Hi I have Print Shop 23, upgraded from Print Shop 20 which I never had problems with. I am laying out my son's school yearbook and want to save file as a pdf. It won't let me. First it seemed like everything was fine then I would get a run time error at about page 22 (out of 28). So I messed around with it (per Broderbund's site suggestions) and tried reinstalling the pdfdriver. Now when I try to save as a pdf it says "failed to setup pdf converter" then I hit OK and it says "unable to initiate pdf printer/driver"
The small area at the bottom left of the screen where I can choose front, inside and back of card...
(More)
The small area at the bottom left of the screen where I can choose front, inside and back of card disappeared. How can I get it back?
I do not see the opening box or tool bar to the left side when the program opens. And it freeze up...
(More)
I do not see the opening box or tool bar to the left side when the program opens. And it freeze up and will not close.
As I begin a new project, I insert any number of frames. Selecting the fill box, I can select color...
(More)
As I begin a new project, I insert any number of frames. Selecting the fill box, I can select color or texture. When I complete this task, the frame is posted along with the fill. However the fill is mislocated 1/3 high inside the frame. You can detect the fill coming out the top of the frame. The lower 1/3 remains white despite variety of color or texture selected. Hp amd athlon 64x2 dual core 4600 2.4 ghz desktop Vista Home premium sp2 4gb ram 32bit os
I created a logo in Adobe Illustrator CS3 and saved it as a jpg which I want to use in a brochure I...
(More)
I created a logo in Adobe Illustrator CS3 and saved it as a jpg which I want to use in a brochure I created in Print Shop 23 Deluxe. But when I insert from file the colors are wrong. There is a background of green where I have none and alot of purple plus other changes that are not mind. I have other images from AI and this did not occur ... did I do something I didn't realize?? Please help! Thanks, Freda
