the cable eye from the anchor pin.
    0900c1528006be0f.jpgFig. 1: Place the brake clamp tool over the ends of the wheel cylinder, then remove the shoe-to-anchor springs using the correct tool
    1. Remove the shoe guide (anchor pin) plate.
    2. Remove the shoe hold-down springs, shoes, adjusting screws, pivot nut, socket and automatic adjustment parts.
    3. Remove the parking brake link, spring and retainer. Disconnect the parking brake cable from the parking brake lever.
    4. After removing the secondary brake shoe, disassembly the parking brake lever from the shoe by removing the retaining clip and spring washer.
    0900c1528006be10.jpgFig. 2: View of the drum brake components-1983-88 9-inch brake shown 0900c1528006be11.jpgFig. 3: View of the drum brake components-1983-88 10-inch brake shownTo install:
    1. The brake cable must be connected to the secondary brake shoe before the shoe is installed on the backing plate. To do this, first transfer the parking brake lever from the old secondary shoe to the new one. This is accomplished by spreading the bottom of the horseshoe clip and disengaging the lever. Position the lever on the new secondary shoe and install the spring washer and the horseshoe clip. Close the bottom of the clip after installing it. Grasp the metal tip of the parking brake cable with a pair of pliers. Position a pair of side cutter pliers on the end of the cable coil spring, and using the plier as a fulcrum, pull the coil spring back with the side cutters. Position the cable in the parking brake lever.
    2. Apply a light coating of high temperature grease to the brake shoe contact points on the backing plate. Position the primary brake shoe on the front of the backing plate and install the hold-down spring and washer over the mounting pin. Install the secondary shoe on the rear of the backing plate.
    3. Install the parking brake link between the notch in the primary brake shoe and the notch in the parking brake lever.
    4. Install the automatic adjuster cable loop end on the anchor pin. Make sure the crimped side of the loop faces the backing plate.
    5. Install the return spring in the primary brake shoe and, using the tapered end of the brake spring service tool, slide the top of the spring onto the anchor pin.
    CAUTIONBe careful to make sure that the spring does not slip off the tool during installation, as it could cause injury.
    1. Install the automatic adjuster cable guide in the secondary brake shoe, making sure the flared hole in the cable guide is inside the hole in the brake shoe. Fit the cable into the groove in the top of the cable guide.
    2. Install the secondary shoe return spring through the hole in the cable guide and the brake shoe. Using the brake spring tool, slide the top of the spring onto the anchor pin.
    3. Clean the threads on the adjusting screw and apply a light coating of high temperature grease to the threads. Screw the adjuster closed, then open it 1/2 turn.
    4. Install the adjusting screw between the brake shoes with the star wheel nearest to the secondary shoe. Make sure the star wheel is in a position that is accessible from the adjusting slot in the backing plate.
    5. Install the short hooked end of the automatic adjuster spring in the proper hole in the primary brake shoe.
    6. Connect the hooked end of the automatic adjuster cable and the free end of the automatic adjuster spring in the slot in the top of the automatic adjuster lever.
    7. Pull the automatic adjuster lever (the lever will pull the cable and spring with it) downward and to the left and engage the pivot hook of the lever in the hole in the secondary brake shoe.
    8. Check the entire brake assembly to make sure that everything is installed properly. Make sure that the shoes engage the wheel cylinder properly and are flush on the anchor pin. Make sure that the automatic adjuster cable is flush on the anchor pin and in the slot on the back of the cable guide. Make sure that the adjusting lever rests on the adjusting screw star wheel. Pull upward on the adjusting cable until the adjusting lever is free of the star wheel, then release the cable. The adjusting lever should snap back into place on the adjusting screw star wheel and turn the wheel one tooth.
    9. Expand the brake adjusting screw until the brake drum will just fit over the brake shoes.
    10. Install the brake drum and wheel and tire assembly, then adjust the brakes.
    11. Carefully lower the vehicle.
    Dec 08, 2008 | 1987 Ford Thunderbird
    Garden Logo
    713 people viewed this question
    Top John Deere Garden Experts
    Phil Walker
    Phil Walker
    Tim Whalen
    Wayne Fellows
    Wayne Fellows
    Are you a John Deere Garden Expert? Answer questions, earn points and help others
