Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Cleaner suddenly stopped working
Little red spinner on top won't spin, water and soap won't dispense.
  • 1 more comment
  • STRECK12 Dec 14, 2007
    little red spinner on top want spin
  • Anonymous Feb 20, 2008
    little red spinner on top won't spin, water and soap won't dispense.
  • Anonymous Jun 22, 2008
    Carpet cleaner suddenly stopped putting out water. Little red wheel only pins occassionally
Based on the other solutions I read, I also traced the problem to clogged input/output ports to the heater. I hadn't used the cleaner for about 2 years and the ports were blocked by calcium and mineral deposits. I took the manifold cover off the bottom of the heater and carefully reamed the ports out with a finishing nail. I then cleaned the ports and manifold with Lime-Away to dissolve any other deposits. I put it back together (with no parts left over!) and it works fine.
Posted on Jun 26, 2008
The main problem I experienced was, as several of these reviews mentioned, the unit failed to spray solution on the carpet after using it only once.
Being mechanically inclined, I decided to investigate myself. I checked three areas of the unit:
Base - I removed the base cover so I could see the lines and the pump. Everything looked ok, the lines had fluid in them but I could see that fluid was not moving through them when I pressed the spray lever on the handle. The small spray heads were not blocked.
Handle - Opened up the handle to check if the spray lever was somehow disconnected inside and wasn't really activating the pump. Everything there looked fine.
Center (where the heater is) - I found the real problem here and it may be the reason for many of the reviews that mentioned that "the spray stopped working". Inside the lower part of the handle, where the red "heating" light is, there's a small heater which the water lines pass through. Even though my unit was used only once, I could see through the clear lines that the outlet from this heater was blocked. I removed the line from the end of the heater unit and used a paper clip to clear away what looked like a lump of minerals blocking the output. Once it was cleared, the unit started spraying again like brand new.
The bottom line, I think, is that, if you have hard water in your area, when that water goes through the heater, it causes some of the minerals to come out of solution, block the heater output and prevent it from reaching the spray heads.
Posted on Oct 30, 2007
I also found that the Heater wqas the problem. It is the outlet port on the heater that gets clogged.
Posted on Jan 15, 2008
My Bissell carpet shampooer will not dispense water or cleaning solution, nor is the "flow indicator" spinning
most of the Bissell carpet cleaners that have the water heating feature stop pumping water at one time or another. Make sure the belt is still on the pump and if it is then the problem is probably in the heater core in the handle. Hard water deposits plug the tiny little water ways inside the heater core. Pull the heater core and take it apart and clean it with a strong scrub brush and I think vinegar works for cleaning I was told. I just use soap and a brush. Then flush all your lines with hot water. The cause is from hard water deposits or leaving the soap in the cleaner after you use it. Both will stop it from pumping water
Apr 29, 2014 | Bissell 1698-1 PowerSteamer ProHeat Plus...
Flow indicator does not spin when the trigger is depressed like nothing is coming through, pump?
Usually that is showing no soap in soap tank even if there is water in the water tank.After filling soap tank make sure it locks in real good ;Thats been my problem a few times.I didnt know the water and soap were in seperate tanks the first 2 times I used mine lol....
Jun 22, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
I have a Bissell ProHeat Turbo. It has only been
i use white vinegar to clear my line.. and it doesn't hurt the carpet.
check the little filter on the top of the machine (mine is on the right side) if it is full of lint, etc and blocked it will not dispense or pick up.
Mar 28, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell ProHeat Rug and Floor cleaner. Won't
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
sf
Oct 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Wont spray soap
Please look at my other posts for this solution
Aug 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Proheat wont spray soap with uniformity
heatman101
jhkl
Sep 10, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Troubleshooting for Bissell proheat
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just re-fasten it down.
Jun 14, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Water and clearen not coming out.
If the modle is an old modle the heater could be blocked,or if it a new modle try taking of the of the handle and ad a small shim to the bottom of the handle plunger to make it a little bit longer ,the plunger might not be reaching the valve,
also unscrew the clear cap which which is on top of the red spinner to see if the white filter under the spinner is clean and free from debris.
when you put the cap back on make sure its not to thigt and the spinner move freely, if the suction is poor make sure the red lint filter in the clean water tank is clean
Oct 20, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
250 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
