Question about Toshiba Satellite A60 Notebook
Laptop how to check the BIOS of a laptop
    Sergeant:
  • 457 Answers
Press either the F2 or F12 button when you start your machine
Posted on Oct 15, 2007
Password toshiba ne marche pas ile ne demarer pas
Posted on Aug 30, 2008
How to baypass bios password on sumsung np300e5x
You can't bypass BIOS password. All you can do is to RESET BIOS, by removing CMOS battery and waiting some time till it discharges completely.
After you reset BIOS, you shuld enter BIOS at startup and input your setup values, so before doing this, you should check your BIOS setup. See some video tutorials but be careful. Dismounting a Laptop is not a joke. You may end with some parts in a shoebox rushing to your repair service...
How to reset BIOS on laptop
How to remove Hard Drive and CMOS Battery from an HP Compaq 6735b Laptop
Reset Clear CMOS on Laptop and Desktop Tutorial 2015
Tutorial How to replace the CMOS battery in your laptop
Jul 24, 2015 | Computers & Internet
I can't find the bios flash instructions .how do you flash the bios on my toshiba a35s159
You should check the Toshiba WEB site for instructions to how to upgrade (flash) your BIOS, if you make a mistake you may not be able to repair or recover from your mistake.
I have done BIOS upgrades on a few computers.
If your Toshiba has a floppy drive and you can boot up from this floppy drive then the BIOS upgrade needs to be downloaded to a boot floppy. Then boot up from this floppy and run the BIOS upgrade program. When completed, remove the floppy disk and boot up your laptop.
YOU MUST CHECK THE TOSHIBA WEB SITE AS THESE INSTRUCTION MAY NOT BE APPLICABLE FOR YOUR TOSHIBA LAPTOP.
Jun 02, 2012 | Toshiba Computers & Internet
My daughters laptop does not start up. It is only saying: Harddisk security Primary Master Hitachi HTS545032B9ALock What should we do??
you restart your laptop and go in to bios setup check the bios setting and hdd security setting in the bios if u cant found than press "F9" key in to bios and press "F10" from you key board and exit....
Dec 17, 2010 | Computers & Internet
Dvd drive is missing when installing window 7?
check ur bios configuration...check ur hardware that connected at your bios default....you may clarification internal hardware that you can see into bios system,,,if not problem ata your bios system,,you may reinstall again your O.S to see that your firmware does support or not with windows 7
Jan 15, 2010 | Acer Aspire 5500 5570-2609 Laptop
E6500 making a beeping noise
Does beeping noise happened before turning on laptop? If yes unplug the laptop from the AC Adapter. Just leave AC Adapter ON and connected to the power outlet. Check if AC Adapter is the one making beeping noise. Note: This is an issue with dell AC Adapter laptops
If no beeping noise in AC Adapter then proceed checking it from the laptop. Does beeping noise happened immediately when laptop is turned on? If yes then it might be laptop's hard drive creating the sound. Try to check the BIOS in your laptop under the category performance if the HDD Acoustic is ON either in Normal or Performance. Note: When laptop is in performance the hard drive makes noise due to its speed, this is normal if BIOS HDD Acoustic mode is ON to performance.
If the noise only happens when sometime while working on the laptop, this might be cause by the laptop fan. This also happens after turning on the laptop fan my have dirt and dust, please do check.
If fan was cleaned, HDD performance was checked and AC adapter was checked then, carefully sense if noise is coming from the internal speakers.
Download the latest BIOS update for your laptop then flash the BIOS. Make sure battery and AC adapter are connected when doing these.
Dec 11, 2009 | Dell Latitude E6500 Laptop
We unplug the computer and it goes out does not
1. boot on bios (turn on laptop keep tapping F2, check the bios version and check the battery health and battery info)
2. if the battery is charge like 10% then battery info says batt performing normally then update the bios, download the latest bios from the dell support site.
3. if battery is 0% charge check if the ac adapter has correct watt display on the bios under battery info, make sure ac adapter is 65W above. if all fails then replace the battery.
Oct 15, 2009 | Dell Latitude C610 Notebook
Brightness not working . tried pressing fn and left control.
Turn on laptop keep tapping on F2. Check if you can go to the BIOS if yes then check the BIOS version from your laptop. Check the website if BIOS is out dated download and flash the new BIOS. If your cannot access BIOS, there might be something wrong with some keys on your keyboard, same thing update BIOS. if all fails replace keyboard.
Sep 21, 2009 | Computers & Internet
Hey! Laptop goes into Bios...
Ok what you need to do with that issue is let the laptop go into bios mode and then look for the boot options and see what is checked there. You may have it checked to startup with windows bios and if that's the case then you need to change it in bios mode. If you have any other questions please let me know!
Apr 07, 2009 | Sony VAIO VGN-FS742/W Notebook
Forgotten password
If you lost your windows password, try a program called "ophcrack-win32-installer-3.0.1.exe" or "ophcrack-xp-livecd-2.0.1.iso". These will crack and show any windows based usename and password on your computer.  If the problem is the bios password, for starting your laptop, then you will have to reset the bios (check manual) or remove the battery pack and on board Li battery to reset Bios. I would check the manual first. On old Toshiba laptops you could jump the parrallel pins to reset the bios, not sure on the Gateway. I will check further.
don
Sep 30, 2008 | Gateway M305CRV Notebook
Toshiba Satellite A60 Notebook Logo
264 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
