Question about Sony PlayStation Portable (PSP) Console
Psps does load any discs
Hi my psp does not seem to read any discs anymore when i fire it up i hear motor kick in and try to scan the disc and then nothing, the little icon flashes in the bottom right hand corner and nothing happens any ideas or is this terminal
  • Anonymous Dec 30, 2008
    i have a similar problem, my psp menu section works fine, but when i put in a umd and trey to start it the psp turns itself off.
  • 709 Answers
Hi Tubston1980,
What we have here, is a failure to read the UMD.  Troubleshooting 101,  open the UMD door and depress the little black spur sticking up about 1/8" and it is about 3/4" in and to the left.  Once your depress the Black spur, You should see the the little disc motor spin and the laser beam light up.  Do not stare into the laser. This tells you that at least the laser is lighting and the motor is turning,  Now, get a Q-tip and dampen it with Isopropyl rubbing alcohol.  Rub the lens with the dampened q-tip.  Use the dry end of the Q-tip to dry the lens. Look carefully to see if any lint or foriegn obsjects are inside the UMD disc drive.  If you see anything, get it out. Look at the white gear in that back to see if anything is on it. Clean it if necessary, I know its very close quarters and hard to do.
I repair PSP's with this problem that do not get fixed after cleaning. I can replace your UMD drive with a full brand new drive for $47 which includes Return shipping. Contact me at Repairtech@playstationclinic.com if you need further assitance.
Posted on Oct 15, 2007
Hey there i bright a psp and its not reading the games wat can cause that???
Hello
Switch on on your PSP and remove the UMD that might be inside
When you open up the UMD door and look down inside you will see the Laser assembly.
If you look to the left there is a black tab that sticks up, this tells the PSP that there is a UMD in the drive.
If you press this down with a small probe, you should see the disc motor spin and the laser light up red (do not stare directly at the laser)
Inspect to see If the Motor is spinning or not.is it moving slightly?
Take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser,check the cables to the PSP and see if there is a bad connection.
If both are running well then put a disc in and get your ear up close so you can hear what is going on in there.
On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be too much pressure for the disc to spin freely
Can you hear the Laser focus? This might be hard to hear it will sound like a little tick. If you cant hear it tick I would move on and inspect this internally later.
Can you hear the Laser move down the rail? This will be a smooth sound of the gears, it should not be a really clicky sound.
If you can't hear it move down the track OR it is very clicky do the fpllowing;
You should open the UMD door and carefully manually move the laser to the right side of the assembly.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing.
try and scrape the gears themselves to make sure there is no gunk or debris in the gear..
After this try and see if it is reading UMD again.
If none of this is working, it is time to open your PSP unit
If you are able to find out what's wrong from the troubleshooting steps above you can replace the problem by
Replacing the UMD, Assembly,Replacing UMD Disc Motor,Replacing UMD Laser Motor or by Replacing PSP Motherboard
Dec 15, 2010 | Sony Video Game Consoles & Games
My problem is my umd disc is not working in the psp.
I have seen many PSP's stop reading UMD discs and for the most part they are repairable with the least amount of opening your PSP.
First we will do some trouble shooting with what might be wrong with your PSP unit.
About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
Another 25% is the Disc Spinning motor. This will not let The disc in the UMD spin.
About 20% is the Laser motor, this might be hard to spot since it could be something in the gears.
About 10% is the actual laser itself. It will not focus the laser to read the UMD disc.
The Last 10% is the Motherboard. This is the worst outcome, since there is very little what we can do but replace the motherboard.
So first what we need to do is find out what is actually wrong with your PSP.
With your PSP in hand.
Turn on your PSP and remove any UMD that might be in there now.
If you open up the UMD door and look down inside you will see the Laser assembly.
*** CAUTION DO NOT STARE DIRECTLY AT THE LASER ***
If the Motor is not spinning. is it moving slightly? Maybe a little twitch?
I would lean more towards the bad motor problem BUT would not say for sure, I would recommend that you take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser, I would try and check the cables to the PSP and see if there is a bad connection.
If both are running well then lets put a disc in and get your ear up close so you can hear what is going on in there.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be to much pressure for the disc to spin freely.
If you can't hear it move down the track OR it is very clicky follow this.
It would look like this if your UMD door was off.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing. It is quite hard to see it in the photos so I put a red star around it.
I usually try and scrape the gears themselves to make sure there is no gunk or debris in the gear.
This fixes it about 35% of the time.
If none of this is working, it is time to open your PSP unit Or send it in for repair.
If you know what's wrong you can replace the problem here
Replace UMD Assembly
Replace UMD Disc Motor
Replace UMD Laser Motor
Replace PSP Motherboard
Dec 03, 2010 | Sony PlayStation Portable (PSP) Console
My son's psp (the older fat version) has stopped reading discs
Not sure is this actual PSP or play station. If it is Play station It is very possible that there is problem with laser that reads disks. Try to by PSP cleaner and run it and this might fix the issue.
Dec 29, 2009 | Sony ACY-BR81/OB
My psp2006 ver5.03 cant read games
PSP UMD Repair: Not reading UMD discs
All photos and content copyright © Llamma Corp. 2002-2006
http://www.llamma.com/PSP/repair/PSP_UMD_Not_Reading_Discs.htm
Jul 16, 2009 | Sony Video Game Consoles & Games
Will not load disc laser and motor seem fine
only way you can fix is by moding your psp. either your drive is bad needs cleaning or the system tools need to be reloaded but it will need to be sent out if you don't want to mod
May 05, 2009 | Sony PlayStation Portable (PSP) Console
It won`t read my game
First we will do some trouble shooting with what might be wrong with your PSP unit. About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
if you need more infomation please just ask ... Symo02
Oct 19, 2008 | Sony PlayStation Portable (PSP) Console
Help!
You might have PSP stop reading UMD discs, First you will do some trouble shooting with what might be wrong with your PSP unit.
first is the Disc Spinning motor. This will not let The disc in the UMD spin. On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
2nd is something stuck in the UMD gear, try to clean the gear of arm of dust, plastic, soda, and even hair.
and at the last is the actual laser itself. It will not focus the laser to read the UMD disc.
Hopefully this help, Pls post back should you need additional information...!
Jun 01, 2008 | Sony PlayStation Portable (PSP) Console
PSP hanged when switch on. The usual screen appears but without the menu icons except for a small circle at the bottom right hand corner which keeps spiinning. Icons will only appear when I open the UMD...
conect your psp to you pc/lap top and find a default setting for your psps this are just like other peoples psp saved dater try that look on game sites and console cheats sites
May 09, 2008 | Sony PlayStation Portable (PSP) Console
Ok Crowd,
All of you need to send your PSP off for repair. The UMD drives not reading is common fault of the PSP and the drive will need to be replaced. The power on Problem is possiblly a defective motherboard. They can be repaired.
Click on "Repair Directory" at the bottom of this screen. Then select "Video Game Consoles" on the next screen. Pick a good REpair shop that has experience in repairing PSP's. Ask them if they know what a UMD is. Then Ask them if they have ever replaced a UMD drive. If so they know what they are doing. Find a good price
Nov 12, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
171 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
