Question about Ricoh Aficio CL3500N Laser Printer
Color regist error code pages are faded. When printing in color, streaks throughout. Is this the drum?
Streaks or lines
Vertical streaks:
Check,which color/s streaks are appearing on print out,remove that cartridge/s check on drum surface for streaks.. if found replace that cartridge/s..check.
Horizontal streaks:
This problem appears when the cartridge/s image drum not rotating properly. Resit the cartridges properly, print 20nos of blank pages, then check.... replace the cartridge..
Dec 29, 2012 | HP Color LaserJet 2600n Printer
Center
Just remove all the removable parts from your printer including trays, toners, etc.
Shake your print toners so that the toner powder inside is mixed well equally throughout the drum inside.
Replace all the parts back and try printing and may be this should work fine for you.
Please provide back your ratings.
Thanks
Apr 05, 2010 | HP LaserJet 4700 Printer
While printing in black middle of page fades out both sides of the page print well. this is about a 1 inch fade out in middle of page.
Replace the drum of the particlular color cartridges. To know which color you have to print in single color one by one. If problem persist then replace transfer belt .
Jan 05, 2010 | Samsung CLP 300 Laser Printer
Color streaks on page
Had a similar problem. Tried lost of things. In my case, the streaks cleared up after I cleaned the toner drum.
Aug 25, 2009 | Brother MFC-9420CN All-In-One Laser...
I have fading on the right hand side. Printer Dell 3100CN
Dell printers are junk. But you have put a lot of money into this thing. Check the alignment of the black drum, could be that something is keeping if off track a little bit.
May 26, 2009 | Dell 3100cn Laser Printer
I just picked up a 4500n hp laserjet, and it was very dusty inside and out. So I cleaned it inside and out very thourougly. I plugged it in and print the configuration page, the plc, ps fonts, demo page 1...
Most likely the drum is failing. After printing pages remove the drum and see if it has streak on it to be sure (don't bother trying to clean it - if it has streaks the cleaning mechanism has failed)
Mar 22, 2009 | HP Color LaserJet 4500n Printer
Magicolor 2400W print fades on right side of page
Have you tried cleaning the leans at the bottom of the printer? Open the cover, pull out the drum. Under it is a long, narrow piece of glass. If it gets dusty or toner accumulates on it, it will cause streaks in the printing. If this is dirty, take a clean, soft cloth and very gently wipe it off.
May 12, 2008 | Konica Minolta magicolor 2400 Laser...
Ricoh Aficio CL 2000N printing problems
If the colors are good and solid with no fades, only black streaks, then black is the culprit. I suggest replacing the black cartridge.
Feb 20, 2008 | Ricoh Aficio CL2000N Laser Printer
Streaks on left side
REPLACE DRUM CARTRIDGE THE CLEANER BLADE IS BAD
Jan 20, 2008 | Dell 3100cn Laser Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Ricoh Aficio CL3500N Laser Printer Logo
201 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
