Question about Actiontec Computers & Internet
Actiontec m1000 dsl modem configuation change
M1000 DSL Modem installed and working with a single computer (Mac Pro)
Need to add a wireless router between modem and existing computer to connect a  Microsoft PC and laptop to create a home network.
Need to change configuration settings of modem.  Current IP is in the range of the wireless router.  Also need to know the protcol used by this modem and Qwest (Rio Rancho, New Mexico).  Qwest has been of no help.
Technotch
  • 22 Answers
SOURCE: wireless router
Yes, you can use wireless router with the modem. I guess the actiontech DSl router that you have is also Wireless one. If so, you can use just the DSL router for wireless connection. If you really want to use Dlink router with it, Connect the ( WAN port ) of the Dlink router to the ( LAN Port ) of the Action tech modem [ modem(LAN)-->Dlink(WAN) ]. Once you do this connection, better to do power cycle ( unplug the pwr to the dlink first, then, disconnect the pwr to action tech - wait 1min and plug the pwr to modem, wait for DSL light to be solid , then put the pwr back to dlink ). Make sure DSL light on the modem solid, internet light & WLAN light on the link glowing.
- Make Hardwire connection between the computer to Dlink and check the ip address on the computer whether it acquires the ip address from Dlink and then check the internet connection on the computer, it has to work. if computer not getting ip from dlink, try restarting computer.
- If hardwire connection on the dlink works fine and check the wireless connection.
For wireless configuration or assistance you may check this link:
http://www.portforward.com/help/wirelessxp.htm
please feel free to ask, if you have any more assistance.
- Laxman
Posted on Nov 23, 2007
mlake33
  • 427 Answers
SOURCE: Router seems to drop connection frequently
What a static ip is, is the ip address that the router automatically assigns to other equipment. (computers, xbox, ect.) Find D-links customer support line for help.
Posted on Apr 12, 2008
  • 35 Answers
SOURCE: d-link 614+ will not connect with Qwest M1000 modem
Well what everybody really doesnt know is that if Qwest provided you with a modem named Actiontech that modem has the same ip address of router so just change routers ip address to 172.16.0.1 and subnet mask to 255.255.0.0 and the problem should be solved.Im a product specialist for dlink.
Posted on Aug 27, 2008
latinmcgyver
  • 208 Answers
SOURCE: Intel Pro Wireless 3945abg not connecting to higher speed DSL
router wireless limitations. if it was N type router it would go faster.
Posted on Nov 29, 2008
frcs68
  • 1605 Answers
SOURCE: access home network remotely via zyxel modem
you will not be able to access from one network to another even if you are on the same workgroup. However, you can setup VPN on both side. the other is to use commercial remote software. i.e.: vnc, mypc, teamviewer, etc.... they don't need anything else, but do require setup on both machine. This is much easier, don't need any permission from the network administrator, or company permission.
Posted on Jan 09, 2009
Where can I get a quest m1000 mnual for a quest m1000 modem
Here's a link to the quick setup guide:
http://setuprouter.com/router/qwest/m1000/manual-596.pdf
and Centurylink help site:
M1000 Actiontec Modems
Note: Google searching for actual .pdf manual results in links to hacker sites, be careful.
Nov 11, 2014 | Actiontec M1000 Dsl Wifi Modem In Box W/...
How do I connect to a qwest dsl m1000 modem
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Aug 20, 2010 | Linksys Wireless-G WRT54G Router
Can a actiontec gateway wireless DSL router be connected to a comcast cable modem?I have an old DSL wireless router (gateway), can I use this as my wireless router with comcast cable internet, or do i need...
You could do it, but it's a bit of a pain in the ***** and probably not worth the hassle.
Actiontec DSL gateway was not designed to act as a "proper" router and therefore you won't be able to make it act like one permanently (well, unless there's a hacked firmware out there somewhere ;).
Of course, since it runs linux, you can telnet into it and manually set up the ip addresses on both wireless/wired interfaces and the necessary route between them. It will then work as a wireless access point for your comcast cable modem, but any changes will be lost every time you reboot the actiontec.
I've done it in the past with similar setup but quickly got tired of having to console the actiontec to add the ips and routes every time it crashed -and eventually got a proper wireless router.
So-it can be done, just not easily.
Have fun,
Raf
Nov 08, 2009 | Actiontec (GT701WG) Wireless Router
I have a dsl modem and an actiontec gt701-wg gateway
Yes this is a normal method to setup a wireless network.
To set-up and secure the wireless router from unauthorized access, follow these steps :-
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 31, 2009 | Actiontec (GT701) Modem
Will comcast support Actiontec - ADSL Modem with 802.11g Wireless Router and 4-Port Ethernet Switch
Comcast will not support that kind of modem. Comcast is a Cable ISP thus the ADSL modem won't work with them because ADSL modem is for DSL providers. Cable Company uses different protocol than DSL. But Comcast will provide you the cable modem if you subscribe to them.
Oct 22, 2009 | Actiontec GT704WG Wireless Router...
The power light on my actiontec m1000 blinks green & red and now my computer can't find the modem. What does the blinking lights mean??
hey
red light on modem usually means modem is in bad state
in this case kindly try to do power cycle
way to power cycle
disconnect all the cables and leave the modem for 30-50secs
then try and connect power cable first
then connect the dsl and then ethernet and see if that resolves the problm,
Sep 18, 2009 | Computers & Internet
Can't print from local printer using remote connection
To print the reports on your local printer, go to
1.Start->Run->
2.Type 'mstsc' and click 'ok'. A window pops up for Remote Desktop Connection
3. Click 'Options' button and select the 'Local Resource' tab.
4. Select the checkbx 'Printers' from the 'Local Device'
5. Click Connect.
Aug 20, 2009 | Actiontec GT701C DSL Modem
My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
Jul 20, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Weird MN700 hassle...
can you tell modem has the 192.168.2.1 ip just chage into different
Mar 04, 2009 | Microsoft MN-700 Wireless Router (p5308j)
Computers & Internet Logo
163 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
