My HE2 Plus will fill with water, but when the tub reaches 1/2 full, it drains, and the pre wash/add garment lights keep blinking. When the tub is drained, the door unlocks and the lights go off. There is no error code. Anyone experience this before?
SOURCE: All lights flashing!
I resolved the issue. The drain plug was clogged. To repair this first unplug the power from the machine. Then remove three screws holding the lower front panel on. Grab a bucket and put it under the "plug" on your right. Hold your nose as this part may smell. Slowly unscrew the drain plug and allow all contents to empty into the bucket. Now you know why the machine refused to work properly! Clean the drain plug and secure it tightly back in place. Put the panel back on. Plug in the power. And this should resolve your issue. Now go tell the wife how hard you had to work to fix her washing machine,duck, and do a load or two to help her out! Happy Washing!
SOURCE: Washer fills and drains at the same time.
Check for congealed soap in the Air Bell which is at the other end of the pipe for the pressure switch
Testimonial: "Thanks. "
SOURCE: kenmore h2 error code
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: The Kenmore HE2 Washer Model 11046462501 Selector
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
SOURCE: kenmore he2 plus front loading washing machine.
If you can supply a model number I will be able to help you with the problem.
