Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Green color seperation multiple images convergence will not fix
Plugged in digital camera which normallyworked. green color seperated at top left corner. After a few days it got worse, all colors seperated, multiple images. Help!!!
  • vfa25sdw May 25, 2009
    I have a Philips 60PW936317F projection tv. The problem looks exactly like the convergence issues decsribed in the trouble shooting. The only thing is I have control of the multi point convergence adjustments on red and blue. The green seems to be shifted causing the warping and 3d look on the screen. I also have a wavey green line on the bottom of the picture. Is there a convergence chip for the green field as well or is the ASC moudule bad? I have also seen the SSm board replaced for this instance. Any assitance would be greatly appriciated.
  • JVC Master
  • 3,459 Answers
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directigreen color seperation multiple images convergence - 0667c5f.pngnvergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Posted on May 22, 2009
    Genius:
  • 1,148 Answers
IN THE MENU LOOK FOR COLOR CONVREGENCE TRY THAT
Posted on May 15, 2009
ALL 3 COLORS ARE SEPERATED AND CONVERGANCE DOES NOT FIX
We fixed this same problem as a dyi project. Check out www.tvrepairkits.com. The kit itself come with the proper chips, fuses, and very detailed instructions which includes pictures. They also have online help if you have questions. If you know how to solder and are a very careful person, this is something that you can fix yourself.
Mar 08, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Pink and green colors seperated images rounded off
If colors are skewed and will not adjust in the customer menu---you have a CONVERGENCE circuit problem.
This model (KP-51WS500) uses two of the STK-392-560 convergence IC chips. I just got home from fixing a similar model with the same problem.
Parts cost on Ebay for the chips and such is going to be less than 30 dollars total. Shops are going to get 300 or more for this kind of repair---and some will not do it in your home---the repair takes about an hour--I have done hundreds of them here in people's homes.
If you have questions or need advice, reply to this posting and I will try to help.
If this told you something that helped you understand, rate this solution as I do this here for FREE.
SD TECH
Nov 14, 2009 | Sony KP-51WS500 51" Rear Projection...
Color seperation and red drooping line
You have defective Convergence IC's. It's best to have a service company verify and do the repair if you wish. Normally runs about $250.00
Jul 14, 2009 | Zenith R45W46 45" Rear Projection...
Red and Green
check video IC or tv convergence sometimes yoke
Aug 12, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Bend in picture and color seperation
try resoldering the convergence ICs if that doesnt help you will no doubt need new Convergence ICs .resolder both of them as thats sounds like a solder issue, unless the IC is getting to the end of its operational ability
Mar 26, 2008 | Sony KP-46WT500 46" Rear Projection...
Colors have seperated on top of screen
convergance ic are bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Televison & Video
Three colours don't converge
Sounds like your convergence power supply board is bad if it is a ctc or ptk 195 chassis. Located above the main board on the left and dynamic convergence board on right. Has two plugs and held down with quarter inch screws. Most problems on the board is the IC on the metal heat sink which is stk 730-010. whatever you can see the part number on it. Unsolder with solder wick and solder in new. If this doesn't fix a new complete board will do.
Sep 09, 2007 | RCA P46922 TV
Arched picture at bottom seperating the green and red
Your tv has a convergance failure. the convergance ic's need to be replaced. Upgraded part # STK392-150 or STK392-160. Both ic's should be replaced to prevent future failure of other colors.
May 20, 2007 | Toshiba 43H70 43" Rear Projection...
Green colors are seperated from rest
You might have a bad green convergence output IC either loose from the circuit board or open internally OR shorted. Stargazer
Apr 22, 2007 | Pioneer PRO-99 TV
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
297 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
