Question about Zebra 105Se Thermal Printer
Printer printing from PC W/2000 but not with XP
Why would a 105Se print from a PC running windows 2000 but not print from a PC running XP?
  • kmcnew May 14, 2009
    Everything is installed properly. Data gets to the printer and the data light flashes but no print. If I hook it up to the machine running 2000 with the same driver it prints fine. I am using parralell.
  • 17 Answers
Hi Kmcnew,
This issue could occur if the connections are not proper.
If the printer is connected using USB cable then you need to make sure that the printer is installed on DOT 4 port.
We need to also make sure that the driver for this printer is installed and listed under printers and faxes.
Posted on May 14, 2009
My Zebra 105Se printer keeps printing blank labels
There are several reasons why this could be happening. If the computer accessing the printer changed then I assume the new computer was recently set up with software to send print information to the printer. I would start with simple calibration and move from there. Zebra Technologies 105SL Printer Calibrating the Printer With Video
Jun 04, 2014 | Zebra 105Se Thermal Printer
Have a Zebra 105SE that prints the FEED test just fine, but will not print the PAUSE test nor will it print a bar code label from the computer. The FEED test prints vertical bar codes while the PAUSE test...
Check to see if the pause light is on also. Make sure you are using the correct printer driver. (105se)
Try in ZPL and then try in ZPLII.
Check Delimiter character 2CH
Check Format prefix 5EH
Check Control prefix 7EH
Aug 24, 2010 | Zebra 105Se Thermal Printer
My Zebra 105SE is printing fine on the left
I think the 105 has an adjustment on the printhead. There are left and right hand adjusters just above the printhead. It sounds as if the right hand one does not have enough pressure on it, try increasing the RH one and see the effect on the print.
Jan 06, 2010 | Zebra 105Se Thermal Printer
Can I print in color with a Zebra 105se
Thermal printers don't have any 'color' of their own; the 'printed' text/numbers are actually only areas subjected to heat from the printhead which exposes the color of tiny beads of ink that are on the paper itself by melting them. Use a fingernail to 'score' the paper and you will see it change color just as happens in the printer.
Oct 14, 2009 | Zebra 105Se Thermal Printer
Every label printed starts further down on label zebra 105se
It sounds like the problem is with the media sensor. Make sure you haven't loaded the ribbon through the same slot that the paper enters on the media guide. There is a reflective metal plate above the media that reflects the sensor from below the media.
May 26, 2009 | Zebra 105Se Thermal Printer
Zebra 105SE label material will not retract in prep for next Lab
The platen is the driving force for the label. the main drive belt runs all functions in the printer.
Is the back feed turn on in the printer? Check the setup.
Also if the print driver is set(doc/properties settings on print depending on software) to use pirnter settings, and the back feed is turned off in the printer, it will not backfeed.
Feb 24, 2009 | Zebra 105Se Thermal Printer
No response from 105Se
if the data light comes on and nothing prints chances are that the serial settings are set improperly. all of my printers are 25 pin serial, not parallel. i don't have one in front of me but i believe the settings are 19200, 8, 1, none. hope this helps.
Mar 19, 2008 | Zebra 105Se Thermal Printer
Zebra 105 SE Printing Blank Labels
You need the correct driver for the 105Se. The 300 dpi SL driver is not compatible.
Unfortunately, Zebra does not make it's older drivers available online. You will need to locacte someone with the correct driver for whichever version of Windows you are using.
Steve
Feb 13, 2008 | Zebra 105Se Thermal Printer
Hp 1220c window xp driver
i updated my driver for my hp1220C on XP after a crash that stopped the valuable print preview function working ...(printer worked but was print immediate - -and no tool box options etc) . i can't believe i found how to fix the driver ... you need to right click the exe file [before running it] dj1074en.exe or whatever ... and 'properties' - 'compatibility' click near 'compatibility mode' 'windows 2000' - then run it ... and voila -- i now have the print preview and all the lovely functions back again!!!! crazy!! took me 3 hours to find this ... it may well work with vista -- to select the windows 2000 option .. don't know that one ... at least until HP update all corectly and clearly
marie
Dec 28, 2007 | HP DeskJet 1220c InkJet Printer
Zebra 105Se Thermal Printer Logo
91 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
