Question about Whirlpool Duet GHW9150P Front Load Washer
Front loader is making funny noises. It was
Front loader is making funny noises. It was leaking eariler now it sounds like something is in there rattling around. Chcked white filter in the front of the washer. It is a whirlpool Duet sport washer.
    Sergeant:
    Champion:
  • 214 Answers
Please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
Posted on May 14, 2009
Why does my washer (maytag mah5500bww front loader) make noise during the wash/rinse cycles but not during the spin.?
The noise could be from a loose wire harness, plastic purse-lock wire harness retainer on the upper hose hitting the top cover ir a plastic injector mold standoff on the outer tub bearing housing, also a flat spot in the belt could cause a tapping noise. Something between the outer tub and wash basket. I have had to remove items lodged in the drain tube between the pump and tub, like bra under wires. Sometimes you can squeeze the tube and feel objects the ate lodged. I always take the tube off the tub side and run my finger all the way down to the pump impeller to make sure. I also check the I can spin the impeller and the nothing is in the pump. Hard to say with out being there. Where do you think the noise is coming from top , bottom , left , or right side?
Apr 30, 2014 | Maytag Neptune MAH5500B Front Load Washer
Front loader washer won't fill up with water, makes a funny noise and turns off. Please HELP!
It has a pump to load water . The problem lies there in the pump.
Jun 28, 2013 | Washing Machines
Frigedaire dryer front loader makes clunking noise
Hi kirst_alers2 - From what you have described it sounds like you either have a problem with the belt, front (and/or rear) bearing, or a loose connection with the motor or drum. Lint or something else clogging the vent could be causing the dryer to take a longer time to dry the clothing. If the dryer is taking too long to dry then the issue may lie with a faulty sensor. I recommend contacting a professional to accurately diagnose the issue, the part(s) may have to be replaced depending if they are worn, damaged or loose. You can often locate a qualified tech through the manufacturer website.
Apr 08, 2013 | Frigidaire Electric Dryer
Front load washer makes funny noise when pump turns on
The pump sounds like it may be plugged wih a coin or something like that. If the pump is plugged it will make a funny noise. Remove the pump and clear everything out of it
Jun 07, 2009 | Frigidaire Affinity ATF6000F Front Load...
Front loader washing machine is not draining
Hi Is this a whirlpool? Sounds like something is in the pump or the pump is bad.
Get me model # and I can help you further. Thaks
Vic
May 16, 2009 | Washing Machines
Whirpool Duet Sport Washer still making noise now it s leaking
make sure to look really close all it takes is alittle whole in that seal anywhere to cause a leak try to look close while it is running but first dry everything you can and then run it. also make sure your door glass is clean if it is leaking down the front just alittle dirt or hair can cause a leak aswell
Mar 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LOCK AND LOAD ISSUE
can you be more specific about the funny noise. When does it occur, during agitation or during spin? something might me stuck in the drain area of the tub and as the tub rotates it rubs against it.
Jun 28, 2007 | GE WSXH208A Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
263 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
