Question about HP Compaq Presario V6000T Notebook
My laptop is not coming back on
I turned off the laptop and tried to turn it back on it is not cooming back on
  • Frank Zhang
    Frank Zhang May 11, 2010
    you may take away the battery using adapter try turn on, what happen?
  • 103 Answers
Thats vague.
could be bad m. board and pwr jack.
if charging light is not on i would replace both..
high tech knowledge is needed for this repair.
Posted on May 14, 2009
Car will crack and i hear the feal pump coome oon but it want start
run the fault codes and check for cam/ crank position sensor. Check operation of the immobiliser , Check that the cam shaft is turning (broken timing belt/chain)
Aug 20, 2014 | Cars & Trucks
2010 Elantra, started with a high pitched sound turning left. Did that for a few days, then started when turning right. Now same noise is cooming for about 10 seconds. Not immediately on start up but
You may need to check the belts on your car's power steering section. Make sure the belts are tight and not worn out. Check for cracks on the belt and if loose, tighten it. There is also a product called Automotive belt dressing that you can spray on the belt to make it stick more easily to the pulley it is supposed to turn.
Mar 12, 2014 | 2010 Hyundai Elantra
My tracfone want coome on
The first thing to Try is Remove the battery from the phone and wait 20 seconds, then, with the battery still out, plug it into your wall charger, then place the battery back in and turn the phone back on.
Aug 19, 2012 | straighttalk.com
My laptop does not turn on when i press the power key the laptop will not turn on. the battery light turns on the ac light turns on but the laptop will not turn on. . can any body help.
First, there is a problem that is why the laptop is not coming on.
What you should do is try to remove the battery and inserting it back in, then try to turn it in again.
If it does the same, then try to open up the laptop, remove the battery, then the hard disk and other components in the unit, then you fix them back and make sure they are properly seated. Then you reassemble it back together and then turn it on.
If it still does not come on, then you will have to charge it properly then turn on, this time, i beleive it should come on.
Take care
Oct 17, 2010 | Toshiba Satellite 1410-S173 Notebook
Noise from tv
the small speakers in the projector can't handle high volume, so the speakers may be shot.
Jan 11, 2010 | InFocus X1 Multimedia Projector
2001 Pontiac Grand Prix GT multifunction switch problem?
I had the exact same problem, I changed the "ignition switch" because the contacts inside were burned, this is why you see all those troubles coming in and out at different moments. It costed me 150$ to do it myself, buy the switch on an online reseller, must cheaper than the dealer! Now everything is back to normal on my Grand Prix GT 99 exept that my headlights don't light up automatically when starting the car... I have to check my fuse/relay and switch to make sure everything is ok on that side.
Good luck.
May 31, 2009 | 2001 Pontiac Grand Prix
Seat belt chime will not stop until ignition is turned off. mercury cougar 92
the wire under driver seat must have coom loose from the seat belt clip
Dec 04, 2008 | 1992 Mercury Cougar
Van will not start,
dodge says front control module ihave same van with same problem i have tested all my circuits relays and ign switch all good guess i get the front control module tell u if it works in about a week
Aug 26, 2008 | 2003 Dodge Caravan
Keyboard problem
turn of the number lock holding 'fn' key + 'num lock' key on your keypad...thats all
Dec 21, 2007 | HP Compaq Evo n610c Notebook
HP Compaq Presario V6000T Notebook Logo
47 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
