Question about Zanussi FJD1666W Front Load Washer
Zwf 1020 w
My drum is going around but it make a horribel sound when it starts spinning could it be ther ebearing ,, but when only just going around there is no noise
    Sergeant:
    Champion:
  • 214 Answers
Please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
Posted on May 14, 2009
Why do i have loud noises coming from my washing machine only whilst it spins
The bearing in the drum has failed and it's always noiier as it spins faster as there is more debris being thrown around inside the hardened steel casing of the bearing. Bad news is that's a write off. Uneconomical repair. It will tear its self apart shortly, probably leaking grease into the wash and leaving black marks everywhere, oor the drive belt will come off, or the drum will impact the front gasket and fill the drum with smoke. Any way you look at it, it's almost certainly going to destroy a load of washing. Throw it away now before it wrecks your washing
Aug 21, 2016 | Washing Machines
Why is the drum on my machine isn't moving?
check ur drum belt or the wheel pulleys and in some cases the center bearing and shaft? my suspicions lie with the pulleys fairly inexpensive and not to hard to replace
Jul 25, 2014 | Zanussi ZWF1230W Front Load Washer
Amana electric dryer whining when started
Is ther anything caught between the drum and the back of the dryer. run you finger around the back edge of the drum inside do you feel anything caught
Feb 02, 2014 | Amana Dryers
Elecrolux EWF 1020
If it gets louder the faster it spins its more than likely the drum bearings, if its a constant noise starting when the machine is emptying it could be the pump or something stuck in the pump,If so check in the filter for hair clips etc.
Nov 06, 2013 | Electrolux Washing Machines
Problems with zwf 1437w. Drum not turning durin wash
see this causes and fix it. God bless you
Belt
The belt may have come off or broke. If you hear the motor running but nothings moving the problem is likely the belt. This is easy to check and replace.
Door Switch
This can cause the washer to not agitate or go into the spin cycle. You will need to remove the door switch to check it. You will perform an ohm reading on the bottom terminals. The reading varies from manufacturers most Frigidaires is around 1500 ohms others like the whirlpool duet is checked at the main control board with the door closed should be around zero ohms. You will need to refer to the tech sheet or service manual for the proper reading.
Main Control Module / CCU
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace.
Motor Control Module
The motor Control Module is located inside the cabinet down near the motor. This recieves the signals from the main control module then relays this information to the motor. Check all connections sometimes a communcation problem is just a loose connection. The Motor Control Module is easy to replace. To check this further you will need to refer to your tech sheet or service manual.
Sep 25, 2012 | Zanussi ZWF1230W Front Load Washer
Zanussi zwf 1221 will not turn drum, the end light flashes the water goes into the drum and drains out when a program is selected but the drum will not turn at all. You can turn it by hand and it moves...
you need to check the pressure switch inside the washing machine there a small hose connected with the pressure switch to sense that the level of water inside the drum is ok if this hose blocked the machine will not run
Oct 10, 2011 | Zanussi ZWF1430W Front Load Washer
Zanussi zwf 1020w keeps over filling then cutting out
hi it sounds like your pressure valve is on its way out or you have a block in the little pipe best way to see if you have a blok in your pipe is take the top off your washer and find your pie is only thin going in to a round valve take it off and with some water in the drum blow down it if there is bubbles comeing up i would get a new valve hope this helps stuart
Jul 03, 2009 | Washing Machines
Zanussi zwf 1020w drum not revolving
The drum will not rotate until the draining process is satisfied, there is either something in the pump or pump is broken
Oct 20, 2008 | Zanussi FJD1666W Front Load Washer
During spin cycle started making loud noise now drum feels loose DURING SPIN CYCLE DRUM SOUNDS AS IF IT'S HITTING SIDE.. FEELS LOOSE WHEN I PUSH IT AROUND FRIGIDARE GLTF1040ASO
ckd your warranty papers sounds like rear drum support(spider) has broken will require new basket and rear drum half est cost 400-600 spider is not a separate part and rear bearing is probably damaged that too is not a separate part and require rear tub replacement
May 20, 2008 | Frigidaire GLTF1670A Front Load Washer
Maytag Washer Noise While Spinning
Most washer models have snap-clips holding the front of the top panel down, with hinge-like clips at the back. Carefully pry up the top panel on the front of the machine using a tool that won't scratch the finish, such as a plastic or wooden wedge. If it does not pop loose fairly easily, then carefully examine the back of the machine to see if this is a rare model that has screws holding down the top panel. (But really, it _should_ just pop loose.) Once the top panel is tilted up to expose the inside, you should be able to see everything you need to see inside the body to evaluate a spinning drum problem.
Aug 04, 2007 | Maytag MAT13MN Top Load Washer
Zanussi FJD1666W Front Load Washer Logo
135 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
