Question about Whirlpool Washing Machines
Need to tighten loose agitator on whirlpool washing machine model LLR8245B.
  • 5,911 Answers
You need to pop the cap off the center post of the agitator, followed by removing the plastic cap and o-ring inside. The agititator bolt is located underneath. Tighten with (I believe) a 9/16 socket with ratchet. Tighten until snug. Do not overtighten as this can restrict agitator motion and may crack it.
Now, if you talking about the upper portion (auger) of the agitator slipping, you will need to replace the agitator dogs. The following link explains:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The dogs are small plastic teeth that are located under the center post cap used to grip the auger as it turns. They do wear out periodically and require replacement. If you go to appliancepartspros.com and type in you model number you can view them as item number 10 under the "Agitator, Basket & Tub" section. You can use the part number I provided in the link, or use the Whirpool part number on the website. Both numbers cross reference to the same part. A very inexpensive fix...
If you still need assistance, please let me know. I hope you find this information helpful.
Posted on May 14, 2009
My Whirlpool LSR8233EQ0 washing machine making loud whining and banging noises during spin cycle only...any ideas on what to replace?
Two possibilites would be a loose agitator (some agitators can betightened from the top, check for tightness)If you can't tighten the agitator from the top, turn the machine over ( you will probably need to disconect water hoses first) and check the underside. From here you should be able to determine if the agitator is loose or more likely you've got a loose drive belt.
Nov 16, 2011 | Whirlpool Washing Machines
Drain line clogged on Whirlpool model ET1CHMXKB09. How do I access the drain line?
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with most old washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your self offer can fix it; here's how.
TOOLS NEEDED TO SOLVE PROBLEM ARE BELOW.
Bucket and rags,Screwdriver,
New drive belt (if necessary),
New drive motor (if necessary).
1 Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
3 Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
4 Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5 Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6 Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Thanks.
Oct 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer fills with water but does nothing after that
5
6
Feb 05, 2011 | Whirlpool Washing Machines
Agitator is coming loose. how do i tighten it
The top of the agitator comes aparts and reviels a bolt. Push the agitator back down and tighten the bolt snug.
Jan 08, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My washing machine basin on a Whirlpool top has come loose.
Hello, down the center of the agitator there is a nut. You need a very long socket shaft to get to it, tighten this and it shold solve your problem. I hope this helps.
Nov 05, 2009 | Cars & Trucks
TOP AGITATOR NEEDS TIGHTENING
You need to get an agitator repair kit from the appliance parts store. Number ap3138838 This has a new thurst washer that will fix the loose upper agitator. Remave cap under fabric dispenser, it pulls up and you will see bolt. This kit also has cam parts to repair the worn ones on upper agitator too. Take model number to the store with you.
Jun 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Loose agitator
Remove the center dispenser. Under the dispenser is a plastic cap with a pull handle on it. Pull the cap straight up and you will find a mounting bolt underneath. Using a socket and ratchet, tighten the bolt snug. DO NOT overtighten as this may cause damage to the agitator. If you go to searspartsdirect.com and type in your model number, there is an excellent exploded view diagram of the agitator components under the "Agitator, Basket and Tub" heading. If you still require assistance, please let me know. I hope you find this information helpful.
Sep 24, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Loose agitator Maytag LAT2600AAE
Look toward the bottom end of the agitator. There should be a small indentation where a 10mm screw is. This screw holds the agitator the the transmission shaft. Sometimes the screw works loose and needs to be tightened.
Dec 17, 2007 | Whirlpool LSB6200PQ Top Load Washer
Agitator
aleethie In order to help you better I need the complete model number of your washer. You can find it under the lid on the frame. Gendos
Jul 01, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
1,577 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
