Question about RCA 20F530T 20" TV
RCA Tv acting wierd
I have a 9 month old RCA 20 inch tv. Lately it has started acting weirdly. it turns on/off by itself and if i press any button it turns on/off. it is also not responding to remote. any suggestion would be helpful
  • 3 more comments
  • Anonymous May 11, 2008
    The television keeps turning off and on by it self.Iti s onlt three months old
    how do I fix a leaky processor
  • debbiegre Sep 22, 2008
    My television turns off after being on for 10 or 15 minutes. Then, if it is turned back on, it immediately turns off. Absolutely nothing seems to help. Can it be repaired? The set is only two years old.
  • southp013 Dec 03, 2008
    I cant even turn the TV on for more than 5 minutes.
    Very useless.
    Turns off
Must be leaky processor
Posted on Oct 25, 2007
My RCA D52W19 HDTV Ready TV will not turn on. The power led comes on three times after pressing the button on the tv itself or attempting to power on with the remote. The condition has been getting worse...
Hi Aaron,
I just want to ask you something before I give the solution, does the unit gone to start-up problem (needs warm-up before it finally turn on, needs to pressed the power button key several times, needs to unplug from the outlet and plug it back in)before, you have said that you've encountered it last few months?
Sep 29, 2011 | RCA D52W19 52" Rear Projection Television
This TV has Model number 2404141 serial number H466DD2D7 also ATC 106 and service # 2404141T This is a relative's set. When turned on, either with the remote or button on the cabinet, it acts as...
id suspect power supply boad is faulty......
if you can use a soldering iron.............
replace the caps on the board..........or search ebay for a replacement board........
May 02, 2011 | RCA Televison & Video
Need the number code for rca tv
I hope that after 9 months, you have gotten this resolved but if you have any problems, or you have another remote you would like to program, here are some simple steps!!!
The first instructions here are for a power scan, which scans the tv for the correct code for the remote. You just hold down the clear TV button until all lights at the top of the remote light up, then press the Power button, then press the up arrow about once a second, until the tv turns off. If the tv turns off, press the # (pound) button. Try your volume and to power the tv on/off. If one or both of these do not work, start the process over.
If you want to use only codes, here are the steps:
1. Hold down the clear TV button until all lights at the top of the remote light up.
2. Punch in the 3-digit code (provided below for RCA tv.)
3. Press the # (pound) button
4. Try the volume, and to power the tv on/off. If one or both do not work, start again at step 1 with a different code.
Becki Barned
DISH Network Customer Service
May 15, 2010 | DISH Network IR Remote Control
I have a 32 inch Haier TV and my comcast cable remote wont work with it. I need to know how to get my tv to sync with my cable remote.
there is an auto search method....some remotes you can hold the tv button down and then the select button simultanteously for a few seconds to make the light turn red and then proceed with codes, when you get the right code you press the select button again, the light blinks and you are done..... well with out a code its the luck of the draw..... the auto search method is similar to programming the code in....hold the tv button and the select button for a couple seconds until the tv button lights up, but instead of a the channel up button(that represents the first autosearch code), continue until the tv turns itself off and then press the select button to lock it into the remote...........if you go past the trigger point you can channel down to backtrack.... otherwise drop it in the toilet until it wont work, call the cable company and have them send out a tech with anew remote. they cant charge you for their equipment not working correctly.
trust me, i am a supervisor at a major cable company.
Jan 17, 2010 | Haier HTF20R21 20" TV
Insignia TV is acting wierd
the problem lies in themain board in the tv. you can buy one from ebay for around $80 used. its not to bad to replace either. just remove the back panel the main board it the tin/ metal wit hthe ciruit board in it on the left side same side as the power botton just unplug the 5-7 wires and unscrew the 2-3 screws and carfully side that board out and replace with a new workign one and put back together and you should be good to go.
please rate my answer it is much apreceated
Feb 04, 2009 | Insignia IS-LCDTV32 32 in. Television
Polaroid flm-2011 20 inch lcd television
 I will be happy to help.
  1. Turn tv on.
  2. Press and hold tv button on remote
  3. While holding tv button press and hold power(on/off) button, led light shold go off then back on after a coupke of seconds.
  4. Release both buttons.
  5. Aim remote at tv and press the power(on/off) button every 5 seconds until tv turns off.
  6. When tv turns off press the stop button at bottom of remote, that will lock in the code.
  7. Turn tv back on with remote and test all buttons.
Let me know if this helps and please rate this solution.
Jan 24, 2009 | Televison & Video
I have a 20 inch true flat screen RCA tv is about a year old. After you turn in off, later on it turns itself back on. and sometimes it turns itself off after being on for a short perion.
I have the same problem with the same size 20" RCA tv. Mine is a little over 2years old. After turning itself off and on whenever it felt like it, now it blinks off and on nonstop every few seconds and nothing makes it stop......please help
Dec 14, 2008 | RCA 20F410T 20" TV
52" RCA d52w19
About middle of the board you removed the flyback,there is a u shaped heat sink this is in the middle of the board,behind the heat sink is a blue cap 2200 uf ,if the top is pushed up the cap is bad.
Mar 11, 2008 | RCA D52W19 52" Rear Projection Television
TV turns on at odd hours by itself
Hi, I had the "Ghost In The Machine". I tried out what I descibed in my original posting.
#1. I unplugged The Set.
#2. I pushed in and held in the power button in for about 5 minutes before bedtime. ( The PC trick I learned) I gave it 5 minutes because a tv set has much more power inside it.
#3. I again pushed in and held the power button in again for 3 minutes the next morning.
#4. I plugged the tv in again. The red standby light was lit. The set did not immeadiatly come on when I tried to power it up.
#5. 5 Minutes later I returned and hit the power button on the remote and it came on like nothing ever was wrong.
#6. It has been fine now for 3 days!!! Powers up when commanded and shuts down like normal. It has yet to come back on or act up as it was doing.
I will keep a watch on it and if it starts up acting again I will repost. I hope this information will be of use to anyone who experienced the same problem. It didn't cost a dime, just some patience. Thanks for a forum that people can exchange information and save trouble and money unless all options are exhausted. Bill
Mar 09, 2008 | Philips Magnavox 20MS3442 20" TV
Proscan video problem
Sound like bad tuner,or tuner circuitry.Instead of spending money,why don't you bypass the problem??
Use a / v  outputs from source box to a /v inputs on tv
let me know by rating if you need more help....T.
Oct 20, 2007 | Proscan PS36125 36" TV
RCA 20F530T 20" TV Logo
105 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
