Question about Kenmore Elite 900 sq. in. Cooking Area Gas Grill 16690\17690
Flare up and smoke
My grill flares up and smokes the whole party out
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 06, 2010
How can I block a number on my cherry mobile flare
3rd party app or contact your service provider, or purchase an iPhone are all options.
How to block number on cherry mobile flare s4
Jul 16, 2017 | Cell Phones
Replace fuel filter
This filter is a famous subject of controversy in Camrys. There is a lot of opinion out there that they not need replacing, being designed as a lifetime component. Certainly the filters located in the fuel tank don't, but the fuel filters in earlier Camrys are located in the engine bay instead, and may possibly be a different matter, opinions vary 50-50.
If of the second type, it is in the engine bay on the left side near the suspension strut tower, and has a metal casing. The banjo union at the top is easy to undo, but the flare fitting at the bottom of the filter is notorious for being difficult to crack undone. You must have a good quality flare nut spanner, correct size, like
http://www.gedoretools.co.uk/double-ended-ring-spanners/1933175-gedore-400-36x41mm-flare-nut-spanner-open-ud-36x41-mm-4010886865811.html
There will be raw fuel spilled, so take care there is no-one smoking, and have a fire extinguisher handy.
Dec 27, 2011 | 1995 Toyota Camry
I WANT TO CONNECT MY NEW GRILL TO MY HOUSE L P SUPPLY. I NEED A NEW Y-CONNECTION HOSE WITH CONNECTORS. MY HOUSE IS 5 YEARS OLD AND SUPPLIED WITH A 200 LB BURRIED TANK AN HAS A MAIN REGULATOR FOR THE ENTIRE...
The easiest way is to install a flare T into the existing gas line and then adapt the existing hose from that...no teflon is needed on flare fittings and for the adapters use only gas approved teflon tape.
heatman101
May 14, 2011 | Brinkmann ProSeries 810-6330-W Grill
I have purchased model #20050611. Can I smoke with wood chunks only and not use charcoal? Do I put the pre-soaked wood in the flame disk bowl or the water bowl? I am used to a double barrel wood smoker...
Wood only. No Charcoal. If you're using wood chips - soak them first. No sure wood chunks will work, as they will have a tendency to flare up & burn rather than smoke.
The presoaked wood chips go in the flame disc bowl, below the water bowl. The water bowl goes on the first shelf bracket from the bottom up.
I was going to send you a copy of your Owners Manual, but the Model Number you listed does not match up with any Masterbuilt Smokers?
Enjoy your smoker,
Apr 21, 2011 | Masterbuilt 20050106 Propane Smoker
While grilling we had a flare up that quickly turned into thick black smoke rolling from our gas grill. we shut off the grill and got the flames out. what could have caused this? is it safe to try and...
If you have a grill that is several years old, some of your burners may be rusted and deteriorating, causing these large, out-of-control flames. It's definitely not safe to us in this condition. Remove the cooking grids and all parts above the burners and examine each burner with a flash light. It's also possible the seams have split which may be harder to tell that it's defective. If you can remove each individual burner to inspect it, do it and and make sure there are no restrictions inside the burner, like bug nests, debris, etc that could clog it and force gas out the venturi tube at the orifice. If you had moved or transported the grill recently before using it this last time, it may have jostled something loose or caused the rusted burners to fall apart so quickly. Hope this helps. Let me know if you need more assistance. Douglas
Jun 08, 2010 | Char-Broil CharBroil Master Flame Gas...
What is the best way to clean the grill?
use a good wire brush on the burners each time you use it before and after cooking. every season take the grill grates and flare reducers out and clean them well with a wire brush and or steel wool and clean out any residue in side the grill. make sure the grease catcher gets cleaned often as needed. blow out the gas manifolds with air in the spring to remove spider webs or insect webs etc. this should keep your grill working well for 10-15 years. replace the grates or flare plates when needed.also lightly clean the burners when you have the grill taken apart with steel woll then blow them out as well to keep all the openings clear. happy grilling.
May 29, 2010 | Weber Genesis E-320 Propane Grill
Flare ups
turn one of the burners off and put your meet over that burner
May 25, 2010 | Kenmore BQ06W1B (LP)
Rear brake line developed a leak. can i just replace the small broken section or do i need to replace the whole line?
you can replace only the short section if you like using compression connector and they are easy to find them at the hardware store,or do the whole line since they are no really expensive,the whole deal would cost aroun 20 or 25 bucks (parts only)
Sep 16, 2009 | 1990 Toyota 4Runner
The inside coating of my Silver C is also peeling.
it looks like paint but it is food and smoke enamel on hood is baked on at 1600 degrees no way to get grill that hot spray oven cleaner on top not the sides and wash off
Aug 01, 2009 | Weber Genesis Silver B Grill
Would like to improve efficency and clean up time also to help flare-ups.
call Atlanta Grill Service they can get the part 770-667-5342
Apr 14, 2009 | Grilling
Kenmore Elite 900 sq. in. Cooking Area Gas Grill 16690\17690 Logo
55 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Paul Carew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
