Question about Dell Latitude D600 Notebook
Wrong keyboard config
When i type certain keys, other text comes up. for example when i type the letter f 'Fsda-' apears on the screen or if i hit backspace 'ty[and the cut, copy option appears. how do i reset my keyboard config as i have to usethe on sscreen keyboard
  • 696 Answers
Go into your control panel, set it to classic view if it's not already and open your regional setting panel. Depending which version of windows you have it will either have a keyboards tab or a input devices tab from there you can add back your keyboard and remove any other installed keyboards to ensure you have the right one defaulted.
f this doesn't work you can open the Accessibility options and turn them all off, then try again, finally if this doesn't work you may actually have a hardware problem with the keyboard.
Get back to me with make and model info of your computer if this is the case
Hope this Helps FixYa,
Chris
Posted on May 14, 2009
When I type letter keys, numbers come up with the letters
That's because some are dual function keys; you've probably hit the 'Alt' or 'Fn' key to the bottom left of the keyboard by accident. If you look carefully at the letter keys, they should have numbers on them in a different colour/smaller text.
Jun 25, 2014 | Toshiba Satellite A105 Notebook
The "v" key is malfunctional. It does not input if I key it alone. The letter appears when I type a word with the letter v in it, but the spelling is wrong. It shows up after three letters or so. Sometimes...
Is this a laptop, phone, or a pc keyboard?
If it's a PC keyboard you might be able to pop the key out and clean under it. I have went as far to clean PC keyboards in the dishwasher. (low heat, no soap, no high temp dry... and then shake all excess water out... and let dry for a week or two.. before you plug it back up.) But do this at your own risk.
If this is a phone, and it is on a touch screen, then try going into settings and changing from samsung keyboard to default android keyboard.. or vice versa.
Sep 25, 2017 | Samsung Computers & Internet
Wrong letters display when I type
Hi Check "Control Panel" > "Regional and Language Options" > "Keyboards and Languages" > "Change Keyboards". This brings up the "Text Services and Input Languages" dialog box in Vista (XP may be a slightly different path). This box will display (in the "Installed services" section) how many keyboard layouts are installed on your computer. If have more than just the "US" keyboard installed, there exists certain keyboard combinations with the "Ctrl" key that will automatically switch your keyboard layout from the default US to another one that is installed
Jun 13, 2012 | Logitech Illuminated Keyboard
When you are typing it will type the symbols instead of the letters, you have to keep hitting the function button for the letters to work, sometimes it will work hitting it one time other times you have to...
Hi
Try system restore. Go to START>ACCESSORIES>SYSTEM TOOLS>SYSTEM RESTORE>CHOOSE PREVIOUS RESTORE DATES. Use other restore dates if needed.
Or try this
If your laptop keyboard types wrong characters, it is rather a software issue than an hardware one. This can happen if you accidentally press certain keys on your keyboard, which enable a certain kind of function.
Try the following steps in case your laptop keyboard displays wrong characters:
1.Go to the control panel option
Click ? 'Regional and Language Services' ? 'Languages' ? 'Details' ? 'Key Settings'
2.Select the option 'Switch Between Input Languages' and click on 'Change Key Sequence'
3.Ensure that all the check boxes are unchecked in this window and do the same for 'Switch to...(Keyboard Type)'
4.Click ?
'Ok' ? 'Ok' ? 'Apply' ? 'Ok'.
This should solve your problem
Jun 24, 2011 | Acer Aspire One AOD150-1920 Netbook
Toshiba laptop keyboard doesnt respond to certain keys with correct letter. for example typing U gets a 3e?????
Hi
Go to the control panel and select the regional and language setting, Tab select Language and click the detail, you get new screen Text Service and Input Language hear you can select the Keyboard language (Default English United State) and change the keyboard setting. now your get perfect key before your have,
Good Luck
May 26, 2011 | Toshiba 310CDT Keyboard
I have a Dell Inspiron laptop, and certain letter
This could be a possible hardware issue. You can try to use an external USB keyboard and check if the keys are working or not. If you do not have an external keyboard, you can try to use the onscreen keyboard. To do this, go to start>programs>accessories> accessiblity and then choose on-screen keyboard. Open a notepad and try to use the keys which are not working using the onscreen keyboard. If onscreen keyboard works fine , then you need to get the keyboard replaced.
Nov 11, 2009 | Computers & Internet
What does the insert key do?
Press and the text you type will over write what ever you have on the screen. This is typically used in most applications to "type over" existing text without moving the other letters/numbers/characters around.
This is my example of how the insert key works.
hit the insert key and position your cursor at the "w" in works.
Now type WOW!!.
You should now have:
This is my example of how the insert key WOW!!.
Clever these programmers. :)
Keep in mind it depends on the application you are running also.
Have fun!
Oct 03, 2009 | Logitech Cordless Desktop EX110...
My blitz doesnt text
Try this. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Hope this helps, let me know if this works or if I can help you with anything else.
JimmyC
Aug 05, 2009 | UTStarcom Blitz Cell Phone
Acer travelmate 4050 keyboard prints wrong keys
Hold the Fn key then hit F11. This toggles the numeric nubers to letters and vice versa.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 20, 2009 | Acer NSK8458AN Keyboard
Ibm thinkpad keyboard. i type letters, numbers show up. fix?
With my IBM Thinkpad, I had to hold Shift+ScrLk to turn off Number Lock.
Mar 27, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
Dell Latitude D600 Notebook Logo
166 people viewed this question
Alun Cox
