Question about Western Digital My Book Essential 1TB External USB 2.0 Hard Drive
External firewire hardrive not recognized and unmountable in linux not seen in disk manager on xp
External isnt seen by mac or xp tried mounting in a live version of backtrack 4 beta and that didnt see it either. its seen in device manager but not under disk manager ... when i put it on an xp machine it installed the drivers but was not seen anywhere again besides device manager... thoughts?
SOURCE: un recognized drive
what you should do is search for a driver for it so put the name of the usb then driver in a search engine and download and install a driver this should make the computer able to recognise the usb's software
Posted on Apr 04, 2009
SOURCE: External USB Disk is installed but not visible under Mu Computer
Go to manage, refresh, and then asign a letter to it.
--- tuljo
Posted on Apr 27, 2009
Crankstart
  • 696 Answers
SOURCE: Tried installing hdd from cctv dvr to save it's contents.....
Most PVR's use a small linux micro operating system to run there menus and handle the drives, as such many of the drives used by them are formatted in Ext2/3. You will need to install a driver in windows that allows it to mount ext? drives and then you should have no problem accessing it. The link below will take you to a download site for a free driver, but they do ask you to donate. Please if it works throw them a bone as this is how they keep providing such useful software for all of us.
If this works, copy the files to your computer and then let the PVR reformat the drive, unfortunately when windows doesn't recognize the drive as being formatted, it marks it. That mark is messing with the PVR but after you add these drivers you should have no problem moving the drive back and fourth as it will recognize the drive and it's data in the future.
http://www.fs-driver.org/download.html
Hope this helps FixYa,
Chris
Posted on Jul 08, 2009
SOURCE: 120 gig Western Digital black no longer mounts on LEOPARD osx 10.5 grrrr
It may need a USB 2.0 Power Booster Cable
WDCA029RNN
http://store.westerndigital.com/store/wdus/en_US/DisplayAccesoryProductDetailsPage/productID.106596600/categoryID.13095900/parid.13092600/catid.13095900
Posted on Sep 12, 2009
bob_computer
  • 3153 Answers
SOURCE: Hello,
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
Posted on Nov 26, 2009
Help Resizing Mac hard drive with Disk Utility
Boot up your computer with using a linux live-cd/dvd manjaro fedora puppy or other technical distro to start up what will have gparted and or the kde partition manager on it that does do everything unmounted to that will allways enable all necessary things to replace or resize partitions , beware backup first always the distro in any way to be safe with the beginning to experiments. but there are several kind of tools and all open source is free , here you see a part of the kde partition manager and here is to see that will you rezise a partition that it just not must be mounted , thats the most important step to get a working menu by changing partitions that will forget. but it must first are recognized before to choose the right drive partition manager is also good usable for Microsoft or Beos and several other partition cluster arts of other unix systems.
the live dvd will work fully from out the memory of your system thats why it cost many more time for handlings. whats also be better to resize partitions is most time to delete an 3 partition system from the right the third partition (if its handling mounting active partitions to resize up to the right site its differs how to boot with a bootmanager was configured after resizing from the middle partition the find theright cluster out.resize from the left site can made bootproblems, if you not can handle
Apr 27, 2016 | Hard Computers & Internet
I took a WD external drive and installed it as a second sata drive. Bios and Device Manager recognize it not windows xp explorer. I want the data so I can't formator use disk manager. Drivers are on the...
The Drve most likley does not have a partition or it has one that is from Linux or Mac. Use the disk manager snap in and see if it sees the drive. If so then create a partition on the disk then windows will assign a drive letter and you can format it
Jul 12, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Freezes up During Backups
I suggest an application called "Disk Warrior" it has always maintained high ratings among us Mac enthusiasts it has a hardware test function built into it and seems to be a little better at verify and repair functions than Disk Utilities which you can try also if you haven't yet. You may also consider trying a different firewire cable if you have one handy. Other than that a reformat should have put the disk back into an original state however the disk could have been damaged by not un-mounting it in rare mac cases. If you have the time you can also reformat the disk again although I would try the first two options first.
Apr 23, 2009 | Computers & Internet
IOMEGA eGo portable hard drive won't copy files from mac
Format your hardrive for Mac OS:
Go to Disk Utilities under the go menu in your finder. Select the external drive and click on the erase tab. Clikc erase again and it formats the drive. You can now copy files onto the drive.
Oct 29, 2008 | Iomega (33090) 250 GB Hard Drive
Hard drive not being recognized
my book world is a network drive, you should connect it to a router / switch using an ethernet cable. if you use a usb cable to get it recognized on your computer it will never work
Aug 24, 2008 | Western Digital 500GB My Book World...
Recognized - but no mount
Don't know about the MAC part, but an I/O error implies that the either the source file cannot be read or the destination drive will not write. This is usually an indicator of a bad HDD. To check, I would attempt to connect the external drive to another computer. If it still gives the same indication, contact the drive manufacturer about data recovery recommendations
May 29, 2008 | LaCie (300728U) 250 GB Hard Drive
Firestore FS-4 no longer recognized as external drive by Macs
bad firewire port try getting a new firewire card throw usb many or pcmia pci card for desktops
Jan 30, 2008 | Video Cameras
FAT32 format, how to do it in Windows XP?
Try using a third party program, like Norton Partition Magic, Acronis Disk Director Suite, or Paragon Partition Manager.
Nov 20, 2007 | Western Digital WDG1C2500N MyBook Premium...
My glyph is not seen on my mac
If the drive is connected via firewire, power the drive. If the drive powers and you can place your hand on it and feel it "spinning", and still it does not mount. Try a different FW cable. If still no mounting action, place your ear on the drive to hear any grinding or clicking. If the drive sounds to be operating normal, open disk utility.. Hard drive/Applications/Utilities/Disk Utility The drive should appear in the left pane under your computers hard drive. You should see the button to MOUNT it on the top right. Hope this works
Oct 01, 2007 | Glyph GT 050Q 400 GB FireWire 400 (1394a)...
SanDisk U3 Cruzer 4.0 GB Stopped Working
Try putting in the deep freeze over night and see if it fires up next day.- they do go down these things. I have seen one get so hot the casing started to melt - but it still worked OK
May 20, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Western Digital My Book Essential 1TB External USB 2.0 Hard Drive Logo
149 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
