Question about Compaq Presario V4000 Notebook
Presario v4000 is dead
Will not even try to power on. Checked DC supply and it is putting out 19.5 vdc. It is dead to the world. Any ideas?
  • 1 more comment
  • beaklr Oct 15, 2007
    Thanks CompuGuy44, do you think it could be something as simple as the dc jack problem that I am reading so much about here on the net? I don't know how to open the laptop to inspect for a cold solder joint or corrosion/heat damage. Are there any instructions posted online that describe the steps in opening the unit? Thanks again!
    Thank you CompuGuy! that is exactly what I have been searching for! Awesome! Thanks again!
  • sam the man Dec 03, 2007
    My laptop connecter for power supply was broke got new one but no power no lights even a come on
If you want to try to solve this problem yourself, download the service manual from Hp. http://h10032.www1.hp.com/ctg/Manual/c00530488.pdf
Posted on Mar 10, 2010
  • 432 Answers
For unknown reasons, only the computer gods know what happened. You need a new system board for your laptop. You can buy one and fix yourself or have a computer shop replace it. Your probably better off buying one off the internet and take it somewhere to have them replace it.
 I found a brand spankin new one for you on ebay. http://cgi.ebay.com/New-Compaq-Presario-V4000-915GM-System-Board-383463-001_W0QQitemZ170158400649QQcmdZViewItem
Posted on Oct 15, 2007
  • Raymond Scott
    Raymond Scott Oct 15, 2007
    Yes Sir there is.
    http://www.laptoprepair101.com/laptop/ca...
    Good luck to you.
  • Raymond Scott
    Your Very Welcome ! Don't forget to ground yourself and the parts your
    working on. Don't use any plastic, fabric or carpet as a surface to
    work on. Wood is a good surface. Good luck, let know if I can help
    again.
How do i turn on a compaq ps-7231 power supply?
Pin Name Color
Description 1 3.3V Orange +3.3 VDC 2 3.3V Orange +3.3 VDC 3 COM Black Ground 4 5V Red +5 VDC 5 COM Black Ground 6 5V Red +5 VDC 7 COM Black Ground 8 PWR_OK Gray Power Ok is a status signal generated by the power supply to notify the computer that the DC operating voltages are within the ranges required for proper computer operation (+5 VDC when power is Ok) 9 5VSB Purple +5 VDC Standby Voltage (max 10mA, max 2A in ATX 2.2 spec) 10 12V Yellow +12 VDC 11 12V Yellow +12 VDC 12 3.3V Orange +3.3 VDC 13 3.3V Orange +3.3 VDC. ATX V2.3 / EPS12V V2.92 both define that the PSU has to use remote sensing to compensate cable drops on the 3.3V line. Because of this there is an additional brown cable crimped together with the orange cable either to pin 13 (ATX) or pin 1 (EPS12V). 14 -12V Blue -12 VDC 15 COM Black Ground 16 /PS_ON Green Power Supply On (active low). Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF. 17 COM Black Ground 18 COM Black Ground 19 COM Black Ground 20 -5V White -5 VDC (this is optional on newer ATX-2 supplies, it is for use with older AT class expansion cards and can be omitted on newer units) 21 +5V Red +5 VDC 22 +5V Red +5 VDC 23 +5V Red +5 VDC 24 COM Black Ground /PSON activated by pressing and releasing the power button while the power supply is in standby mode. Activating /PSON connects the power supply's /PSON input to ground, thereby switching the power supply to full-on condition.
Feb 26, 2015 | Compaq Computers & Internet
Motor tripping out power supply
The input to your treadmill is about 120 volts Ac. The output from the board will be about 30 Ac. Almost nothing on there will be measured in DC. Your particular issue is your motor controller. It needs to be replaced.
Jul 27, 2017 | Reebok treadmill i-run s
Have an Acer Aspire 5920-6470 that is dead. The power supply seems OK with the green light on and ~19 VDC on the DVM when checked. no power light on computer when plugged in, with or without battery. ...
Try remove the battery and unplug it from the AC. Hold down the power button for 35-45secs. plug AC back and see if you can power it back on. If not, the motherboard is shot.
Dec 29, 2010 | Acer Aspire 5920-6727 Notebook
I want to convert this power supply for use with a battery charger for model aircraft. I need to know the color codes for the wires and also the pinout and which wire is the power on.
Pin Name Color Description
3 COM Black Ground
4 5V Red +5 VDC
5 COM Black Ground
6 5V Red +5 VDC
7 COM Black Ground
8 PWR_OK Gray Power Ok (is a status signal generated by the power supply to notify the computer that the DC operating voltages are within the ranges required for proper computer operation)
9 5VSB Purple +5 VDC Standby Voltage (max 10mA)
11 3.3V Orange +3.3 VDC
12 -12V Blue -12 VDC
13 COM Black Ground
14 /PS_ON Green Power Supply On (active low). Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF.
15 COM Black Ground
16 COM Black Ground
17 COM Black Ground
18 -5V White -5 VDC
19 5V Red +5 VDC
20 5V Red +5 VDC
18 AWG is recommended for all wires except pin 11, which should be 22 AWG. For 300W configurations 16 AWG is recommended.
There are several ATX variants.
Hope this helps.
If this helps you resolve your problem, please
consider giving me a rating of 4.It will help me as well. Thank you.
Nov 26, 2010 | Compaq (243890-001) 250-Watt Power Supply
Compaq Presario V4000 BTO notebook PC PC Notebook is dead won't turn no lites nothing completely dead
try to change the motherboard of the laptop immediately you change it the system will work again.
Jun 14, 2010 | Compaq Presario V4000 Notebook
Yes this is a good list of the voltages to be expected from a newer power supply on just the main header
Apr 01, 2009 | HP Compaq dc7100 PC Desktop
Computer wont turn on
it might be a bad power supply
Mar 12, 2009 | Compaq Presario V4000 Notebook PC
Compaq Presario M2000 DEAD
My power plug that goes in the computer gets hot enough to melt the plastic ring on the end of the plug. so i am going to get a new power board and try that.
Jul 27, 2008 | Compaq Presario M2000 Notebook
No Power
What is the cassis number to your set. RCA has to be diagnosed by the chassis as they have used different chassis depending on manufacturer. Should be a PTK number located on the back of your set.
Feb 23, 2008 | RCA P52960 52" Rear Projection Television
Compaq Presario V4000 Notebook Logo
794 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
