I just want to change the oil on my 2003 3.2 tl
Look in your owners manual or look up online what type of oil you acura takes. Go to the store buy a 5 quart bottle of the oil type. Also buy an oil filter for your car. Just ask the people at the store to look up what filter fits your car. Get under the car or jack it up a little and put it on jack stands and get under it. Locate the oil pan and at the rear of it there is a small drain plug which is a bolt. Loosen it and get ready because once you remove it the oil will come pouring out so have a pan under the car to catch it. Then locate the oil filter and twist it off, replace the filter with the new filter and hand tighten. You dont need to gorilla grip it just snug it. Then replace the drain plug. Now your ready to refill with new oil up top. Make sure you get the right oil type and also lookup how many quarts your car needs. It is easy it takes less than 15minutes
can't hold you hands here!
go get the hanyes maunal and some metric tools, (sockets, rachet, extensions, open ends, and a oil pan. most of all, lots rags.)
