Question about Microsoft Xbox 360 Console
No video, appears to be no video sync, diagonal rows of dots. Not an HDMI TV, switch is in TV position, cable checked ok by using a new cable, same problem
No video, no video sync. Diagonal dots only
  • 23 Answers
Sounds like you have an incorrect output signal from the Xbox or a fried chipset in the Xbox. Test the Xbox on another TV or monitor, test another video source on that same connection, if both of those fail, replace the Xbox. Hope it helps!
Posted on May 15, 2009
VGA to HDMI converter connection and set up
Use VGA adapter to HDMI works for video
Sound is carried over stereo cable
What you are doing needs 2 cables
Video cable for video
Sound cable for sound
Using TV for monitor VGA to HDMI 32" at 120 refresh is best dot pitch .
over 32" dot pitch is lower may become grainy resolve place monitor away more from you when using over 32" TV 120 refresh is important
Jul 15, 2016 | Computers & Internet
I keep getting green dots all over tv screen.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jul 15, 2015 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
Just bought a 55" Lg Led tv and i hook up hdmi from cable box to tv hdmi 1 and hdmi from my blue ray player to the tv hdmi 2, ok then i turn the input on both now hdmi 2 work but hdmi 1 has no signal why...
try connecting your blue ray player to HDMI 1.
A) If it works there, then you know the port on the TV is OK & the problem is with either your HDMI cable or your cable box.
B)If it still doesn't work then you may have a problem with the port on your MAIN PCB. if it's a new TV your warranty will cover that as long as the input connector is not physically broken.
Mar 08, 2015 | LG Televison & Video
Sound on but no pitcher
Sound on means audio section is ok. No picture is video board problem. Pl check input cables. Or give Hdmi cable input. Disconnect all inputs switch on u should get plain raster that is only dots on screen, or blue back screen, if nothing contact authorised dealer,
Feb 08, 2015 | Panasonic TH-L32C20X 32 inch Multi-System...
Yamaha rx-v1600 hdmi output not working
Have you inspected the HDMI socket? I had the same problem and the socket had been damaged by a tight fit cabinet with insuficcient space behind the amplifier. A sideways cable tug on the inserted HDMI cable had snapped a small piece of plastic seperating the two rows of HDMI connectors, and three were splayed out, so no connection when plugged in. Solution was to carefully re-align the connector fingers and glue a tiny piece of insulating material between the two rows. The output now works perfectly. A bit fiddley, but worth the trouble when you look at how much Yamaha would charge to fit a new socket, or even a new board!
Don.
Aug 11, 2012 | Yamaha RX-V1600 Receiver
Only 1 hdmi outlet on TV . I have a high def cable box and a sony blue ray dvd player. How do I connect 2 hdmi cables fron the components to the tv?
Don't used the Blu Ray player on the tv HDMI out put hub.Used the connections for of the Blu Ray player connections by a S-Video cable for the video and the RCA component cable R,W for the connections for the audio out.The high Def.cable box will not work for high Def. this way,but the Blu Ray player will.
May 30, 2011 | Sony BRAVIA KDL-40S2400 40 in. LCD HDTV
I see red dots on screen of dlp samsung tv. Not sure why. Could be a bad lamp? When I watch tv thru regular tv cable between cable box and tv , the tv is loosing signal.Thru s video signal is ok.
optic block failure is the dotty appearance use your model number to shop around for a new one and the coaxial input's are easy to break loose so use s-video if at all possibly ok
Dec 31, 2010 | Samsung DLP HL-P5663W 56" TV
I have a Mogen ML-1508TN 15" LCD TV which worked perfectly well until I moved house recently. Having re-installed it in my new home all I get is "No Sync" on the screen everytime I switch on. My helpline...
In the U. S., we would see "No signal" if there is a problem with picking up the TV station. "No sync" may be equivalent; the tuner may be detecting a signal, but it isn't strong enough for the TV to pick up the synchronization pulses needed to decode the picture information.
You can check this by connecting a known-good video game set, DVR or DVD player to the TV and verifying that the TV properly shows that.
Worst case: you're only using HDMI inputs, and the HDMI circuit was blown out by static electricity during the take-down or reconnection processes. That's been a problem with some cheap HDMI external switches. Before assuming this, try a different HDMI cable; there are some low-quality types with fragile connections at the end.
Nov 22, 2017 | Televison & Video
Scrolling diagonal lines
The cable box signal on the components video have a too high refresh rate frequency, that is the reason for the lines.
Use RCA cables or an alternative connection.
Other solution is changing the display out settings for cable box (from PAL to NTSC etc.)
Sep 01, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Microsoft Xbox 360 Console Logo
155 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
