Question about Garmin nuvi 250 GPS Receiver
Have the battery cant open the case
How do you open the case?
  • Anonymous May 15, 2009
    I have a NUVI 260 with dead battery. Found the battery online. They sent me tools as well but no instructions as to how to open the case or replace the battery. I figured it was small and would be easy. Wrong!!
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Please don't try to do this yourself. You need the right tools and you risk damaging the case and damaging the LCD display. You also need to have the right adhesive to install the new battery.
    Also, if anyone tells you that its the same procedure as a Nuvi 760, it's not true... the two are put together completely different and the dissassemly is different. I've done this type of repair on both units and I've also hadto repair many units from "do-it-yourselfers".
    - Jim
    SHARCNET-USA
    http://www.sharcnet-usa.com
  • 48 Answers
Put your thumbnail under the Garmin logo and pry off the faceplate. You should then see how to get to the back.
Posted on Jun 02, 2009
Cant open doors without fob, put new battery in still not working, can'get into car
Check to make sure the battery is inserted correctly, the tabs are making good contact, and the polarity is correct. Check to make sure button contacts are clean if visible. Ensure case is snapped tightly shut.
Feb 27, 2015 | Cars & Trucks
I cant reset my bios mine has 6 pins and two jumbpers how to i reset them
Step 1:
you can remove cmos battery from your motherboard to reset every bios setting.
Step 2:
disconnect all power wires from your pc. first open your case.
Step 3:
now , remove cmos battery and leave it for 5 to 10 minutes. after that put that battery again and start your pc.
Step 4:
now open bios menu at startup. you will see everything resetted.
Apr 11, 2013 | Computers & Internet
Drivers side door cant lock
this case the driver door lock have problem , need to replace ,try dis connect battery while all doors are open .
Apr 08, 2013 | Skoda Fabia Cars & Trucks
Aston martin rapide battery has died and cant open the doors
When the battery goes flat on a rapide the windows are up. The doors are frameless so the windows are located in the seals in the door aperture. You cannot open the doors and you cannot open the boot. Look through the front grille towards the radiator with a torch and you will see the bonnet release cable outer sheath. If you pull the outer sheath it will put enough tension on the cable to release the bonnet catch. With the bonnet open you can charge the battery. Negative clip on the alternator casing and positive clip on the central charging stud.
Mar 04, 2012 | Cars & Trucks
Cant open my programmable key pad safe. the code wont work
Locksmiths agree try replacing the batteries just slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Aug 12, 2010 | Sentry Fireproof Safe
I have a lip 'tv' watch. i cant get the back off
There is a small groove between watch case and case back. This is the place where to insert the openers blade and pry up.
Jan 11, 2010 | Watches
How do you reset cmos bios administrator password
open case and look for jumper info in case read the info and reset the jumper
Rick
Mar 01, 2009 | Dell Inspiron 1200 PC Notebook
Roomba red battery
on the ends of the battery are two yellow clips. push these towards each other and pull up at the same time.
Jan 10, 2009 | iRobot Roomba Red 4100 Bagless Robotic...
Palm Zire 72
You have a bad connection, or no connection to the digitizer. This is common when changing out batteries. Re-open the case and check the connector to the digitizer.
Nov 01, 2008 | Palm Zire 72 Handheld
Garmin nuvi 250 GPS Receiver Logo
294 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
