Question about RCA HD61W66 61" Projection HDTV
Convergence problem hd61w66 problem #2
How doo i replace the 400 ma 125v fuse ...please instruct me
    New Friend:
  • 13 Answers
There are 3 small brown rectangular fuses by the flyback ...the fuse in question is the middle one...it has to be unsoldered from the board and is somewhat blocked by the plastic...the fuse has to be ordered from an electronics outlet like andrews electronics in calif. 18002890300....be sure to resolder all connections to the flyback which are kinda in a semi oval shape.
Posted on Jul 22, 2009
  • RCA Master
  • 1,525 Answers
Hello take the back off the tv look where the power lead plugs in to
you should be able to see a glass fuse get a mulitmeter and test it if you change the fuse and it blows again you have a dead short in the circuit good luck
shaun
Posted on May 14, 2009
Colors are seperated on toshiba 50A61
Go into menu and with original remote call up convergence--either it has a problem(will not adjust) or you may with the remote be able to manually adjust the convergence back: sometimes if a power outage/surge it scrambles the convergence memory.
Aug 28, 2012 | Toshiba Televison & Video
Convergance is off
I have an RCA 52” HDTV Model R52WM24 the other day it developed a convergence problem (The picture took on a 3D effect and it the screen had an hour glass type of shape)
This appears to be a common problem or a pattern failure.
I wanted to confirm that I did find the fuse p/n FL231 to be blown.
I think it said the RCA part # is 259213 and it is a 400 ma, 125V fuse, Looks like a square capacitor by the fly back xfmr.
I bought a generic part from Digi Key and it seems to be the identical replacement part to the fuse that was in the circuit.
The Digi-Key part is part # WK4440BK-ND (99 CENTS EACH).
THIS IS A 125V, 400 MA ( 0.4 A FUSE). Digi Key PHONE # IS 1-800-344-4539
I am watching the TV right now for last 3 hours and it seems to be a good fix.
The fly back transformer solder connections looked good but it is recommended to re solder these part ( so I did).
Good luck
Dec 27, 2009 | RCA R52WM24 52" HDTV Projection Television
Our TV picture is bowed inward and lettering is 3D. How do we fix this problem?
Go to Menu then to setup if you do not see Convergence in the menu then you have a blowed Fuse FL231 it will be on right hand side of FBT flyback Transfomer there is 3 in a roll it will be the Middle one they are small brown rectrangler Looking caps but are Fuses Located on the Deflection board Bottom Left hand Board.
Dec 24, 2009 | RCA Televison & Video
Convergance problem
Resolder the connections on the high voltage transformer. There are 3 pc mount fused shaped like little brown boxes to the right of the transformer. If the one in the middle is open. Change it. I't 400 ma fuse.
Nov 22, 2009 | RCA HD52W59 HDTV Projection Television
Mitsubishi WT-46809 Powers Off; Code 2-2
The 2 fuses you mentioned are associated with the convergence IC. If they are open then the convergence IC is either bad or you have a "cold" solder joint on the IC.
Feb 01, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Replace a fuse R52WM24
you can temporarially. Its recomended not to exceed fuse ratings especially the amperage do to pretective reasons. You can get the proper FL231 fuse at the following link. They have a 10.00 minimum order for free shipping so you may have to order enough fuses to add up to 10.00 or pay for shipping if under 10.00 Heres the link.
http://servicemanuals.vstore.ca/
Jan 17, 2009 | RCA R52WM24 52" HDTV Projection Television
Convergence on a r56wh78 rca projection tv
I located the problem with this set and wanted to pass it on to help anyone with this problem. the chassis # is ITC222A and the problem turned out to be a fuse on the High voltage board. There are 3 fuses that sit next to the flyback transformer and the middle fuse (400 ma 125v) was blown.
Mar 21, 2008 | Televison & Video
Toshiba 50H81 TAC0151 Blowing Fuses, I Need schematic
Well without the schematic, knowing Toshiba they have alot of convergence problems, so see if the fuse blown in the convergence area, if you you may have to replace convergence amps. These are the big STK's. Most of the time there was a color problem with set before going out. If no problem with this on your set then look in the HV area Hor. and Ver. area. Hope this helps!
Sep 09, 2007 | Toshiba 50H81 50" Rear Projection...
RCA HD61W66 61" Projection HDTV Logo
357 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
