Question about InFocus LP70+ Multimedia Projector
Vertical Lines on the projector screen
How can I fix this one for Infocus LP70+?
Re: Vertical Lines on the projector screen
When the vertical lines are displaying, open the projectors menu (by pushing the "menu" button). If the vertical lines affect the menu, it's a problem with the controller board and will need to be repaired. If the menu is NOT affected, it's probably a loose or damaged cable (Cable part# SP-DVI-A-R).
Posted on Nov 21, 2007
5 Suggested Answers
  • 2236 Answers
SOURCE: infocus projector lp70
in order for the lamp to strike and stay on, the fans and the colorwheel must be spinning and up to speed. if you remove the lamp and start it up, see if the 2 fans are spinning. and look inside to see if the colorwheel (a colored glass disk) is spinning. you'll also be able to hear a high-pitched squeal coming from it. unfortunately, you'll need to take it in to a repair center to have them replaced.
Posted on Jun 03, 2009
  • 2236 Answers
SOURCE: Thin black vertical lines in infocus projector screenplay 7205
normally, i'd say av solutions in ny, but they don't ship out of country. try
Posted on Jan 27, 2010
  • 2236 Answers
SOURCE: LP70 infocus projector is casting a shadow on the
the light tunnel is collapsing and need to be replaced. you could get the part from an infocus service center and do it yourself or send it in to one and have them repair it. speaking from experience, it's a quite involved repair. you have to basically take the whole thing apart to get to it, and make adjustment to it really close to the power supply while it's on. kinda risky. either way, try av solutions in ny. they're really good.
Posted on Dec 16, 2009
  • 167 Answers
SOURCE: infocus lp70
What's that??
Posted on Jan 16, 2010
  • 269 Answers
SOURCE: Our lp70 projector is blurry from mid screen up.
If there is any discoloration like a blueish hue then the light tunnel has collasped. But if it is just plain ol' fuzzy there is a trick you can try. Grab the focus tube behind the focus ring tightly and put some umph into it and completely unscrew the tube from the projector. Look inside the projector with a light and if you see any of the dried glue hanging from where it screws in remove it with some needlenose pliers. Gently shake out any that has fallen inside. Now look at the tube and clean any glue from it. While you have it off look at the back side of the lens and make sure it's clean. Next screw the lens on till it is on the threads but not completely screwed on. Now put 1 hand on the rear of the projector and one on the end of the lens and push the lens into the threads until it pops and then tighten it the rest of the way in but don't over tighten. Get your palm prints off the lens and fire it up and check the focus. Try to look at a screen that has text from corner to corner and see if the text is clear in each corner. If not loosen the barrel again and keep trying to get a different position when reseating the barrel and check each time until the 4 corners of the screen are in focus. When you get it close enough for your satisfaction and have tightened the tube back up the fun part starts.... Now you need to remove the top cover and be sure to break off the 2 airplane tail-fins in the top cover on either side if a tech hasn't already done in the past (they just get in the way when putting the top back on). Once you have the top off you need to super glue the tube back to the part that it is screwed into, just a very thin bead as far around the tube as you can. This will prevent the tube from unscrewing in the future when you are using the zoom adjustment. Let it dry and good luck !!!!
Posted on Nov 11, 2010
0 characters
3 Points
What causes white vertical lines on dlp projector?
Possible fault on the mother board as there are noise on the LCD display. You might need help to sort this out if the fault does not clear even after the lamp works for some times.
Nov 05, 2011 | InFocus ScreenPlay 5700 Multimedia...
Hi, I have a Infocus Projector, Model # LP70, serial # begins with ACAN. The projector only has 951 hours on the bulb. The unit powers on and I get the Infocus startup screen. as soon as I turn on a video...
I think it is the time to remove the cover and check for air filters blocked with dust.
When this happens, air doesn't flow freely through the projector and result in overheating, which leads to automatic shutdown.
Sep 22, 2011 | InFocus LP70+ Multimedia Projector
Process to upgrade firmware for InFocus lp70 ... can some describe this for me please? I've got the firmware downloaded, but my PC does not see the projector .. Help!! I also can not find the USB drivers...
Go here: down load the file then find the text document "D3 D3+ firmware upgrade instructions.pdf" in C:\LP70plus\002-0870-08\I , or where ever you saved it. That will give you the complete instructions on how to upgrade.
Apr 27, 2011 | InFocus LP70+ Multimedia Projector
Screen keep jumping
This is probably a voltage issue with the power supply especially if it is an LP70 type projector. If not it is still a power supply problem that will have to be fixed.
Oct 27, 2010 | InFocus Multimedia Projectors
Infocus LP70 powers itself down after 30 seconds or so.
Nov 12, 2009 | InFocus LP 70 Multimedia Projector
InFocus LP70 projector is running hot
clean the dust out of it with canned air. the dust keeps in the heat that the projector is trying to expell. it also shortens the life of the lamp.
Sep 21, 2009 | InFocus LP70+ Multimedia Projector
Lp70 flickers and color wheel chirps at the same time. It's worse with more white in the image. Colored screen shots or dark movies have limited flickering. No issues prior to hookup to computer (Infocus...
it's chirping because it's trying to keep in sync with the dmd chip. for the refresh rate, go into the menu and first reset the settings to factory default. if this doesn't clear it up, try matching the signal.
Jun 09, 2009 | InFocus LP70+ Multimedia Projector
Why does picture brightness change up and down on LP70.
Hi there
Sounds like the lamp is going , but it could be the Ballast as well ( lamp's powersupply ) Rather have a certified technician look at.
Mar 22, 2008 | InFocus LP70+ Multimedia Projector
InFocus LP70+ Multimedia Projector Logo
4,625 people viewed this question
Top InFocus Multimedia Projectors Experts
Juan Carlos Pacheco
Level 1 Expert
Are you an InFocus Multimedia Projector Expert? Answer questions, earn points and help others
