Question about RCA P52926 52" Rear Projection Television
HDMI TRYING TO HOOKUP HDMI FROM DIRECTV TO HDMI-DVI IN BACK OF TV WHEN I UNHOOK COMPOS WIRES SOUND NO PIC?
Use the input button on your remote control... as you press input you should see VID 1, VID2, COMP 1, FRNT and then DVI... When you get to DVI you should see your picture..
Posted on Oct 19, 2007
Samsung LN-T4671F HDMI PC hookup and Audio Problems
Pls bear with me, have you tried not using the HDMI/DVI cable but simple straight connection PC > Standard 15 pin VGA cable and audio cable that has "stereo mini-plug" on both ends to the PC IN of the Samsung?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 09, 2008 | Samsung LN-T4671F 46 in. LCD Television
Viewsonic HDCP LCD & DirectTV HD receiver
connect it with HD RCA's....then youll have both HD and Working cable.
Nov 12, 2007 | Zenith HDSAT520 DirecTV DTV Receiver
Why do I have to go all the way through my tv hookup (HDMI 1,HDMI2 etc)to get sound. I just hooked up to directv and it used to work fine.
Sounds like the TV do not save the LPM (Last Position Memory). Contact the authorized service centre. If the main system control memory IC has any fault, this might happen. Electro help
Nov 18, 2014 | Sanyo DP26647 DP42647 DP50747 Remote...
No sound coming out of speakers tuner or cat/tv
Please add details of setup so I can help you. For example. My Directv box hooks into my HDTV HDMI. Sound is carried inside that cable. I then get sound on my TV from my Directv RCVR without any other hookup. But I do have more. I use an optical cable to go into my Denon 1312 TV/optical input. Since my Wii, PS3, VCR, and formerly Xbox360 all plug into the HDTV inputs and I use it to switch. The Denon is not HDMI capable so this is best for me.
This is the first thing I would try. hook the HDMI to your HDTV from the CATV/SAT box and turn up the sound on the TV. [Box and TV on and correct input used] If you hear audio, the hook it back up as before. Now, turn on the Denon to radio. and turn it up. Got sound?
NO: check speakers and speaker setting. Let's say you have speakers hooked to A but not B. is the selector on B or AB. That won't work. It has to match the hookup. If speakers are on A only, select A only, etc. Also check with known good speakers. Also check all cables to be plugged into the correct spot and plugged in fully.
Thanks PM me if you need more help.
Aug 07, 2014 | Denon AVR-1601 Receiver
How can I connect a samsung bdf5900 to my hitachi rear projection tv
Your TV is probably older and has Component, Composite and DVI connectors. HDMI is a newer connector that integrates sound. If your RPTV does not have HDMI but DOES have DVI, you can get an HDMI to DVI adapter on eBay or a computer store pretty cheap. You will need another way to get the sound from the Blu-Ray player, either external speakers connected to the player, or stereo RCA cables from the player to the TV (there will be a set of RCA audio plugs with the TV's DVI port).
Apr 30, 2014 | Samsung BD-F5900 Smart 3D Blu-ray Disc...
What's your problem?I just purchased a I just purchased a Sharp LC32SV40U. I'm trying to hook it up with my Shaw Direct DSR 505 receiver (DVI to HDMI. I cannot find how to get sound using this
When using this type of adapter you only feed video into the TV/monitor
you have to use a separate set of RCA audio wires to feed the audio into your tv.
Nov 24, 2012 | Sharp Televison & Video
Soyo dylto32c
The DVI input on this set is meant for picture only.. ex. to display computer picture.
if you want audio with your picture. you must connect to either inputs YCBCr or YPbPr which both of those inputs has audio inputs.
Mar 19, 2008 | Soyo DYLT032C 32 in. LCD Television
RCA P52926 52" Rear Projection Television Logo
109 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
