Question about Uniden Cordless Phone
Uniden cordless: Adjusting ring tone volume down
From the manual instructions online, I suspect that I have an older Uniden model, (it's a 900 MHz cordless), since I don't have the 'standby' that they refer to in the instructions. My model # is: EXA7950/Serial #: 04203988.
If I'm on calls, adjusting the volume is no problem, but adjusting the volume on calls coming in when the phone is ringing has been futile. Any advice is appreciated.
Thank you.
If it is like mine....push on one of the volume buttons (up or down,doesn't matter) and the phone will ring. WHILE IT RINGS, push the button again and it should scroll to the next ring option. Keep pushing WHILE it rings to scroll through the ring options.
Posted on May 30, 2009
Have Uniden EX14560 and do not know how to turn ringer back on..can you help me?
Do you mean the Uniden EXI4560 2.4 GHz phone? With the handset in standby, press the volume up button (above End and just below the LCD screen). Then you will be able to toggle between the 5 available ring tones and volume levels. (I'm assuming the unit is set to Ringer Off which is another choice in the list.) Press End to confirm and save your ring volume setting.
Most Uniden manuals are available from Uniden on the product page or the support page. The product page is http://www.uniden.com/cordless-phones/24-ghz-extended-range-cordless-technology/invt/exi4560g/ . Then go to the Manuals tab. The direct link to the EXI4560 manual is http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/EXI4560om.pdf .
All of the Uniden manuals are here: http://www.uniden.com/scat/cordlessphones_mnl . Use the drop down menu to select the type of phone and then find it in the list by numerical and alphabetical order. The EXI4560 is on page 4 under cordless phones.
I hope this helps.
Aug 25, 2011 | Panasonic UnidenEXI3226 : Two-Line 2.4GHz...
We have an older Uniden cordless telephone-Model #EXI7960 that seems to have a very soft ring tone. How can we increase the volume of the ring? Also, is there an owners manual on-line for download?
The EXI7960 has two ring tones and two volume settings available. With the handset in standby, press the Volume up button. (The volume up and down arrows let you switch both volume and ring tone. So you may have to press it a few times to adjust the volume.) The display should show the changes.
Retrevo has the manual here: http://www.retrevo.com/support/Uniden-EXI7960-Telephones-manual/id/471dj498/t/2/ . You will need to enter a code to access the PDF.
I hope this helps.
May 27, 2011 | Uniden EXI 7960 Cordless Phone (EXI7960)
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
I need a manual for a uniden 900 mhz cordless phone
Sorry, you didn't give the model #. Try going herehttp://www.uniden.com/index/manuals_results.cfm?cat=1
they might have it
Jun 14, 2009 | Uniden Cordless Phone
I carn't ajust volume on ring tone
Since you declined to specify the model of your Uniden DECT 6.0 phone I can only suggest you select it from the list beginning here to download a copy of the manual. The manual will describe how to change the ringer volume.
May 07, 2009 | Uniden DECT 6.0 Cordless Phone ID
Lost manual
How do I change phone from pulse dialing to tone dial.
Thanks
Rjfawcett52@yahoo.com
Apr 22, 2009 | Uniden Cordless Phone
Lost manual
Without the exact model it is difficult to find the manual.
Here the manual for 900 series/996:Uniden EZI996.
I also quote from manual:
Selecting the Ringer Tone and Volume
Base ringer on/off
The ringer switch allows you to set the base ringer on or
off. If you set the switch to off, you never hear the base
ringer tone.
Base ringer tone
Press the ringer tone button in standby mode to select one of 7 ringer tones.
Base ringer volume
Slide the ringer volume adjuster to set the base ringer volume.
Handset ringer tone and volume
Press the volume up key or volume down key (labeled as the volume/ /+ or volume/ /- key) in standby mode to select one of five ringer tones and volume combinations
Apr 17, 2009 | Uniden Cordless Phone
Programing the memory numbers
http://www.uniden.com/pdf/EXI2960om.pdf
Aug 31, 2007 | Uniden Cordless Phone
Uniden Cordless Phone Logo
537 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
