Question about EliteGroup GeForce 6100SM-M Motherboard
Setting up vga.
I have just installed this motherboard into my computer.  When I plug in the monitor, I do not get any signal from the mother board.
I have checked and rechecked the connections but to no avail.  How do I activate the vga port on the board?
Send any helpful answers to ddl@3rivers.net
Thanks
  • 1 more comment
  • Anonymous Dec 24, 2007
    i plugged in vga and no signal comes up
  • 4--jamie--4 Jan 05, 2008
    same mobo and no vga input really frustrating can't download any cds for os or mobo cd
  • Anonymous Mar 13, 2009
    Should I send it back ?
Have you checked to see if there is a jumper setting for that model? I have changed from intrgrated to AVG one time and that was a problem I had for a week.
Posted on Oct 16, 2007
LG monitor displays "D-SUB POWER SAVING MODE" when it is starting
The message it is displaying indicates that a VGA cable is connected and is not sending signal, or is sending a Monitor Off signal across the VGA cable. The motherboard battery will have no impact on this. If you are using something other than a VGA cable to send the signal to the monitor, then you should ensure that no VGA cable is plugged into the monitor, or the source on the monitor is not using the VGA connector.
Mar 28, 2014 | Computers & Internet
No monitor signal on my m2n-vm dvi after installing my new graphics card asus en210.The graphics card was tested on my other pc and works fine..any help?
First boot the computer without connecting Graphic Card, then go to BIOS and find for VGA option change the option to compatible mood, save the setting and come out of it. now off the computer re connect your graphic card and start the computer.
Aug 15, 2012 | ASUS M2N-VM DVI - Motherboard - micro ATX...
Monitor Not Receiving Signal
There is a number of things that could be bad. First is the cable between the monitor and the computer and since you said you checked all of the cable connections we can skip that. Next if you have a separate VGA board installed it may have come loose or may have gone bad. Next is that if your VGA port is built onboard the mother board it may have gone bad and in either case buying a seperate VGA card should fix the problem.
Oct 30, 2017 | Gateway Computers & Internet
My Mother Board Is **acer sf2 661fx rev 1.1**. Now I Have A Problem, Please Solve This.......... No Signal To Monitor, But Mother Board Is Working. After That I Tried To Solve The Problem By Following...
haii all.....
i facing problem on mb acer sf2 661fx rev 1.1 no power to cd rom and hdd...also monitor not shown anything... cpu fan and casing fan only working..any idea pls..
Aug 03, 2010 | Acer (ACERMOTHERBOARD)
Screen pink red after installing mother board
uncompatible motherboard with many hardware,
1 - VGA screen card not compatible
2 - if VGA card is on board, then driver in the HD not compatible
3 - Screen resolution set to unsuported screen refresh rate HRTZ
Dec 06, 2009 | Computers & Internet
Adding a video card and get no output
Look in the motherboards manual for info about installing graphics cards, see if it needs jumpers. Plus make sure you plugged the monitors vga or dvi on the right place (VGA or DVI port ON the graphics card, NOT on the old vga port you used to plug your monitor before )
See if it works otherwise tell me..
Sep 14, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
No signal to monitor when booting.
(1) Remove memory from mother board and start the system if you happen to listen long beep then RAM is not working properly.
(2) Clean RAM conducting area on mother board with clean cotton cloth, put one peice of RAM and test and check the othe peice also, if working you could any sign display . Before doing all these check mother board any LED is glowing if so your SMPS is working after you turn on UPS.
(3) Check for all proper connection for all cables. Have you connected video cable of monitor to mother board VGA (it will not work because it is disabled as soon as you installed XFX GeForce 8800 GT), your viedo output only will come through XFX GeForce 8800 GT VGA port.
(4) If propelm persits Deassmble complete the system and reassmble & do n't connect HDD, DVD, floppy. Cehck with bare mother baord, processor, RAM (put one picese at a time) by connecting viedo cable of monitor
Apr 19, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
EliteGroup GeForce 6100SM-M Motherboard Logo
82 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
