Question about Kenmore Washing Machines
Kenmore coin operated washing machine water saving tab location
I have a Sears Kenmore coin operated washing machine model #82407130 and serial # CE0630456. Under the top keyed portal it says: "To save water: pull out tab on water level switch located in console."
I can't find the water level switch. Any suggestions?
Thank you,
Scott Carlson
SOURCE: aeg oko_lavamat 508- not enough water
Have law level water problem in my clothes washing AEG Lavamant OKO 508.
Posted on Aug 13, 2008
  • 71 Answers
SOURCE: GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
The ge wcxr1070t uses a coupling under the agitator . There is a cap on the top pop it off and remove the screw if you see one , otherwise just pull up , the coupling is under the agitator check to see if it is stripped . dr fixit in the repair service directory will have it if bad
Posted on Dec 15, 2008
SOURCE: Dont want to save suds.( Kenmore model 5450290 Suds saver washer)
disconnect the wireing to the suds saver valve and tape the ends off.
valve will no longer open for the suds cycle
Posted on Oct 22, 2009
  • 1937 Answers
SOURCE: kenmore washing machine will not stop walking
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If you look at the section on "Machine Base Parts" you'll see a number of springs and vibration pads.
It's possible that one or more of the springs or pads has come loose or broken.
In order to get to them you have to remove the cabinet.
Here is a description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=90fdc122f6335c7c64f46f2ea1b1c887
Also see the Whirlpool Service Manual for top load washers. It has a troubleshooting section that describes the reasons for excessive walking or vibration.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
If it's not the springs or pads, you may consider that the "Agitator Cams" in the transmission are not raising the Agitator Gear high enough (about 1/16" ) when the washer goes into spin mode.
See the description of what the Cams do in the Service Manual.
We had the same problem, excessive vibration and noise during the spin cycle.
In order to solve that problem, :
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
It sounds a bit complicated but it really isn't too bad and (For a $15 part, saved buying a $170 transmission.)
Following is the Whirlpool parts list for their commercial washers although the consumer models use the same part numbers.
Posted on Jan 17, 2010
SOURCE: Miele W698 Hydromatic washing machine serial no,10/11236327 (purchased 1992)
SREALNO AND MODELS PROBLEM
Posted on May 13, 2010
Washer pump makes a clicking sound and is not pumping water fast enough before spin cycle, witch spills the water that was not pumped out. could the pump hve somthing blocking it ,or is the pump strti
Hi, there is most likely a blockage. Common is the coin blockage, locate the drain pipe and disconnect from area nearest to pump, usually has clamp fastening on either side of pump, disconnect both sides and check for foreign objects. Important*** disconnect machine from main current supply before working to avoid a shocking experience***. Hope this helps.
Apr 18, 2014 | Washing Machines
Its a commercialcoin operated machine that won't start washing what could be the problem please?
open the coin dispenser and push in the start button that the coin lever should push in when you put the correct coins in the dispenser
Feb 04, 2013 | Maytag Washing Machines
Coins in drain pump on washing machine. Coins can be seen through plastic drum of washer, how do i get them out/
Without your model number this is a stab in the dark.. for a front loading HE machine. Look at the lower panel of the washer. It should have 2 tabs that you can relase with a putty or butter knife. Open the panel... then locate the white or black flat faced filter. Rotate the filter 90 Deg CCW.... knowing full well this is going to make a water mess. Be prepaired.... cake pan works great! Then pull the filter out and remove the coins. Make sure your reach back inside with your fingers to ensure there is noting on the pump impeller blades. Once clean... reinstall the filter by pressing it straight in.. then thruning it 90 deg clockwise to LOCK it in place. Leak test!!!!!! Close panel and use normally.
Thanks for choosing FixYa,
Kelly
Apr 27, 2011 | Kenmore Washing Machines
Manual for kenmore 80 washing machine
See the following Sears site:
http://www.managemyhome.com/
Click on the Manuals tab, enter your model number and you should be able to get a PDF file of their operating manual.
Sep 26, 2010 | Washing Machines
I have coins under the basket of my kenmore elite oasis he model 2806 how do remove the basket?
See the following Whirlpool Service Manual for their Cabrio washer. The Sears / Kenmore Oasis is basically the same machine so the procedures for pulling the basket should be the same.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Apr 26, 2010 | Kenmore 22422 Top Load Washer
What year was my washing machine made? Kenmore model # 110 91565210 serial # CF1608473
Looks like it was in the 16th week of 1996 so that would be around in April 1996... according to your serial number... btw it was actually made by Whirlpool for the Kenmore line at Sears..
Jun 05, 2009 | Kenmore Washing Machines
Water not hot on hot temperature setting
BS ....on the back inside the washer are two solenoid operated valves that control the hot and cold water flow. your hot valve has ceased to function...and needs replacement.  also make sure your hot water valve is open fully and that the screen inside it isn't clogged.
Mar 29, 2009 | Kenmore 22422 Top Load Washer
Your leak may be at the pump as these will eventually have failed seals and need replacement. They aren't too hard to find, with the back panel removed, look for a roundish plastic device with several hoses attached.
You can get the part number from the Sears parts 'store' via an illustrated breakdown of your machine and order it from them or, if you have a Johnstone Supply store in your area, you can save a few dollars getting it there.
Feb 07, 2009 | Kenmore 22422 Top Load Washer
Need replacement coupling for Kenmore Washer
Go to a sears service senter and they can order one for you
Jan 22, 2009 | Kenmore Washing Machines
Kenmore Front Load Washer Problem
Pump may be plugged.Take off back Locate pump remove hoses. Check pump spins freely, remove debis. Mine had a hole in the basket gasket sealt hat let debis get in the pump. Good luck
Oct 27, 2007 | Kenmore 44102 Front Load Washer
Washing Machines Logo
212 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
