Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
Washer will not complete the cycle.
The washer begins a cycle, sounds like it is trying to fill but does not.  There is water in it, it tries to wash, runs for about 10 minutes and the clothes are not even wet.  The symbol nF comes on.  We have checked the water lines and connections, they are correct.  The water comes through the line and into a bucket but does not seem to be getting into the washer.  The set-up is new so the problem has to be in the washer.  There is no kink in the line.
    Scholar:
  • 146 Answers
Check if you have power to the inlet solenoid/valve where the hose connects to the machine. There is a thin tube running from the outer drum at the back of the machine to a pressure switch. This pressure switch controls the water level in the washer. Remove this tube from the pressure switch and blow back into the machine. There could be a blockage in the tube. To check if the pressure switch is faulty, pull the tube off the pressure switch and let the machine fill. If the machine fills to a high level, switch it off before it overflows. Replace the pressure switch.
Posted on Nov 05, 2007
The water, there was no water left in the tub of the washer, but the clothes were dripping wet; and the cycle was showing to be complete. I had to re-set the dial to the spin setting inorder to completely...
What has happened is that your water pump has gone out and it cannot pump the water out of the washers tub. This is a common issue and replacing the pump is not that hard assuming you have the time, effort, tools and energy.
Jan 23, 2011 | Kenmore 24962 Top Load Washer
I have a GE Harmony Profile top load washer. It is stuck on filling during the rinse cycle. It usually stays at 18 minutes for about 15-20 minutes. I usually start adding buckets of water to get it going....
when washers go into rinse cycle they use cold water so the clothes don't rinkle,i would say that you have a bad water valve located on the washer,you can try to run the wash at the beginning just with cold water,if the water comes in slow you have a bad valve,you can then run it on just hot water and see if there's a difference in how fast it fills.the strange thing is that it should pop up with an error code after 6 or 8 minutes because the washer is filling to slow,have you seen any codes come up?if it is the valve the part number is WH13X10017 and that valve is under the top console
Nov 10, 2017 | GE WPGT9360EPL Top Load Washer
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer doesn't fill with water and begin wash cycle. I can hear it instantly draining out rather than fill, and has ran my well dry. We replaced the water pump a month ago, and it washed a few loads of...
Sounds like siphoning. This can happen if your drain pipe is too low and you run the drain hose right into it, or if there isn't any kind of air gap between the drain hose and pipe. Usually it shows up when trying to fill for the rinse cycle - it drains as fast as it fills. Or it might not fill at all. Order a "siphon break kit". They're cheap and easy to install
May 26, 2010 | Roper RAS6233KQ Top Load Washer
The washing machinge is not completing the complete cycle
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag washer wont start after it fills
Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
Mar 14, 2009 | Maytag Washing Machines
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
93 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
