Question about Mag Innovision LT982s 19" Flat Panel LCD Monitor
Getting message: "VGA mode not support"
I tried to change the screen resolution on the control panel because the size of the picture got too large, and then too small. But then it immediately went to black with the little blue box that says "VGA mode not support.." Nothing I do can get me out of that screen and back to the OS so i can change settings! Help!
  • 696 Answers
Shut the computer off, hold the power button for five seconds.
Once it's off, turn it back on and tap the F8 button until you see a black and white safe mode menu. Use your arrow key to select Last Known Good Configuration and then press enter.
This should get you back to your previous settings.
If it doesn't work simply comment back here and let me know how far you got.
Chris
Posted on May 14, 2009
How do you get your computer screen back to normal size
You can right click on a empty space on the desktop then click properties. When the Desktop Properties window opens click the Appearance tab. Go down to the font size and you can change it to normal, large or extra large. Normal is what it should be.
You can also get there by going into the Control Panel and changing the Font size on the display. Click Start/Control Panel and look for Display or Appearance and Personalization. Open the display, click the Appearance tab and change the Font Size.
If that don't do what you are looking for you can click the Settings tab on the display to change the Screen Resolution. The higher the resolution, the smaller the icons and therefore the more you will get on the screen.
May 12, 2012 | Computers & Internet
Program too large to fit screen hp mini 110 notebook
Change your screen resolution on the Display in the Control Panel.
Click Start/Control Panel and look for Display or Appearance and Personalization (depending on your operating system). When the Display opens increase the Screen Resolution. The resolution will be under the Settings Tab on the Display. The higher the resolution, the smaller the icons and things will be on the screen, therefore you'll see more.
Apr 19, 2012 | Computers & Internet
Unsupported video configuration occurs when computer is turned on. then asks to attach monitor cable to add- in graphics card. everything usually necessary to plug into is done.
It is possible that the desktop resolution was set too high for the type of monitor you have. This can happen if adjusting screen size settings. If this is the case, you may see the Dell splash screen at boot up and then the screen will go black when trying to load Windows.
If that is the case, try this:
Boot up in Safe mode or VGA mode (Tap F8 a few times when the dell splash screen comes up.....this should open a menu allowing you to choose the different modes)
If you are able to boot up in safe or VGA mode, you should be able to go into the display settings in the control panel and change the resolution. Find out what the native resolution of your monitor is, and see if you can set it to that. otherwise start the slider at the lower settings and gradually work your way up.
Good Luck
Jun 01, 2011 | Dell OptiPlex GX280 PC Desktop
My screen is connected to my computer--suddenly the screen shows pages too large and blurry. I can't recall how I resolved this problem when I first bought it and connected it to my PC. I'm missing...
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general
dpi normal size,larger size or custom settings
hope this helps
Jan 07, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
I have a samsung 510m lcd monitor when i plug the vga cable it shows "not optimized mode 1024x768"
Your computer's video-card is outputting 1024-by-768 video,
but your monitor would prefer to receive its "native" resolution,
e.g., 1280-by-1024 or 1920-by-1280.
Change the settings on your computer's video-card.
Note that this could make the text on the screen VERY small!
Or, just ignore the message, if the "large" size of text on the screen is easier for you to read.
Oct 20, 2010 | Samsung Computers & Internet
Hi I've got a Samsung TFT monitor -Syncmaster 710V - that gives an error message.Message reads: Not optimum mode Recommended Mode: 1280 x 1024 60Hz This screen is impossible to get rid of. Anyone know the...
Try to change the desktop display settings, see screenshots below, see if it works
Right click on your destop and go to properties > settings
  1. Set your Screen resolution to 1280X1024
  2. Then click advanced and go to Monitor and set the refresh rate to 60 Hertz.
Dec 06, 2009 | Samsung 710V 17" LCD Monitor
We can not seem to get it to recognise our new hp pc.
Start the New PC in safe mode. In safe mode the PC will have low resolution, and must be seen in any monitor.
If you cannot see safe mode picture, then check the cables. If you can see picture in safe mode, go to Personalize in control panel, find printer settings and lower resolution and change screen size.
Oct 14, 2009 | Dell E176FP 17" LCD Monitor
No sound and picture not full screen when connected to pc
if you have your tv connected to your pc with a vga cable, you will not get sound, since the vga does not carry sounds, only pictures. to change the settings on your pc to make full you will have to change your resolution size on your pc in your control panel
Apr 05, 2009 | RCA L26W11 26 in. HD-Ready LCD Television
Olevia Monitor
Restart your computer and tap the F8 key until you get the Windows Advanced Options Screen. Use the arrow keys on your keyboard highlight Enable VGA Mode (Low Resolution Mode for Vista). Press Enter. Then Enter again.
Windows will boot up in a low resolution which will make things look large. Raise your resolution to a normal level in Windows' Display Properties (in the Control Panel)
The next time you restart the computer, it will boot normally.
Jul 04, 2008 | Proview PL926WBi 19" LCD Monitor
Out Of Range
Do the same procedure you do to enter "safe mode" but this time choose the "start in VGA mode" option, then change windows resolution.
May 08, 2008 | iiyama ProLite E380S-S 15" LCD Monitor
Mag Innovision LT982s 19" Flat Panel LCD Monitor Logo
452 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
