Question about Hayward 36 Sq Ft Pro Grid Vertical Grid De Pool Filter
I took my filter apart so that i could clean each grid individually and now i cna't seem to get the put back together correctly. i have been looking for a manual or something and cant find one so any suggestions you may have would help a ton!!! THANKS!!!! the model is a hayward pro grid DE filter model de4820
  • 78 Answers
Here is your manual. Hope it helps... Rob http://www.haywardnet.com/products/Manuals/pdfs/Manual362.pdf
Posted on Apr 22, 2010
How do I put my foot controller back together, I took it apart because it will not turn off. My model # 66 - AA307535. Controller # 192257
more than likely, your variable resistor in the foot pedal is shot. cleaning is a low probability repair. replace the pedal assembly.
Oct 19, 2014 | Singer Sewing Machines
I have an echo PB265L it died the other day in the middle of use, it soaked the air filter with fuel. I started looking into it more this week and it has good spark but it doesnt seem to be getting fuel. I...
Put a new plug in it, don't prime it, and use quick start (a little bit), hold it wide open and give it good yank. If you haven't screwed with the needles and put everything back together correct (like hooking the fuel lines up correctly). it should have a short burst running. If that works, check your fuel line inside the tank to see if it is in tact and hooked to the fuel filter. The needles will be okay at 2 turns out. If it starts, you will need ot adjust them in for max tunning. Turn the one in closest to teh motor first (probably no more than a half turn), then holding it wide open "running" screw the next one in until it stips 4 cycling adn runs at peak.
Jun 06, 2014 | Garden
My pump and filter work great for an hour or more then the pump keeps running, but isn't pumping water through filter. We shut off the power and turn it back on and it works great for a while.
take filter apart clean grids (use TSP then 4 parts water to 1 part muriatic acid rinse off put back together then recharge with DE it should be fine filters are locked
May 19, 2014 | Hayward EC-40 DE Pool Filter with pump
I got a pool with a fns plus 60 DE filtering system thats depositing diatomaceous earth all over my pool.Took it apart cleaned the grids bought 2 new ones to replace the bad ones,put it back together...
The FNS PLUS was originally built by American Products under a different name and was absorbed into Pentair's line, recently replacing the PAC-FAB FNS (fiberglass nautilus) also absorbed by Pentair. The two filters have no common background.
The FNS PLUS has been cursed at by more pool techs than I can count. All I can say is practice helps but these are always a pain to get right. Make sure that the narrower of the elements is in the correct spot, the rest do not matter. Also check the manifold on all sides for cracks and make sure the air relief screen is set properly. I wish I had an easy solution for you, but this filter is just a pain, even for the guys that work on them every day.
Aug 23, 2013 | Pool & Spa
Need to reassemble the D.E. filter
All D.E. filters are basically the same. There are two plastic manifolds. One attaches to the bottom of tank by threads or bolts. The other plastic manifold goes on top, and ussually has small holes in this manifold for stainless rods to run through.All fabic looking materials(grids) run between bottom manifold, and top manifold.All grids must be washed free ofD.E.(diatomacus earth). Place bottom manifold on solid ground and begin plugging grids into large holes in manifold so they form a circle, this sometimes takes two people. Place top manifold on other end of grids in a simular fashion.Gently turn assembled filter to its side while holding together, and run ss rods through small
holes in bottom manifold, i n between grids , and through small holes in top manifold. Secure rods with ss washer and nuts, until snug but not overtightened.
Feb 15, 2009 | Jacuzzi Pool & Spa
Drain pump on my LG wm1832cw seems to be "clogged" I've cleaned drain filter check discharge hose and have made sure house drain is clear.
i took the pump out . then took the pump apart , water got past the o ring , where shaft goes into the center. i cleaned out the sludge & put grease on the o rings before putting it back together. it's worked since,
Jul 08, 2008 | LG WM-1832C Front Load Washer
Hoover Wind Tunnel
what probably happened is you swapped end over end when you replaced the beater brush. anyway go to thehooverstore, find your machine and you'll see an exloded diagram of your machine.
Aug 18, 2007 | Hoover Company Wind Tunnel U53019 Upright...
Hayward 36 Sq Ft Pro Grid Vertical Grid De Pool Filter  Logo
272 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
