Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE side by side refrigerator freezing up
Replaced defraust heater and did not fix problem. Tried replacing main board but the new board I could not get to work properly. It would not kick on the compressor. Model# GSS25JFPCC
  • 144 Answers
Have you tested the D'stat(Defrost thermostat)?
Posted on May 15, 2009
Side by side Model GSS22WGPA CC Ice has quite freezing and frost is building up on the back of the freezer. Only 7 yrs old. I have been told it is probably the defrost heaters and it has shorted out...
if they will replace it do it . i do belive that the main board wil have to be replaced . but i not sure that the heater caused it .. that is guess work at this time , .. mm hope this helped . ps did some one ck the heater .. in any case g e will fix it and if it keeps doing it make them repl .. hope this helps mm feed back pls ..
Oct 21, 2010 | GE Refrigerators
Is the heater timer on ge refrigerators with computer boards, locayed in the computer board? does the whole board have to be changed also? the heater and the thermostat have been changed but, the...
There are four things that will cause this problem and they are the defrost thermostat, defrost heater, evaporator thermistor and the main board. This page will help http://appliance-repair-it.com/GE-refrigerator-repair.html
Also yes, the board is the timer.
Sep 14, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
DEFROST PROBLEM
you said a mouth full . any of the 3 would cause freeze up.. so make sure the inside fan (evap fan is working ) . if unit is newer one the control in side fresh food may be bad and the sensor in the freezer. if it does not sense tempt properly the compressor run time is too long causing freeze up . now some times new components fail so ck them . . clean the bottom coils . and make sure the bottom fan is cooling the coils .. mm
Jul 29, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
GE refrigerator won't keep cool
check the voltage going into you fan w/ the old main board and also w/ the new board. You might be getting a low voltage w/ your new board or the fan you replaced is for a diferent voltage. Have you tried to put the old fan back w/ the new board??
Dec 10, 2009 | Hotpoint HSS25GFP Side by Side...
Evaporator coil freezing, replaced main control
It is possible you have a defective fan motor in the condenser area or evaporator area. Sometimes when they become defective they will run for a while and just warm up and stop while the compressor continues to run. I learned that one on four costly returns to the home. The cost was to me not the customer. Thanks, Sea Breeze
Aug 05, 2009 | GE GSS25SGPSS Side by Side Refrigerator
Ice building up in freezer
Due to the frosting up, The glass defrost heater broke. Any good tech knows this happens. The defrost heater must be replaced. If this is a GE side by side. The new replacement heater has dual elements. The standard heater that was put in them, was not large enough to defrost the coils fully. Replace heater and you should be fixed up. I would also replace the thermostat while you are in the freezer section they are only like 15 bucks and this way you will have a new defrost circuit.
Jun 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge is freezing up. not going thru defrost cycle we have a side by side ge fridge and it freezes up and we unplug it letit defrost and it will be fine for few days.& then is does it again; we...
The defrost heater must be replaced when the defrost T-stat is replaced.
The main control board located on the rear of the fridge controls defrost sequence.
May 15, 2009 | General Electric GSS25JET Side by Side...
Refrigerator keeps freezing up. Replaced defraust heater still froze up in about 4 weeks. Tried to replace main board WR55X10037 WITH WR55X10656 BUT THE NEW BOARD DOES NOT KICK MY COMPRESSOR ON. GE SIDE BY...
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
May 14, 2009 | GE Profile PSW26P Stainless Steel Side by...
Defrost issues
If it's around 2-3 years old, my first guess would be the heater is bad. The GSS models have problems with the heater almost always about that time.
Test the heater and the defrost thermostat for continuity with a multimeter. Whichever one doesn't get continuity is bad and should be replaced. If they are both good and the evaporator fan is running like it should, it will be the main control board located on the back of the unit.
Click here to see the defrost heater
Click here to see the defrost thermostat
Click here to see the main control board
Let me know if you have any other questions about this issue.
Mar 19, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
112 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
