Question about Califone International 1030AV Turntable
Trying to fix an old record player - Califone. It seems to be making a scratchy sound even though I have replaced the needle. It almost sounds like when the two wires from a speaker touch... same sound... but I opened it up, and that's not the case; wires are free and clear. Speaker (at least viewing it) appears to be fine. Any thoughts? Someone know of web resources to help out?
  • phattimmy May 15, 2009
    Cool. Yes, I'm in the process of trying another speaker... but to do that, I'm finding myself needing to bid for it on ebay. When it gets here I'm going to try it right away. I'm thinking that sounds about right.
  • 909 Answers
May be the "winding" on the speaker. If it has got damp at some point(you may not notice any on the casing) the cardboard tube that the coil is wound around swells and "rubs" in the speaker. Thus producing a scratching sound. Try connecting to another speaker, just to test and if it sounds fine then that is what it is.
Posted on May 14, 2009
Califone 1435k This record player from the 70s runs great and came highly recommended but the 33 records we're trying to play are sounding much too fast. Any ideas on how to fix this?
This is an idler wheel drive turntable that uses a small rubber wheel, that when engaged pushes on the motor spindle and also on the rim on the underside of the platter. The spindle on the motor is stepped so as you shift speed the idler wheel moves up or down the spindle and that changes the speed of the platter. It could be the the shifting mechanism is dodgy You can try to loosen it by gently shifting the speed from 78 to 16 and back again. But the idler wheel rubber might be in trouble too.
Dec 29, 2016 | Califone International Audio Players &...
Scratchy sound on turntable with mat om
One of two things. The deck has got a static problem. Perhaps caused by an earth connection problem.
Or you have a bad earth connection on the cartridge.
Dec 27, 2015 | Crosley Executive Portable USB Turntable
Just inherited an old califone 1010av. It turns on, but when I put the record on the turntable and bring the needle down, there is no sound and the arm slides to the center of the record very quickly. I...
SOUNDS LIKE NEELDE BROKEN.TO TELL PUT FINGER UNDER NEEDLE PULL BACK FINGER GENTLEY AND YOU SHOULD FEEL A POINT ON THE END OF THE NEEDLE.IF NOT OR UNSURE SEE IF YOU CAN SEE THE END OF THE NEEDLE THERE SOULD BE A SAFIRE OR DIOMOND IN THE END OF IT THAT SITS ON THE RECORD IF NONE IS SEEN REPLACE NEEDLE.
HOPE THIS HELPS
NORMAN
Aug 23, 2011 | Califone International 1010AV Turntable
Plugged it in and turned it on. Put a record on and moved the needle over. Nothing happened.
Hi.
From your description it sounds as though the drive belt requires replacing. If you are experienced, remove the platter to get the belt out carefully.
If you are not tchnicallly minded, take it to your nearest audio/hifi repair shop. should be no more than £20.00.
Jan 14, 2011 | Califone International 1005AV Turntable
The speakers are so scratchy sounding, even without playing a record on it. Just received it as a gift, so bummed!
static noise coming from the needle. reomve the needle and the speakers should go silent. if this works replace the needle
Feb 20, 2010 | Crosley Traveler Turntable
I have an old Califone 1400 all records skip new needle
There's not enough pressure to keep the stylus down in the grooves. Increase the weight (on the end of the arm).
Feb 10, 2010 | Audio Players & Recorders
Scratchy noise on my record player
Sounds like its time to change the needle [Stylus ] , there are a few types But the two most common are Saphire and Diamond Stylus pay the extra and get a diamond if you can , Hope this helps
Jun 01, 2009 | Creek 5350SE Amplifier
Record player sounds scratchy and tinny
Playing records is a contact sport.
Since the needle touches the record -- as opposed to a laser reading a CD -- any bit of dust or mold translates to annoying pops and hisses.
Record cleaners get down into the record grooves to extract dust and particles.
Or you may need a new needle.
Mar 25, 2009 | Electro Brand Nostalgic Stereo CD Music...
Sound scratchy
Seems to me that the first thing you want to do is find out if your problem comes from the camera speakers/output, or if it records them scratchy. Take one of the "scratchy" cassettes, and play them on another device to see if it transfers bad audio. If it does, then you're worst off offcourse, more of a repair. If it doesn't you can decide you don't need a repair, as long as it does the job. Good luck
Apr 01, 2006 | Panasonic NV-DS60 Mini DV Digital...
Califone International 1030AV Turntable Logo
869 people viewed this question
Top Califone International Audio Players & Recorders Experts
Ben Armstrong
 Bob Buchholz
Bob Buchholz
 Grubhead
Grubhead
Are you a Califone International Audio Player and Recorder Expert? Answer questions, earn points and help others
