Question about Brother IntelliFAX 2920 Plain Paper Laser Fax
How to replace the phone numbers in the quick dial list & 1touch
Need to know how to replace the telephone numbers in the quick dial list, and 1 touch list, and how to add multiple numbers into the quick dial list.
  • michelleg213 May 15, 2009
    I have the manual - the directions are worthless. Thanks anyway.
Follow this link, select your model, download manual, and do a little reading:
http://www.brother-usa.com/Manuals/Default.aspx?WT.cg_n=Support&WT.cg_s=Manuals
Posted on May 14, 2009
I have model 1104 sensaphone and lost manual. I want to know how to change dial out numbers
To change the phone numbers in the Sensaphone 1104 press [SET] [phone number] <1-4> then enter the telephone number you want the unit to dial, and press [enter]
*Remember to program the telephone number JUST how you need to dial it from that location. If you do not require a 1 or area code do not program it in, as this can cause the dial out to fail.*
Here is a link to the manual if you need one. Also, since this model was discontinued, the direct replacement for this unit would be the Sensaphone 400.
Sensaphone 1104 Manual:
http://www.sensaphone.com/legacy-products/1104Manual.pdf
Sensaphone 400:
http://www.sensaphone.com/products/sensaphone-400-monitoring-system.php
Feb 06, 2011 | Cell Phones
Driverts calls
Hi, You can use this instruction to activate and de-activate Call divert .Works on all phone
Turning Call Divert On
by Touch Tone phone
Step 1 Lift the receiver and listen for the dial tone.
Step 2 Press the Divert On button if using an Optus OneTouch phone, or dial *78 from any other touch tone phone.
Step 3 Listen for three beeps followed by a continuous tone.
Step 4 Dial the telephone number to which the calls are to be diverted.
Step 5 Listen for two short beeps, confirming the diversion.
Step 6 Replace the receiver
Turning Call Divert Off
By Touch Tone phone
Step1 Lift the receiver and listen for the dial tone
Step2 Press the Divert Off button if using an Optus OneTouch phone, or dial #78 from any other touch tone phone
Step3 Listen for two short beeps to confirm removal of the diversion
Step4 Replace the receiver.
Other Call Divert Options - Selective Calls
With selective call options, you can choose which numbers you wish to divert, accept or reject by adding these numbers to a list. You can list up to 30 numbers for each call option.
Turning On or Off Selective Call Options
Step2 Press the access code for the service you require. You will hear a prompt telling you the status of the service and how many telephone numbers you have on your list. To turn the service on/off press 3.
Access codes Dial
*63 for Selective Call Divert Dial
*68 for Selective Call Accept Dial
*60 for Selective Call Reject
Step3 For Selective Call Divert you will then hear the 'divert to' number that is currently entered. If this number is correct press 1. If it is incorrect, press 0, then re-enter the phone number you wish to have your calls diverted to. When turning this feature off dial 3 again.
Step 4 The feature is now on/off.
Step 5 Replace the receiver.
Note: You can divert calls to a local, national or mobile. However, you cannot divert calls to emergency, 0055, 1900, 008, 1800, 0050, 13, 1300 or international numbers.
Hope it helped.
Thanks for using fixya...
Jan 11, 2011 | Cell Phones
How do you set the time on a panasonic kxt7731 proprietary telephone
Which system. See below. BUT make sure you find your system first....
Panasonic XDP 824/1232
All programming is done at ext. 101
1) Press the program button, followed by *#1234
2) Dial 000, then follow the prompts on the LCD
KX-T308, KX-T616
  1. Use phone with intercom number 11. It will change the time for all phones.
  2. Keep handset down and press INTERCOM button.
  3. Dial 77.
  4. Dial the hour, with two digits (e.g. 03 for 3 o'clock).
  5. Dial the minutes, with two digits (e.g. 07 if it is now 7 minutes after the hour).
  6. Dial 0 for AM or 1 for PM.
  7. Press #.
  8. Press SP-PHONE
Panasonic KXT Series Telephone System
Setting the time must be completed from an LCD Display phone at Extension 11, using the telephone keypad. This system type requires "Easa-phone" series or a 7000 series model telephone (the model number is listed on the bottom of the phone) that has one or more small switches located at the rear of the phone. Digital "XDP" phones can not be used on this system type!
To set the time:
  • Lift the handset or press "SP-Phone" button on Extension 11.
  • Dial "77"
  • Enter the hour with 2 digits. (01 through 12)
  • Enter the minute with 2 digits. (00 through 59)
  • Dial (0) for AM or (1) for PM.
  • Press the "#"
  • Wait for confirmation tone. (Instantly after pressing the # button, new time counting will start).
KX-TA624
  1. Use phone with intercom number 101. It will change the time for all phones.
  2. Move MEMORY switch on rear from SET to PROGRAM.
  3. Dial *#1234
  4. Dial 000
  5. Press NEXT ("Sp-phone")
  6. Press Right Arrow ("FWD/DND") four times until you see the time displayed
  7. Change the hour with the keypad
  8. Press Right Arrow ("FWD/DND") to reach the minutes field
  9. Change minutes with the keypad, if necessary
  10. Press AUTO DIAL/STORE
  11. Press HOLD
  12. Move MEMORY switch on rear from PROGRAM to SET.
KX-TAW848
  2. Press PROGRAM (or PAUSE, if you don't have a PROGRAM button.)
  3. Dial programming access code (probably *#1234)
  4. Press NEXT (SP-PHONE, if you are not using the programming template).
  5. You'll see "Date & Time Set" on your phone's display
  6. Press STORE
  7. Press NEXT to see hours and minutes.
  8. Use your keypad to change the hour
  9. Press STORE.
  10. Press HOLD.
  11. Press PROGRAM
KX-T123211D
  1. Use phone with intercom number 101 (probably the receptionist's phone). It will change the time for all phones.
  2. Move MEMORY switch on back of that phone to PROGRAM.
  3. Keep handset down and press 0 on touch-tone dial.
  4. Dial year with two digits (e.g. 97 for 1997).
  5. Dial month with two digits (e.g. 01 for January).
  6. Dial date with two digits (e.g. 03 if today is the third day of the month).
  7. Dial day with one digit (1 for Monday, 2 for Tuesday, 3 for Wednesday, 4 for Thursday, 5 for Friday, 6 for Saturday, 0 for Sunday).
  8. Dial hour with two digits (i.e. 01 for 1 o'clock).
  9. Dial minutes with two digits (i.e. 07 for 7 minutes).
  10. Dial 0 for AM, or 1 for PM
  11. Press either AUTO DIAL/STORE or AUTO/MEMORY, depending on your phone.
  12. Move MEMORY switch on back of phone to SET.
Panasonic DBS 824, 40, 72 & 96
- From the Attendant's display phone.
  1. Press "On/Off"
  2. Press "Prog"
  3. Press " ##"
  4. Press "FF1 key"
  5. Dial 1#, 2#
  6. Dial the time in 24 hr format.
  7. Press #
  8. Press "On/Off"
- From any display phone in the system.
  1. Press "On/Off"
  2. #98 + Password
  3. Press "Prog"
  4. Press " ##"
  5. Press "FF1 key"
  6. Dial 1#, 2#
  7. Dial the time in 24 hr format.
  8. Press #
  9. Press "On/Off"
Panasonic DBS 576 & 576 HD
From any display phone in the system;
  1. Press On/Off
  2. Press "Prog"
  3. Press " * * "
  4. Dial the " Password"
  5. Press "FF8"
  6. Dial 81001
  7. Dial in new time in 24 hr format.
  8. Press Hold and then "On/Off"
Aug 15, 2010 | Panasonic KX-T7731 Corded Phone
If I enter the phone number and then press "talk", the numbers dial extremely quickly, a dial tone comes on, and I have to enter the numbers again. How do I fix this? It is a Vtech 6.0 DECT.
Usually there are two modes provided to all fixed line telephones. Tone mode and pulse mode. Pulse mode will dial the call slowly and Tone mode will dial calls quickly. Your phone is in Tone mode i guess. You need not dial the numbers again. Wait for few seconds and the call will get accomplished!
Aug 01, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
How do I programm the Speed Dial on my 4406D+?
To program your Personal Speed Dial numbers, make a list of
your telephone numbers/extensions numbered 1 to 24, then:
Press an Intercom button + lift handset + dial #00 + dial # + list number (01 to 24) + dial *21 + the number you want to store + #*00.
To use Personal Speed Dial:
1: Press an Intercon button.
2: Press Feature (if you have programmed a "Feature" button) or #.
3: Dial the two-digit code (01 to 24).
Apr 27, 2010 | Avaya Merlin Magix 4406D+ Corded Phone
Enter memory data
Here are the commands to run the phones memory dial (speed-dial).  I have included the instructions for deleting and changing numbers as well.  It is listed below.  I hope this helps you out.
Ken
MEMORY DIAL INSTRUCTIONS Store up to ten 20-digit numbers in memory for quick dialing. Storing a Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the MEMORY button. 3. Press a number (0-9) to store the dialed number in that memory location. 4. Press the MEMORY button again. 5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm. 6. To enter another number in a different memory location, return to step 1 and repeat the process.
Storing a Redial Number 1. Repeat steps 1 through 4 in Storing a Number in Memory. 2. Press the REDIAL button. 3. Press the MEMORY button to store the number. You will hear a confirmation tone.
Changing a Stored Number 1. Repeat steps 1 through 6 in Storing a Number in Memory. 2. Press the MEMORY button to store the number. You will hear a confirmation tone. The old number will be overwritten with the new number.
Dialing a Stored Number 1. Make sure the phone is ON by pressing the TALK button. 2. Press the MEMORY button. 3. Press the number (0-9) for the desired memory location. The number dials automatically. Inserting a Pause in the Dialing Sequence Press the PAUSE# button once to insert a delay in the dialing sequence of a stored telephone number. A pause is needed to wait for a dial tone (for example after you dial 9 for an outside line, or to wait for a computer access tone). Each pause counts as 1 digit in the dialing sequence. If you need a longer pause, press the PAUSE# button twice.
Deleting Stored Numbers 1. Press the MEMORY button. 2. Press the desired memory location (0-9). 3. Press the MEMORY button twice to delete the entry. 4. You will hear a confirmation tone.
Jan 08, 2009 | GE 27928GE5 Cordless Phone
Programming a number for memory
Memory
Nov 03, 2007 | Uniden Cordless Phone
Need manual
Given that consumer telephones are inexpensive, the cost of repairing the speaker phone on the 960 (assuming you still have it) is probably not worth it.
Going off of my memory....to program a speed dial you would first press "Program", enter the telephone number you want stored and then press the one of the memory buttons to save the number to. If the number is to be saved on a lower memory position press "Lower" before you press the memory button.
AT&T's telephone product website has a section where user manuals for many AT&T and Lucent branded telephones.
http://telephones.att.com/telephones_ui/support/dsp_manuals_list.cfm
The 960 is no longer listed, but the many of the basic functions are similar to the 922.
Sep 20, 2007 | Lucent AT&T 960 Corded Phone
Remove power cord with no backup battery
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set.) Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
May 17, 2007 | GE 2-9450C Corded Phone
Storing Speed Dial Phone Nmbers
Emergency/quick dial numbers: Pick up handset, push store, enter the phone number (it will not call the number), push store again, Push A,B or C. hand up handset. Frequently called numbers, pick up the handset, push store, enter the phone number, push store again, push key pad 1, or 2, etc. for memory location. Hang up handset. How to change a stored number. just repeat the sequence. How to clear a stored number, repeat the storage skip step 3 (do not enter the phone number). How to correct an error while storing, just hang up and repeat.
Feb 26, 2007 | GE Telephone pr521w
Brother IntelliFAX 2920 Plain Paper Laser Fax Logo
101 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
