Question about Kenmore 24812
Kenmore washing machine 110.24812200 only filling water up but not working after that. no washing, no draining, no spin.
  • 5,911 Answers
The washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. Just use your model number as your search criteria. All three sites offer competitive pricing, so shop all three for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If you still have questions, please let me know.
Posted on May 14, 2009
    Problem Solver:
  • 6 Answers
  1. if this is a dishwasher. in the front of it all the way in the bottom there r 4 schrus remove them and look in front of you u will see the motor use a flash light tern on the dishwasher if the motor dont sp[ing tern it off and with a screwdrivers spin it. it will feel Taite its ok it will get loos then tern on it will work fin.
  2. If it is a washing maching use a flat hed screwdriver ther too clips one on the L and one on the R of the front of the washer stick flat Head there to open one's open on the left hand side u will see a clear hose fa low it down u can pull it out and it will look black the tub gets dirty stick a wier or mettle hanger to cling it . if you tern it on and blow in it you will see and here it chang ok that is it
vest6
  • 196 Answers
SOURCE: kenmore top load (model # 110 82370120) drain problem
Could you please rephrase the question. I'm not sure if I'm understanding this correctly
Posted on Jan 02, 2008
appldoctom
  • 311 Answers
SOURCE: KENMORE WASHING MACHINE MODEL#110. 254872300 WONT SPIN
if your sure it will agitate?[because the pump is on the other side of the motor and will drain,but if coupler broken ,wont agitate or spin although it makes noise like its working.so if will truely agitate drive coupler fine and its going to be the clutch or that area unless somthing[clothing] is between the two tubs creating anough resistance to stop the tub from taking off.clutch pads will just slip on drive plate.hope that helps>God bless ,tom
Posted on Jan 04, 2009
  • 3 Answers
SOURCE: Kenmore Washing machine model 110-26422300 no spin
look at the belt
Posted on Feb 21, 2009
  • 5 Answers
SOURCE: the washer will not drain or spin
more than likely the pump needs replacing, first of all remove the outlet drain hose from the the place it discharges and lower it into a bucket,this should allow it to syphon away,you may need to empyt the bucket a few times once the machine is empty you should be able to put it on its spin cycle once it has spun locate and remove the filter to remove any objects or lint, fill machine with warm water and try to drain and spin via the programme,if this do not work fit a new pump
Posted on May 29, 2009
jumptrout51
  • 3361 Answers
SOURCE: kenmore 80 series washing machine - won't stop
Your air pressure tube going to the water level switch is pinched or stopped up,OR, the water level switch is going bad.
Use this manual to access these parts and diagnose which is bad.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb?OpenDocument
Posted on Jan 16, 2010
My washer filled up with water, - the filling part works. however, it won't agitate or drain.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 23, 2010 | Kenmore Dryers
Kenmore topload washing machine that wont switch to drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Then, see the Whirlpool / Kenmore Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Normally, this would appear to be a Lid Switch or Neutral Drain problem BUT since it is re-filling , it sounds like a Timer problem.
See the Service Manual for how to test / replace the timer.
Apr 16, 2010 | Kenmore Washing Machines
Kenmore washer fills with water
You may have a bad lid switch. Need the model to check for you. Thanks
Dec 01, 2009 | Kenmore Washing Machines
Washer fill or drain but does not spin
It's not supposed to spin during water fill and draining, if I understand your post.
Charlie
Aug 23, 2009 | Kenmore 44102 Front Load Washer
The washer will not drain or spin
May 29, 2009 | Kenmore Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer model 110.49722990 it will not go into the drain or spin part of the cycle, just sits there and hums, won't do anything. It will fill with water and wash,but thats all it won't finish the...
Does it fill with "cold" water?Will it spin?Drain?If the machine will fill up with cold water,will the timer advance by itself to finish?Or if you place the timer in spin cycle will it spin?First off if your not getting "Cold" water to fill inside :Replace the water valve (because when the timer stops after the agitation cycle it wont advance because it cant fill up with cold water.
May 23, 2008 | Kenmore Washing Machines
Kenmore 24812 Logo
300 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
