Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet front washer will not come on!
I have checked the breaker which is fine. I checked the plug which is fine. My machine is full with the last cycle and it will not activate or power up at all.
  • cct776606 May 19, 2009
    Thanks I found the problem...its was the power cord which was installed incorrectly and in turn it rubbed against the tub wheel and caused the line to fray!
  • 51 Answers
SOUNDS LIKE YOU NEED TO CHECK POWER COMING INSIDE WASHER, AN IF SO REPLACE MAIN CONTROLER AN DOOR LATCH ASSY
Posted on May 16, 2009
No power and no code error on my Whirlpool duet washer
possible you have blown the fuse inside the machine, or burnt out a component. if you have a multimeter you should test your fuse for continuity, then your pump and motor for shorts.
Nov 09, 2013 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool front loader washer. I have checked the plug and circuit breaker and they both work fine, however my washer does not turn on. What could be the problem?
try to put in other plug,if the uni is no power or same problem,its means the unit have a problem,if your unit is have a digital,thats the one we need to replace,but how much the cost,check the price and the labor before you make a decision to repair,or buy the new one.
Dec 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: front load whirlpool washing machine runs fine unt...
You can try this:
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door wont open because there it is full of suds
Try cycling the buttons/knobs to various positions until it restarts. check that power cord is plugged in and circuit breaker is not tripped.
Otherwise move drain hose to a bucket or tray - water should slowly run out once the hose is near the ground.
Mar 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Power light doens't go o
Plug a working lamp in the washer power outlet. If it lights, the problem is within the washer (look for a breaker button on the back of the machine). If the lamp doesn't work either, look for a bad breaker, a loose neutral wire connection, or loose wire connection on the breaker. Check the wiring on the washer end as well.
Oct 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need to reset a whirlpool duet washer
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loader no power
Reset your circuit breaker in the electric panel.
Jul 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Dryer
Friend,
huuum At your service!
You said:
Everything was working fine, now we get no panel lights, the dryer light doesn't, dead in the water! Checked the plug...unplugged it and plugged it back in. Checked the circuit breaker...ok. What next?
I'm sorry to tell you that you need hands on service.
If I were there hands on I could diagnose the problem.
You may have an electronic malfunction and that only a trained technician can diagnose!
SORRY!
Bless You,
huuum
Please give me a good rating before you sign off
thank You
You will be fine
Bless You ,
huuum
Please give me the best rating for this solved solution!
Thank You!
Sep 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Old whirlpool washing machine won't run.
if no lights suspect main control bd remove rear screws in top panle remove top by sliding towar back control is along rear
Jun 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
203 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
